Everything posted by 87manche1
http://www.quadratec.com/products/55216_211.htm
Try quardra tec http://www.quadratec.com/products/55216_211.htm
Flipping the dana.
Flipped the alt a week or so ago.
My next project
Way to high $ for me.
Yep it is found only one topic on it. Looks like security is built into the pcm.
1993 cherokee country 4.0 auto runs great but after 30 mins stalls out then continually stall after a short wait.. New cps, fuel pump tuneup. So after hours of checking I found an article about cycling the lock unlock switch on the door and it restarts Imediately a stall instead of waiting. But will stall back out after 15 mph, so I've come to the conclusion the security is faulty. So does anyone have any info on a 93 xj not grand Cherokee security module? I can't find anything but grand cherokees.
Usually cyber monday is when the internet gives good deals. But hey they could do friday too. Usually a discount and shipping is reduced or free.
Most Likely A Dumb Question
87manche1 replied to jpdriver1's topic in MJ Tech: Modification and Repairs
U may not need to charge. U need to understand an a/c refridgerant pressure scale. Which gets way more involved than I can type. Its better to charge it when its nice out. If u charged at 40f and didn't weigh it it from an empty circuit. U may actually overcharge it. They are meant to run off of the low pressure switch in winter. -
Transfer Case To Transmission Studs
87manche1 replied to Megadan's topic in MJ Tech: Modification and Repairs
3/8"NC on the case itself,3/8"NF on the nut side. From sir google search -
Yes on defrost, point of it is to dehumidify the air that's hitting the windsheild. So it defogs quicker -
Pm me ur email ill send them to you. Hose is required the one on there now doesn't allow hood to close.
Ok wel guys I've been wanting to do this for some time as I don't have a/c and I like to offroad. I like rocks but sometimes u have to hit the water. 88 4.0, first I remove the belt, remove the idler pulley and a/c bracket. Remove alt and all brackets. Cut 2 ears from the idler pulley they are the perfect space. One of these spacers goes onto the small tab to a/c mount Next take the steel alt bracket trim to fit. At the alt this is your second spacer location. I am running this with the mechanical fan for now. Belt I grabbed at a jy for testing if needed I can get a p#. I'm sure ill have more on this. And I need to grab an upper radiator hose for an a/c truck.
You could use a dana 300 behind it to.
What To Buy For The Front When Doing An Soa?
87manche1 replied to hawkswag1's topic in MJ Tech: Modification and Repairs
Save up. Ull need control arms, control arm drops to fix the severe angle, track bar, shocks , swaybar extentions, lift spring 4.5"-5.5" basically a whole lift minus the rear -
91 is the same as 93. These covers go from 91-96 get a felpro rubber gasket not the cork way easier to use. Just installed one last night.
'90 Renix Not Injecting Fuel - A Bit Long...
87manche1 replied to OneOverZero's topic in MJ Tech: Modification and Repairs
Mine runs at 37 psi and bleeds down to 20 something. I would get spray from the scharder. May also look into the rubber line in the tank corroding away. New fuel filter? -
Do u actually here the fp run? Pressure test first. Check fp relay -
Which Mj Would You Consider More Desireable?
87manche1 replied to badazzelanore's topic in MJ Tech: Modification and Repairs
I like being different I say chief. I don't see many around here -
So How Do These Shoes (Wheels) Look?
87manche1 replied to a1awind's topic in MJ Tech: Modification and Repairs
Like em -
Oil Where It Doesnt Belong?
87manche1 replied to mpace6a's topic in MJ Tech: Modification and Repairs
Slow valve cover leak? And as u drive in rain there's ur water on ur lower bolt?
