JeepcoMJ Posted January 21, 2008 Share Posted January 21, 2008 I'm gonna be making a few cowl hoods here soon, using 2 hoods to make one (only 1 seam to weld), and want to know what the typical cowl height is. I'm not too sure how high I want to go for the 3800. TNT, Beaterjeep, and Geonovast will each be recieving a cowl induction hood from me, and the hood height is their choice. I just don't know what I want yet. so, since I like just the typical height, can someone tell me how high their cowl is from the "stock" part of the hood? thanks -Pat Link to comment Share on other sites More sharing options...
Geonovast Posted January 21, 2008 Share Posted January 21, 2008 Link to comment Share on other sites More sharing options...
mfpdm Posted January 21, 2008 Share Posted January 21, 2008 My reflexion is 2 inches. Which looks the same as what was previously posted by Geonovast. I know that each state has different restrictions on how high a cowl hood can be. I think VA is 4 or 6 inches. Can remember which. :cheers: Link to comment Share on other sites More sharing options...
Geonovast Posted January 21, 2008 Share Posted January 21, 2008 WI is pretty lienient about what people can do to their vehicles...I believe when it comes to lift laws WI is one of the least restrictive. They probably don't care about cowls as long as you can see. Most of the cops here probably don't know what a cowled hood is anyway... Link to comment Share on other sites More sharing options...
FxRacing282 Posted January 21, 2008 Share Posted January 21, 2008 up here if you have a cowl hood its usually 3'' or better. most people run 4''-5'' on there street/strip cars Link to comment Share on other sites More sharing options...
TNT Posted January 21, 2008 Share Posted January 21, 2008 In WI 3" high hood scoop is the max legal height. About 2.5" would be perfect for me. As for lift 5" is maximum. The tires can have a raduis that is 4" larger then stock. Max bumper height is 30". Link to comment Share on other sites More sharing options...
FxRacing282 Posted January 21, 2008 Share Posted January 21, 2008 In WI 3" high hood scoop is the max legal height. About 2.5" would be perfect for me. As for lift 5" is maximum. The tires can have a raduis that is 4" larger then stock. Max bumper height is 30". GAYYYYYYYYYYYYY Link to comment Share on other sites More sharing options...
TNT Posted January 21, 2008 Share Posted January 21, 2008 In WI 3" high hood scoop is the max legal height. About 2.5" would be perfect for me. As for lift 5" is maximum. The tires can have a raduis that is 4" larger then stock. Max bumper height is 30". GAYYYYYYYYYYYYY How ghey is it.... I can run 5" of lift and fit 35" boggers and still be legal no problem... I guess that must be ghey to run a set-up like that..... Link to comment Share on other sites More sharing options...
89eliminator Posted January 21, 2008 Share Posted January 21, 2008 those may be the WI laws, but they don't enforce them. Link to comment Share on other sites More sharing options...
FxRacing282 Posted January 21, 2008 Share Posted January 21, 2008 In WI 3" high hood scoop is the max legal height. About 2.5" would be perfect for me. As for lift 5" is maximum. The tires can have a raduis that is 4" larger then stock. Max bumper height is 30". GAYYYYYYYYYYYYY How ghey is it.... I can run 5" of lift and fit 35" boggers and still be legal no problem... I guess that must be ghey to run a set-up like that..... not legally you can't, mj's didnt come with 31's. up here you can find t100's with 2' lift kits, (no joke i saw one two weeks ago at napa) Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 21, 2008 Author Share Posted January 21, 2008 tire size doesn't count for lift. well, not legally. and I don't see lift height enforced in wisconsin at all. as for cowl, I'm settled on 2.5" for me. apparently TNT wants that, correy's pretty good with that too. sounds good :D Link to comment Share on other sites More sharing options...
