LEAD_NOT_FOLLOW Posted May 9, 2008 Posted May 9, 2008 Since this seams to keep coming up I figured I'd post some pics of a extended cab (with XJ 2 door door's) MJ project that a guy is doing.
jaekl Posted May 9, 2008 Posted May 9, 2008 The vents are in the 2 door jamb. With that size of window he will have alot of space behind the seat. He must like to weld and is good at it. I managed to terminate the roof ribs on my Cherokee when I added a sunroof rather than welding all the way across. It is a solution to the different roof profiles but that is alot of reshaping of the Comanche panel. Nice work, impressive. but where is the floor? Side note on the vents, the Mahindra truckin another post must also be sharing doors from a 4 door vehicle. The doors are a bit shorter than other trucks so a wider B pillar is needed.
TNT Posted May 10, 2008 Posted May 10, 2008 Looks good. Lots of work. Is he building his own frame? Whats the wheelbase going to be? I'm not going as long. That is way long. I'm just adding 2dr doors and the back of another MJ cab. And I will be keeping the MJ vents.
Badger Posted May 10, 2008 Posted May 10, 2008 I never thought of that.I might have to make another round to the junk yard to get the front section of a rear window to help finish the rear window. He has a lot of work on his hand.I see the Cherokee has the whole frame rails as well as the fire wall missing.
Darren Posted May 11, 2008 Posted May 11, 2008 that thing looks pretty long. no floor firewall or "frame" this guy has a lot of work to do.
pingpong Posted May 13, 2008 Posted May 13, 2008 He is going to need a bus license to drive it on the road.. seriously lots of good fab work on it... really inventive
LEAD_NOT_FOLLOW Posted May 13, 2008 Author Posted May 13, 2008 To answer a few questions. He is building a tube frame for it. He is using the Jeep as a drag truck (yes I know...)
Pete M Posted May 13, 2008 Posted May 13, 2008 He is using the Jeep as a drag truck wicked.... :D Know what engine he's looking to run?
jtdesigns Posted May 13, 2008 Posted May 13, 2008 He is using the Jeep as a drag truck wicked.... :D Know what engine he's looking to run? A V8??? :nuts: :D
