8
Everything posted by mjeff87
The Escapade continues.
mjeff87 replied to DirtyComanche's topic in MJ Tech: Modification and Repairs
It's an even 42" Jeff -
I can measure the D44 I have (sitting in a wheelbarrow beside my deck at the moment :oops: ) when I get home from work tonight. Whaddya want, spring pad center-to-center? Anything else? Jeff -
steering box - AND new comanche!
mjeff87 replied to urbanMJ's topic in MJ Tech: Modification and Repairs
You're adjusting the "over-center preload" Don't worry too much.....if you overadjust it, the worm gear will bind and you'll feel it. Just adjust the slop out of the wheel, and leave a little bit of play in it. You'll know it when you dial it in, it'll "feel" right :) Jeff -
That nut on the top of the steering box that you saw is the adjuster. It's a locknut with an allen head setscrew inside of it. Loosen the nut, then turn the allen screw inwards, in very small increments while checking the play after each adjustment, until the slack is taken up, then retighten the nut. Be very careful not to overadjust because it will ruin the box if it's too tight. Good luck! Jeff -
Yeah, I know......but at least this one was semi-interesting, and they only spent $250,000 :eek: Anyways, the crew built a Baja 1000 "top truck", and proceeded to sink it in the sand in the middle of the race. They had to get strapped out by nothing other than 'ol Paco in his stock XJ :D Then they got rearended and their junk broke. Funny stuff. Jeff
I lost something on the way to the paint shop!
mjeff87 replied to Drahcir495's topic in MJ Tech: Modification and Repairs
That's almost the exact same dimension of floor that was missing from mine, except it ran a little bit further back along the tranny tunnel. The cargo mat padding did mine in as well :oops: I cut a patch panel out of a junkyard MJ as well, of the tranny tunnel area from the firewall forward, above the TC shifter and back to where it bends around in the back. For the flat parts of the floor I used 22 gauge steel sheets from Lowe's. Didn't have access to a welder, so I used a bazillion 1/8" self-tapping sheet metal screws all around the perimeter and gobs of sealant (but it still leaks a bit so I have to rip it all apart again and find the hole :roll: ) Fun times...... Jeff -
Well, here's some pics of the damage. First one is the head (aluminum) that took the worst of it. Notice the black gap around the intake valve from about 2 o'clock to about 11 o'clock.....that's the missing bits of the seat :roll: The other pic is of the piston head, and you can see the nicks in it. There's only one of them that's "bad" enough to worry me about (the big blob at 5 o'clock). I'm just gonna carefully file it down (I think it's a part of the seat that fuzed itself to the top) and call it good. Shop is running about a week behind, due to it being race season down here, so I might not get the new head back until next weekend :mad: Jeff p.s. thanks for the offer Pat :cheers: Once I get this thing fixed and back on the road, your bumper is going on the MJ permanently. I'm dying to bust out the sawzall! Image Not Found Image Not Found
neither can my wife...... Jeff
:eek: ...and I thought I had a bad night wrestling with the cylinder head on my car.... Did you fubar the splines on the TC output or on the slipyoke? If it's the yoke, I have a YJ yoke (somewhere in my mess o' parts) I can send ya (?) Or, maybe think about an SYE..... Jeff
Well, I was finally able to get time to work on it, and pulled the head off last night. Turns out that about 2/3 of the intake valve seat is AWOL. Looks like it broke off in a couple of pieces and got mangled/burned up inside the cylinder :eek: There's a bunch of pock marks on the top of the piston, as well as in the chamber in the head. (I'll take some pics and post them.....it ain't pretty). So....I'm dropping the junkyard head off at the shop this afternoon for some R&R. Hopefully I can get it back by the weekend and get it all buttoned up and running again Any ideas on what I can use to smooth out the top of the piston head? The nicks aren't that deep, but I don't want to ignore it. Jeff
oil in the airbox, another cause
mjeff87 replied to mjeff87's topic in MJ Tech: Modification and Repairs
Yeah, it's all clean. I've actually taken the whole top end of the head off (rocker cover, rockers, pushrods, lifters and cleaned them back to bare metal (and plastic)) as well as the vac circuit in the TB and the small vac line from the VC. My problem is worn valve seals, more than rings on the bottom end...not technically "blowby" but has the same result. I get oil in the filter, as well as oil pushing out from the oil fill cap on the VC :oops: I gots too much positive pressure inside the cover, and that little vac line in the back isn't pulling all of it out and into the TB.... Jeff -
My wife and I are leaving tomorrow for the beautiful, sunny, city of Brothers-with-guns, Philadelphia, PA for a couple days. From there, we get on a boat (a BIG boat) and won't be back until next weekend Anybody close to Philly? We'll be there from tomorrow afternoon until Saturday morning (sadly I'm leaving the MJ at home :cry: ) if anyone wants to meet/greet (?) I doubt I'll have internet access while we're away, but if I can find it somewhere, I'll check in with y'all. JnJ-- I'll see if I can't pick something little up for you while we're "in-country" :D :banana: :banana: :banana: :banana: :banana: :banana: Jeff
X2 for me, on everything said right there! Jeff
Hey Richard, welcome to the club! :cheers: Jeff (Jeff in VA, over on NAXJA)
I'm diggin' it. The stack turned out well, too! (still need a flapper on top of it, tho :D ) Jeff
Just put a tape on mine.....I came up with 15' 6" (186"), give or take. HTH, Jeff
Yup, the BA10 (2WD) won't work without major surgery....probably even more difficult than a 2WD AX15 to boot, considering the "clamshell" design of the case. I don't even know if it's sectioned like the AX's, where you can remove the rear section. I'd guess it's two cast pieces- maybe you can't convert it at all (?)
