  • Replies 897
Is that trail open to the public now?
No, it will be at least a couple more years before it will be open to the public. There is a bridge that needs to be built along the forest service road leading to the trail. There are also at least two more bridges that need to be built on the trail itself.
Willy
Willy - awesome thread, love your build.
Did you ever figure out how to re-install your door locks? I see you bought new ones but didn't say if you got them installed.
Yes, I figured out how to install them.......and already forgot how I did it. I just looked back through my pictures. The new locks did not require removal of the c-clip. They already came with the bracket installed. All I had to do was pop off the actuator rod and attach it to the new lock.
I do remember that the new lock comes with a much thicker gasket. This required substantial compression in order to get the retainer clip to slide on. I ended up using a 2x4 and clamp to compress the gasket.
Willy
curious as to why you don't put the camper on the truck and the mj on a car trailer? easy detachment to drive somewhere? isnt the mj street legal though?
Been there, done that. Loading and unloading the camper is a pain in the @$$.
I can unhook the gooseneck and be on my way within minutes.
Yes, the MJ is street legal, but the Dodge is much nicer to drive for any extended road mileage.
Willy
i want to do the same setup. plus you have a nice deck/porch area when you walk out instead of a tailgate.
This too. The deck makes a nice place to congregate when the MJ is unloaded.
For a long time I've had on my list to add some type of canopy to cover the deck. Especially when it is raining it would be nice to have a place to kick off your boots before tracking a bunch of mud into the camper.
Willy
  • 3 weeks later...
Willy
I want to work there!!!
  • 1 month later...
Which model front axle truss did you purchase? I'm narrowing a Ford hp44 to Waggy width.
It is a T&T Customs truss.
Make sure you do your research before narrowing the tubes. If you narrow a Ford HP44 to use Wagoneer inner shafts it won't leave you enough room for a coil bucket on the driver side.
Willy
Willy
But using TJ inners will allow enough room? I knew it was T&T, just didn't know which model T&T truss it was.
  • 3 weeks later...
