Thanks Pete (cruiser54), we are eternally grateful for your tips and helpfulness. Your contributions to our community are immeasurable and will continue to help us keep our RENIX MJs/XJs running. As a tribute we are archiving these tips here on ComancheClub.
April 30, 1954 - May 16, 2024 RIP
Screenshot 2024-05-24 at 05-18-18 664fa99e76907.webp (WEBP Image 400 × 245 pixels).png
https://comancheclub.com/topic/73455-we-lost-a-member/
Cruiser’s Mostly Renix Tips
Technical DIY instructions covering common issues on the Renix XJ Cherokees and MJ Comanches (1987-1990). Preventative and proactive procedures to save you headaches, time, and money.
Many of these tips were provided to me and my buddy Joe by JeepTech when I was Service Manager/Shop Foreman at a Jeep dealer from 1980 through 1992. That’s what “The Book” is all about. Our notes from back in the day. Right from the Field Service engineers. Thanks Lonnie and Big Al!!  Most were never published, until now.
Tips 1, 2, 3, 4 and 5 are a great place to begin before chasing your tail with parts replacements on your 87 and 88 Jeeps.  These are pretty much “haftas” in Renix Jeep ownership. You can skip Tip 2 if you have an 89 or 90. But, do the Tips first……….Avoid firing the “parts cannon” at your Jeep!!!!!!!
The next priorities on your Renix Jeep are Tips 11, 13, 31, 25 and 26
A simple multimeter is handy along with a few other basic tools……so dive in and get to know your Renix Jeep.
Some Tips also transfer to later years, or the techniques can be adapted.
If you have a 91 or later, see Tips 1, 3, 10, 11, 12, 15, 16, 18, 19, 20, 24, 29, 30 and 36.
If you have an 84 through 86, see Tips 3, 12, 15, 16, 18, 19, 20, 28 and 30.
1 – Ground refreshing and Upgrades
2 – C101 connector refreshing
3 – Connector and relay/receptacle refreshing
4 – Coil/ICM contacts
5 – Checking sensor grounds
6 – Sensor ground upgrade
7 – CPS testing and adjusting
8 – TPS testing and adjusting
9 – ECU connector refreshing
10 – Trans plug connector refreshing
11 – Throttle body and IAC cleaning
12 – Setting your 4.0 to #1 TDC
13 – Renix Distributor indexing
14 – Restoring Throttle Butterfly Adjustment
15 – Rear main seal diagnosis
16 – Vacuum test for exhaust restriction
17 – HO engine into Renix
18 – Improving the instrument panel ground
19 – Headlight harness installation
20 – 4WD shifting tips
21 – Renix EGR valve test
22 – Renix vacuum harnesses
23 – CPS timing advance mod
24 – 4.0 Engine date codes
25 – Valve cover mod
26 – Oil Filler cap Mod
27 – C101 Connector Elimination
28-Improving blower motor performance
29-Improving the fuel pump ground
30-Adding the Sentinel Headlamp feature
31-Throttle body to MAP hose upgrade
32-Renix metric oil filter to SAE filter
33-Converting to an open cooling system
34-Eliminating the Heater Control Valve
35-Reducing cabin wind noise
36-Bypassing the Power/Comfort switch
37-Best injectors for Renix
38-Improving the wiper motor ground
39-4.0 Engine Removal
40-More power for your 87 and 88 4.0 ***VIDEO***
41- Easily track down and repair  ENGINE VACUUM LEAKS
HELPFUL LINKS. TAKE A LOOK!! DON’T MISS THESE.
Guides
Resources
Products
Cruiser54's WEBSITE DEDICATION
"This website would never have been possible without the decades long work and support of my “little brother”, co-worker, and dear friend Joe Soriano.
As I write this dedication to Joe on Thanksgiving, it seems quite appropriate.
Thank you Joe for many things, all larger than this website. A true friend and comrade in buffoonery forever.
For those of you who didn’t know Joe, you need to be aware that we worked together at a Jeep dealership from before the inception of the Jeep XJ. 1980 to be exact. Side by side, with the help of our friends at JeepTech, we embraced the XJ and MJ. We both kept the special tips and info in “the book” featured here.
After working together for 12 years, I left the dealership and went on to other things. Joe kept “the book” and worked for the dealership a total of 37 years. In 2010 Joe presented “the book” to me. All those notes in both of our handwriting, outlining neat fixes.
So, that is the true heritage of this site.
Sadly, Joe passed away unexpectedly on November 13, 2016.
I wish to dedicate this site to Joe."
  • Pete M pinned this topic
Fiat, I did a little helping for the missing ones. I used the way back machine to see when he added those tips. It looks like he added them but never implemented them to his website. Cruiser probably had intentions say as a a video for those ones that don’t have a true link.
Sad to read of Cruiser's passing. He was a great help to me when I first got my 86 MJ a few years ago.
I bought my Comanche with a known no-start issue that the past owner never bothered to fix. Cruiser gave me the drive to tackle this project head-on with zero experience working on vehicles.
These days, my truck runs quite well thanks to the time, effort, and dedication that probably no mechanic would methodically do as I have.
  • 6 months later...
  • 3 months later...
I was just thinking about Cruiser today and wanted to check in to see if his stuff ever made it over here. I'm glad to see y'all got it on the site. Pete will be missed!
Weather is getting nicer in NorCal and I'm feeling the itch to tackle a big project this spring/summer. So grateful for CC and folks like Pete.
