1990 shortbed with 2000 swap
After many XJ's I finally found an MJ. So I popped the trailer on behind the diesel and headed down to Arkansas to pick it up. Per the vin It was a 2wd 4 cylinder manual truck. One of the previous owners had already swapped in a 8.25 in place of the broken D35. In the bed was a 140k 4.0l and underneath was a LP and a HP D30.
  • Replies 55
  • 3 weeks later...
  • 1 month later...
Thanks for the complement's gents!
Pulled the bed off and started stripping the paint. Laid primer the underside, then after that had cured did the top side.
Now on to some fab work. I want to retain as much of the donor Jeep as possible, So the spare tire carrier was deleted and the XJ fuel tank was mounted in its place. It really mounted up well with enough clearance for everything.
Looking like glass! Gosh I want to do this to mine if only I could find the time :rolleyes:
On 9/15/2024 at 11:00 AM, grainofsalt said:
Needed to open up some floor space in the shop so bolted the drivetrain together and tucked it into the truck.
Then popped open the tailgate to straighten it and give it some beef.
This looks mighty familiar :L:. As for the gas tank, could you take a few more pics of how that mounted up for you? Interested in doing something similar if I decide to 4 link down the road
A-man930, The tailgate work it totally worth it! This truck had a banana bend in the tailgate, Now you can't notice it flexing with some weight.
Primed up another round of truck parts and then started body filler and fitting the notch customs flares.
ghetdjc320, I'll snap a picture for you, Basically just have the j-bolts running up to the cross member. Kept it super simple.
Did relocate the brake line location to make the new fuel fill hose work. I didn't relocate the fuel door.
Oh boy, could you also shoot some detailed pics of the cuts you’re making for the rear notch fenders? It has been very difficult to find any decent pictures.
Here's a shot of how I did the J-Bolts. I probably would have been fine cutting a v in the plate, But went and made the mounting hole similar to the Cherokee mounting hole.
There also is drain locations, Didn't want to trap water in there.
  • 3 weeks later...
On 11/6/2024 at 6:33 PM, ghetdjc320 said:
Any chance you could get a few detailed shots of the bedside wheel opening cuts you made for the Notch flares?
I guess I got into the flow of working and don't have any closeup pictures. It's fairly obvious once you hold the flare up to the bed. These are about as high as you can mount them.
