WahooSteeler
    5
Everything posted by WahooSteeler
  1. Kept searching and came across Hornbrod's post in DIY............all good
  2. Curious to see anybody's setup that has fabricated or used something different than the OE metal rod with plastic ball caps on the load sensing valve. I know there is a lot of debate on using it, disconnecting it or eliminating it altogether. I prefer to keep it but my truck never had it since I bought it. The arm is there and zip tied to a parking brake cable, but I'm doing a lot of work to get it back on the road for my son who gets his license in @10 days and this is on my "to do" list since the brakes have always seemed to be a little touchy. Don't need my new driver locking up the brakes his first day out. Thanks for any pics and suggestions.
  3. Reviving this old thread as I need a replacement floor anchor bolt on the driver side shoulder harness. Old one was rusted and stripped and had to be drilled out. I do believe the retractor bolts and the anchor/static bolts were the same length when I removed the others. Top pivot one was longer, as were the ones for the buckle anchors I believe. Anyhoo, anybody got 1 or 2 laying around that I can buy? No pick n pulls around here to grab out of an XJ.......
  4. Don, what is your current measurement on your front end, and what is the stock measurement? I prefer little to no rake which is how your truck appears to me.
  5. A couple of years ago someone on here suggested 5W/50 Castrol as Eagle also mentioned above. My local Advance Auto has it in stock, @$6-7/qt.
  6. Will a fuel sending unit from an 86 2.8 work in an 88 4.0? I'm guessing not because of carbureted vs. fuel injected. If not, can it be rebuilt with new pump etc and work? 86 model is out of a 23.5 gal tank and would go in the same size on the 88.
  7. My truck has the cargo light, definitely comes in handy when needed, hauling trash in the evening or a long day of yard work. I think Stroker needs to sell me one of his NOS for a backup.
  8. WahooSteeler
    Sacrilege
    Is that a 1/4 scale RC toy?
  9. Jeff! How goes it man?! Yessir on the sweat equity and scraped knuckles. BTW, I still have your 15mm socket that somehow made it back with me that day! LOL
  10. Plenty of 'Manches over the years that could be in that forum too! Yeah, someone could custom build something for half that! Less!
  11. https://sanantonio.craigslist.org/cto/d/1970-ford-bronco-with-bronco/6334590785.html
  12. At $90k I figured this was better posted in The Pub than the Classifieds! Pretty cool though! https://southjersey.craigslist.org/cto/d/1990-vw-syncro-camper-vanagon/6305034554.html
  13. That is just friggin sweet if you ask me. I see this in the dually project one day!
  14. Thanks Pete and Hornbrod for letting me know about the DIY search index. Been away for awhile but my son gets his license in 30 days and Jeep MJ (still have my VA custom plates) is getting back on the road!
  15. Very ironic that before I even saw this thread tonight I posted in the Pub that I think a good sticky in Tech or Projects would be a basic listing of parts needed, do's and don'ts etc for members like rylee144 and even myself.
  16. I think a good sticky under Tech or Projects would be for MJ lifts. They could list out the minimum requirements for each common lift amount. I.E., 0-3" lift can be accomplished with these kits or collection of parts and requires 1, 2, 3, 4 to be done, i.e. front brake line extension etc. Then duplicate it for over 3" to 4.5" and again for over 4.5". Maybe what separates the lift categories is when a certain amount of lift triggers another critical requirement such as control arms or a transfer case drop or SYE etc. I know the majority of members know this on their own, but I still think it would be a great sticky for quick reference instead of sifting through a ton of posts. Just my nickels worth........
  17. https://missoula.craigslist.org/pts/d/jeep-cherokee-comanche-front/6313967055.html
  18. Hornbrod, my truck has a hard wired electric fan that comes on as soon as the ignition is turned on so I could not hear the pump humming when I tried it. Need to do it again and crawl under the truck. Hopefully I have some time to troubleshoot this weekend.
  19. Eagle, thought of replacing the filter as a cheap first step. Hornbrod, I'll have to try again and listen specifically for it, but I don't recall hearing it before and I had the door open when I went to crank it.
  20. Truck got parked probably 2-3yrs ago due to various issues, mainly cracked manifold. Been putting off getting it going again due to normal constraints, time and money. My son gets his license in November and this will be his DD until he goes to college. Time to get it running again. So, over the past few years I would start it every 4-5mos and let it idle. Unfortunately time got behind me and it's been well over a year since last fired. Put a new battery in, 4 gallons of new gas and some Seafoam. Lots of cranking and no fire. Several shots of starting fluid and she'd fire long enough to burn that off but no love after that. I let it sit for a few days (and had to recharge the battery) and tried one more time. Same thing, fired with starting fluid but very briefly then dies. On the last try I noticed that the fuel gauge was pegged "full" but I know it does not have a full tank as I purposely let it run low when I last started it so I didn't have a tank full of old gas. Is the fuel gauge incorrectly reading full an indicator my fuel pump finally died? Thanks for comments, suggestions and direction............
  21. Still lurk around this great site from time to time and wanted post with a picture tonight. Tried the search, looked on pinned posts and now I'm taking the easy route. How do you post pics now? Been so long since I posted one I forgot how and assume it has changed. Thanks!
  22. http://www.ebay.com/itm/VINTAGE-COLEMAN-MAVERICK-TRUCK-CAMPER-POP-TOP-EXPANDABLE-TENT-CAMPER-/141948816203?forcerrptr=true&hash=item210ccf0b4b:g:9mgAAOSwsN9XAB7g&item=141948816203
  23. Long time no see fellas! Hornbrod, congrats on #16, great game! I'm an ACC fan (I have to say that since I'm a UVA fan and they suck at football LOL) so I was pulling for Clemson, but that history of knowing "we're Alabama and we're not out of this" came through. I'm also a big Bama fan though as one of my best friends went there, so Roll Tide!
