Everything posted by JeffK
Hayden, the lights we were talking about are on page 10 near the bottom.
We'll do that
Looks good.
Started mocking up the front brakes today, the write ups I've read they've had to remove 1/16 to 1/8 of material off either the hub or the rotor center. I literally sanded of the coating on the rotor center and they slid on. Drilled out the mounting ears and chased the ball joint sleeve threads, which went surprisingly well. I started assembly of the knuckles and realized the caliper bolts I have are too short. The bolts needed are M14 - 1.5 x 70mm, I ordered them online because I couldn't find any flange hex bolts that size locally.
Finish coat on the knuckles. I still need to drill out the mounting holes for the caliper bracket and chase the threads for the ball joint sleeve. I did a parts inventory and I'm going to start mocking up the brakes later this week. Rotor size comparison vs one of my spare TJ rotors.
I clean everything with CRC Brakleen before I paint. Best de-greaser out there.
I was able to remove the lower BJ sleeves this afternoon. I'd been soaking them in PB Blaster for the past couple of days. then this afternoon I put some heat and few adult adjectives on them and they came out fairly easy.
I spent part of this week doing some spring cleaning on the TJ, and started working on my knuckles for my brake upgrade.
truck twitches to the left under heavy braking
JeffK replied to Pete M's topic in MJ Tech: Modification and Repairs
My TJ was doing this and progressively got worse. I changed out both front calipers and rubber lines and it stopped. -
I was wondering about the CA length, that's good info. Thanks. Approx what length are you running the upper CAs? I'd like the to end up with the caster angle toward the high side of the stock specs.
Got my new tires mounted today, saved almost $60 a tire buying them from Tire Rack vs locally. I think they look pretty good on the JL wheels. Compared to the worn 33s on my TJ.
I'm still waiting on a few more parts to come in. I did finish painting what has come in. Final box from CavFab showed up with my track bar. Very impressive part.
Hood Prop Clip 34202710/ 55027404
JeffK replied to Gojira94's topic in MJ Tech: Modification and Repairs
I agree the Wilwood kit is the simplest solution. I don't mind saving a little money though, corrosion resistant rotors, new calipers and other needed parts for the DIY 13.25" rotor kit was less than $500.
Nice, thanks.
I looked into some of the DIY kits as well, I found this parts list on another jeep forum- -Early '84-'89 knuckles with the lugs for the caliper to bolt on (not the late '90+ knuckles with the brake pad 'wings') -Mustang GT '11-'14 Rotors 13.25" Centric 120.61098 -Calipers dual piston '11-'15 Durango or GC for 350mm rotors Centric 141.58011/12 -Pads semi-metalic Centric 30014550 -14mm grade 8 caliper bolts and washers -14mm drill bit to drill out the knuckle caliper mounting lug hole -Spacer machined steel- 1" thick, 1.375" diameter and 9/16" hole No pics with the post though, I assume the spacers are for mounting the calipers(?) Do you know of another kit that maintains the stock steering?
Thanks for clarifying that. I was looking at bigger brakes, Wilwood seems to be the simplest to install, but even if you opt for their solid rotors that kit is still almost $1100. https://www.summitracing.com/parts/wil-140-12576-r
From 84-90 is there any difference in the steering knuckles? i.e. caliper brackets/mounting? Thanks.