TNT Posted January 21, 2008 Share Posted January 21, 2008 In WI 3" high hood scoop is the max legal height. About 2.5" would be perfect for me. As for lift 5" is maximum. The tires can have a raduis that is 4" larger then stock. Max bumper height is 30". GAYYYYYYYYYYYYY How ghey is it.... I can run 5" of lift and fit 35" boggers and still be legal no problem... I guess that must be ghey to run a set-up like that..... not legally you can't, mj's didnt come with 31's. up here you can find t100's with 2' lift kits, (no joke i saw one two weeks ago at napa) 4" in radius, equals 8" in diameter.... so I can run a 35" tire legally. :brows: Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 21, 2008 Share Posted January 21, 2008 as for cowl, I'm settled on 2.5" for me. apparently TNT wants that, correy's pretty good with that too. sounds good :D Here's a pic of a fiberglass XJ/MJ hood w. a 2-1/2" cowl (according to the mfg.). Looks a bit high to me - I like the Reflexxion 2" cowl hood better. Image Not Found Link to comment Share on other sites More sharing options...
Blue XJ Posted January 21, 2008 Share Posted January 21, 2008 I made one out of a spare hood I had lying around 3 or 4 years ago. Its just about 3" if I remember correctly. Image Not Found Link to comment Share on other sites More sharing options...
Confedneck Posted January 22, 2008 Share Posted January 22, 2008 i think it'd look best with a stock hood with a reflexxion style cowl at 1.5" and maybe 2" wider... just my $.02 and not like i am able to do it anyways lol Link to comment Share on other sites More sharing options...
ScottJ Posted January 23, 2008 Share Posted January 23, 2008 Since swapping out my stock carb/intake manifold for a Holley/Edelbrock combo I have no room under stock hood for air cleaner. I cut out a section of the hood and fabricated a pretty crappy "bulge" but still looking for a permanent solution. Are these cowlings just for looks (tacked onto the top of a stock hood) or do they create addtl clearance? JeepCo: How much do you think you'll be charging? Geonovast & mfpdm & all: Where did you get those hoods? Any suggestions? I google and don't find what I'm looking for. Thanks! Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 24, 2008 Author Share Posted January 24, 2008 shipping from me would kill you, as it's not a business. the people I'm doing it for are local, and are all supplying the parts plus some time in making it, so I have no problem doing it that way. umm...so, I don't know what I'd charge. geonovast doesn't have one, that's just an example. maybe someone will chime in with the site to get them from, but I think they run about $300. if you had 2 hoods and some time, you can make one yourself (like I'm doing) Link to comment Share on other sites More sharing options...
ScottJ Posted January 24, 2008 Share Posted January 24, 2008 shipping from me would kill you, as it's not a business. the people I'm doing it for are local, and are all supplying the parts plus some time in making it, so I have no problem doing it that way. umm...so, I don't know what I'd charge. geonovast doesn't have one, that's just an example. maybe someone will chime in with the site to get them from, but I think they run about $300. if you had 2 hoods and some time, you can make one yourself (like I'm doing) Ah well, worth a try. I just learned that I have no biz trying my hand at body work. My fab'd hood thingie looks like an upturned baking pan. So if anyone knows where those examples came from... a website would be sure helpful. Someday I'll get off my arse and post a picture or two... I dig my truck and spend too much $ on it. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 24, 2008 Author Share Posted January 24, 2008 Ah well, worth a try. I just learned that I have no biz trying my hand at body work. My fab'd hood thingie looks like an upturned baking pan. So if anyone knows where those examples came from... a website would be sure helpful. Someday I'll get off my arse and post a picture or two... I dig my truck and spend too much $ on it. well, I could build the cowl part for you and leave enough edge that you could rivet it on, or you can try to tac-weld it in, then do some grinding and smoothing. THAT anyone can do. all I'm doing is rollin gthe corners out and setting height. idk what price would be, $65 plus shipping or so? it'd be less than $25 to ship I'm sure Link to comment Share on other sites More sharing options...