Couple little things not to overlook. You'll need a longer speedometer cable, and the '92 is an electric speedo. Also, depending on what tranny you end up using, you may need a different sized transfer case linkage rod (there's 3 different sizes, one for an AX5, AX15, and AW4). Or you can fab your own stand-alone linkage. You'll also need to either cut down the MJ 2WD rear driveshaft or source one that's specific to the driveline you end up using....the XJ one will be too short. Front shaft may or may not be the correct length. And if you reuse the Pukegoat or go with an AX15, it'd be a good idea to do a clutch job while you have it all torn apart. Maybe swap out the CPS as well if yours is questionable too, since you'll have easy access to it. It's the little things in doing a conversion that make you slap your head sometimes :D Have fun! Jeff
Discovered another cause for my oil soaked air filter aside from blowby. While changing the oil and PMCS-ing the MJ this weekend, I noticed the little vaccuum actuated flapper valve at the bottom of the airbox that lets air in looked like it hadn't moved in ages :roll: No vac signal = no fresh air to the intake. I'm gonna fully diagnose it when I have time, but for now I temporarily blocked the flap WFO. Viola! It's not starving for air now, and not sucking oil laden crankcase vapors back thru the fresh air line that runs to the airbox :D Just something y'all might want to check out if you still run the OEM airbox/filter combo.... Jeff
Found you a nice sticker to add to the back of your MJ..... :brows: Image Not Found
On the way home from work last night, drove thru a road construction zone where the workers were laying a fresh topcoat of blacktop down. No big deal, right? Well, about 1/4 mile later there develops the most gawd-awful grinding/scraping sound under the front end. Scary enough to make me pull over and inspect to see if I was dragging something underneath (wasn't). Limped it into the driveway, waited out a horrendous rainstorm, and pulled the left front wheel hoping the unit bearing hadn't crapped the bed :roll: Turns out a fresh hot piece of blacktop got itself wedged behind the rotor and the backing plate. It had actually fused itself to the backing plate :headpop: and of course I couldn't get it out. Had to pull the @$#^% rotor off and chisel the damn thing off the backing plate with a screwdriver and a hammer. It left a very faint score on the rotor, not enough for me to worry about. When I swap the new D30 in, it ain't gonna have dustsheilds! Jeff
4.0L Renix exhaust question
mjeff87 replied to Bounty Hunter's topic in MJ Tech: Modification and Repairs
Mine doesn't (although it's a 2.5...it's still Renix :D ). Just 2 studs on the end of the manifold that fit thru a flange collar on the pipe, held by 2 9/16" nuts. The end of the intermediate pipe is flared a bit. Simple but cheezy design IMHO, but it works! Jeff -
Actually, mine's a 5 speed, not an auto. I've stepped up to 235's from the stock 205's (but I've changed my speedo gear). But I've discovered that leaving it in 4th more often as opposed to shifting into OD is helping economy-wise. I only use 5th now on the interstate, everything else I stay in 4th (unless coasting on a downgrade). I'm moving up to 31's when I regear to 4.56's...I'm hoping it'll basically be a wash and things won't really change that much mileagewise. Normally my MJ isn't my DD, but it has been for the last couple of weeks :oops: I used to drive it about 1X a week. But one thing I've noticed now that I'm driving it daily as a commuter vehicle (LOL) is that the more I drive it, the better the gas mileage is getting :nuts: I dunno, I guess things are "loosening up" some the more I drive it, and it's going down the road more smoothly. Trust me, I ain't complaining!! Jeff
Wha??? 30-35?? I gotta go get me some of that Ohio gas-o-lean :D I get an average of 18-20 in mixed driving (that's with the CAD shimmed over and pass side axleshaft locked full-time). Back when it was a 2WD (and had a few thousand less miles on it), 23-25 mpg wasn't uncommon :cry: YMMV, Jeff
I'm straight-up DIGGIN' the "legal" rear lights :cheers: Nice build, man. Flat black to boot...... Jeff
