truck twitches to the left under heavy braking
under sudden hard braking the truck twitches to the left slightly and the right side of the front dips lower than the left.  is this a symptom of bump steer due to the track bar relocation bracket that came with the lift kit?
any other thoughts as to why this might be happening?
oh, they are definitely not lined up like factory.  the bracket drops the axle end of the bar a bit in order to also scoot it over towards the drivers side to compensate for the need of a longer track bar.  I originally thought my front brakes weren't braking the same left to right, but then this popped into my head.  but I don't remember anyone complaining of this before.  :dunno:
the upper left bolt is the original hole for the track bar.
3 hours ago, watchamakalit said:
I ran on 3" of lift with a stock track bar and mount location with no drivability issues. I'm curious why your running the relocation bracket?
came with the kit.  :dunno:  the worst part is that the axle is still not quite perfectly centered.  :doh:
Relocation kit perhaps if your trac bar hole is oblonged, otherwise Id stick to factory location with 3in lift. Double measure tac bar compare to draglink for same length. Trac bar sould only need to be about 1" longer then factory if that. I wanna say i was around 3/4" when did my 3" kit.
:yeahthat:
If it’s a true 3” lift then it’s about 3/4” that the track bar moves. Adjustable track bar solves this issue as you can tune it in. I’m not sure the reason behind the drop brackets though with a 3” lift. Some adjustable lowers and stock uppers is all that’s needed with that lift height to set your caster properly.
I pulled the bracket.  ran out of daylight to do a proper high speed test drive, but around the block seems to be normal again.  we shall see what tomorrow brings.
it's a skyjacker 3" lift with coils, lower arms, and this bracket.  looks to be this one:  https://www.amazon.com/Skyjacker-JC301K-Lift-Components-Suspension/dp/B000JKM87E
I bought it for like 50 bucks at the junkyard, so I think I did alright. :D
no real change.  :(  doesn't happen every time, but from 55mph under heavy braking it still pulls left slightly.  I may try swapping pads side to side to see if anything happens.  pads and rotors are brand new, so there's no wear pattern yet.  maybe tires too?
  • Pete M changed the title to truck twitches to the left under heavy braking
18 hours ago, MiNi Beast said:
Sure its not a sticking caliber? :dunno:
This, it sounds exactly like the symptom of a sticking caliper to me.  Two things you can check are, is the break pedal firmer than normal and is one of the two front brakes much hotter than the other after driving it for a few minutes?
well, we're going to hope that some light daily driving will free it up. :dunno:  if not, I'll swap the calipers later.  I handed the truck over to the owner today.  bitter sweet, but it's not like the project is over. lol.  Jeeps are never finished. :D  (stereo and 4wd swap coming next, but not for a bit)