mfpdm Posted January 24, 2008 Share Posted January 24, 2008 Since swapping out my stock carb/intake manifold for a Holley/Edelbrock combo I have no room under stock hood for air cleaner. I cut out a section of the hood and fabricated a pretty crappy "bulge" but still looking for a permanent solution. Are these cowlings just for looks (tacked onto the top of a stock hood) or do they create addtl clearance? JeepCo: How much do you think you'll be charging? Geonovast & mfpdm & all: Where did you get those hoods? Any suggestions? I google and don't find what I'm looking for. Thanks! I picked mine up off Craigslist, however Quadratec has them(LINK) and if you google Reflexion cowl hood you'll find several site's that carry them. I went with this hood because it is all steel. I had planned to shell out the cash for it from a site, but got real lucky with the craigslist find ($150) and a friend that happen to be going up to Washington DC anyways to pick it up for me.($40):D Oh, it does provide more clearance too. :cheers: Link to comment Share on other sites More sharing options...
ScottJ Posted January 24, 2008 Share Posted January 24, 2008 well, I could build the cowl part for you and leave enough edge that you could rivet it on, or you can try to tac-weld it in, then do some grinding and smoothing. THAT anyone can do. all I'm doing is rollin gthe corners out and setting height. idk what price would be, $65 plus shipping or so? it'd be less than $25 to ship I'm sure Thanks for the offer amigo. Maybe you could build one of those others and post a pic so I could see? I like the idea of saying "Yeah, I got it from this guy in Wisconsin who custom-built it for me" rather than "Yeah, I plunked down a butt load of cash..." And while I really like the look of that reflexxion hood mfpdm posted... thanks for the link by the way... the cheapest I could find was about $400. Your $65+shipping would be a great deal. I want to respect your time, though. Are you sure that'd be enough to comp ya? Oh, and to answer your original question, I'd want to keep mine no more than 2" off the stock lid. The 'manche hood is stubby and I think a taller cowl would look funny. My opinion. Scott Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 25, 2008 Author Share Posted January 25, 2008 Thanks for the offer amigo. Maybe you could build one of those others and post a pic so I could see? I like the idea of saying "Yeah, I got it from this guy in Wisconsin who custom-built it for me" rather than "Yeah, I plunked down a butt load of cash..." And while I really like the look of that reflexxion hood mfpdm posted... thanks for the link by the way... the cheapest I could find was about $400. Your $65+shipping would be a great deal. I want to respect your time, though. Are you sure that'd be enough to comp ya? Oh, and to answer your original question, I'd want to keep mine no more than 2" off the stock lid. The 'manche hood is stubby and I think a taller cowl would look funny. My opinion. Scott I think once I do a couple cowls (I'll be building a jig for it and simply bendingthe edges), it shouldn't cost me much time to make them. just to be clear, I could do just the cowl for that. a complete hood I'd want between $150 and $200 for it depending on time involved in it. -Pat Link to comment Share on other sites More sharing options...
jtdesigns Posted January 25, 2008 Share Posted January 25, 2008 Ah well, worth a try. I just learned that I have no biz trying my hand at body work. My fab'd hood thingie looks like an upturned baking pan. So if anyone knows where those examples came from... a website would be sure helpful. Someday I'll get off my arse and post a picture or two... I dig my truck and spend too much $ on it. well, I could build the cowl part for you and leave enough edge that you could rivet it on, or you can try to tac-weld it in, then do some grinding and smoothing. THAT anyone can do. all I'm doing is rollin gthe corners out and setting height. idk what price would be, $65 plus shipping or so? it'd be less than $25 to ship I'm sure Hey Jeepco you could cut the hole bigger and then tac the edge on the under side of the hood. Tac welds and some high strength glue should hold it up pretty good.. Link to comment Share on other sites More sharing options...
minydigger Posted January 25, 2008 Share Posted January 25, 2008 Kinda off topic but does anyone make Blanks to shave the tail lights and maybe a rear roll pan?? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 25, 2008 Author Share Posted January 25, 2008 Kinda off topic but does anyone make Blanks to shave the tail lights and maybe a rear roll pan?? i have no idea. Link to comment Share on other sites More sharing options...
