Eagle
Moderators
    27
Everything posted by Eagle
  1. :agree: Yep ... what he said.
  2. There was no box behind or around the factory speakers in an '87 MJ (or XJ).
  3. There's a possibility it's a crack in the flex plate, if it's an automatic. Test: Start engine. Rev it up and down a few times in neutral (not to redline, just up and down slowly from idle to maybe 1500 or 2000 RPM. Listen for a knock. If there's a knock, step on the brake, put it in gear, and apply just a little bit of throttle (just enough that the engine is pushing SLIGHTLY against the brakes). If the noise disappears, it's probably a cracked flex plate.
  4. You probably read that in one of my posts -- that's what I did. Nope. Unless you had a front brake failure and the rear bypass got actuated, that circuit should not be under pressure. There is fluid in that line IF the proper bleeding method was used, so what's in the line will dribble out -- but it won't drain the MC.
  5. Unfortunately, then you're on your own because we can't tell from wherever we sit if the speedo wire was even moved over to your truck. You need to find an XJ or MJ from about the same year, crawl underneath, and find out what color wire you're looking for and where it's supposed to go into the chassis harness.
  6. Which is why there's a knock sensor ...
  7. A 1990 does not have a "Check Engine" light. You have a "Maintenance Required" light, which is just a reminder to replace the oxygen sensor.
  8. You do NOT have to remove it to block the lower front outlet port. Just unscrew the old tubing nut and screw in a plug. Done.
  9. But the XJ proportioning valve is well-known to gradually seize up and leave you with NO rear brakes. That's why a lot of XJers remove the O-ring and spring -- which is just making the proprtioning valve into something that works just like the MJ distributiuon block already works. It makes much more sense (IMHO) to keep the MJ front distribution block. If you find that the rear brakes often lock up prematurely (this has not been a problem for me), you can add a Wilwood adjustable proportioning valve to control that.
  10. But WHICH Monroe shocks did you buy? It isn't fair to compare Monroes cheapest shock with another company's premium, performance shock. FWIW, it was exactly the type of driving you describe that I found the KYBs to be so horrible for -- especially the rears. They were fine over big dips, but over small cracks and ripples in the pavement they were unable to keep up, and the tail end (of a Cherokee, which is heavier than an empty MJ) was getting bounced all over the road. Personally, for your application I'd suggest the Monroe (or Rancho) Reflex shocks, but if you're dead set against Monroe, don't buy 'em on my say-so.
  11. You have an all-electric gauge cluster in an '88 MJ? Was the entire '94 wiring harness swapped in? If not, you have a problem because the '88 originally had a mechanical speedometer with a conventional speedo cable.
  12. I don't think you need a high-altitude CPS in Monteray, CA. But, irrespective, the CPS doesn't control the ignition timing. It sends a signal to the ECU which, in turn, compares the crankshaft position to several other inputs to determine when to fire the plug. Either CPS gives you as much advance as the engine can handle short of getting ping. When the knock sensor detects ping, it retards the timing enough to stop it before you grenade a piston. The high-altitude CPS is offset a couple of degrees so that UNDER LIGHT LOADS you get a couple of degrees more advance, and maybe better gas mileage if you're near sea level. Once you mash the throttle under load, the knock sensor is what's going to limit your timing advance, so I don't think replacing the CPS is likely to fix whatever problem you are experiencing.
  13. Absolutely YES. I would not mix types, brands, or series between front and rear. Shocks do NOT help you carry load. Springs carry weight -- shock absorbers control suspension bounce. If you have a tight budget, go with the Monroe-Matic line (but see if you can find truck shocks with the right dimensions -- they'll have a bigger piston).
  14. Funny. I had KYBs on my Cherokee for about a week -- took 'em off, replaced with Monroe and have never regretted it. You do realize that Monroe and Rancho are the same company (Tenneco), right? If you don't like Monroes (which series?), I doubt you'll like Rancho 5000. They ride pretty harsh. Maybe the 8000 (if they still offer that series)?
  15. Keep in mind the OP does not have a stock height truck. Stock shocks are too short. What you need to do is measure the eye-to-eye distance when the truck is parked on level ground. That's going to be your mid-travel length. If you look at that Monroe link I provided, they give the compressed length and the extended length for each shock. Average the two and that's the mid-travel length for that shock. You want to find a stock number with upper and lower eyes for mounts that has a mid-travel length as close to your truck as you can find. Once you know that, you can pick a Monroe shock if that will work for you, or go to a cross-reference table and find out what vehicle that shock fits. Then look up that vehicle in other shock brands. The SensaTrac is an okay shock, but remember that it uses bypass grooves in the center portion of the shock bore to soften the ride over small bumps. Unless you really get pretty close to a perfect fit, they don't work as intended. And for the rear of a pickup, adding a load may take the shock out of the central zone. For Monroe, I'd go either one line cheaper, or step up to the Reflex series.
  16. "Ah so," said the man who only owns 5-speeds.
  17. Check an Advanced Auto (if you have them in your part of the world) and see what Monroe shocks they have on sale. The Monroe web site has (or used to have) the full catalog online, and in the beck there's a listing of shocks by length and upper and lower mount type, so you can figure out what length you need then look up what shock(s) will fit by part number. http://www.monroe.com/assets/downloads/ ... hSheet.pdf
  18. The NSS is not really part of the transmission. It has nothing to do with making the vehicle run or move. It's the equivalent of the idiot safety switch on the late-model 5-speed XJs that won't let you start the engine unless the clutch pedal is ALL the way to the floor. Until we got my wife's 2000 XJ Classic, I don't think I ever drove an automatic that had a NSS. It's just more nanny state interference. I wouldn't hesitate for a moment to do that "hack" and call it permanent -- except for the "gotcha" about losing the backup lights. I wouldn't mind wiring those to a manual toggle switch on the dashboard, but that's not an option in states that have mandatory safety inspections.
  19. OK not form an XJ. I need to learn to read better... Junior (87 MJ) was a column shift at first. I may still have that cluster in the trailer, and will look for it today after work. He is not looking for a cluster. He is looking for the cable that connects to it.
  20. Unfortunately, most XJs had floor shifters. Finding an XJ with a column shift means finding a fleet vehicle, and those are rare. Someone (Hornbrod, perhaps) some time ago posted a link to an aftermarket PRNDL that mounts right on the steering column. That might be the only solution.
  21. Borrowed from another forum for your viewing ... pleasure?
  22. Yep. If the engine can't get up to an operating temperature of at least 165 to 170 degrees, the ECU will never switch out of "open loop" (or warm-up) mode. That means you will ALWAYS be running based on a hard-coded, overly-rich fuel mixture. Your fuel economy will suck, and you may end up fouling the catalytic converter due to excess unburned hydrocarbons.
  23. Eight, not seven. The MJ never had a 7-slot grille.
