Eagle_SX4 Posted July 7, 2023 Share Posted July 7, 2023 (edited) So I need to replace the Delhi fuel pump I have in my Eagle. (XJ tank swap with 92 High Output 4.0 fuel injection) I have only put 500 miles on it and it is on its way out. It is super loud (you can hear it standing 20 feet away) and overheated once already almost leaving me stuck on the side of the road. My question is which fuel pump to get, the Bosch 69302 or the Mopar 68001826AA. It looks like I can get either one just wondering which one would be better? Edited July 7, 2023 by Eagle_SX4 Fixed the Bosch # Link to comment Share on other sites More sharing options...
eaglescout526 Posted July 8, 2023 Share Posted July 8, 2023 Mopar number is discontinued but at vintage. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted August 4, 2023 Author Share Posted August 4, 2023 Well I ordered a Mopar fuel pump from Amazon but returned it because I couldn't find a sock or the proper connector for it. I can't find the Bosch pump in stock any where. I also have seen in pictures that it will also require a special plug and sock that I can't find any where. Any help would be much appreciated. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted August 4, 2023 Author Share Posted August 4, 2023 I just got a fuel pump and hanger assembly from the parts store. It has a lifetime warranty so I shouldn't have to buy one again but time will tell how often I have to change it. Link to comment Share on other sites More sharing options...
gogmorgo Posted August 6, 2023 Share Posted August 6, 2023 Fuel pump and hangar assembly from the parts store is probably an XJ unit. They're not quite right in an MJ tank. With a little creativity you should be able to rob the parts off it to move over to your sending unit, but there goes the lifetime warranty. Currently MTS is the only manufacturer we're aware of making proper sending units to fit the Renix MJ, there's been talk about it but I haven't seen an HO version released to the general public yet. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 6, 2023 Share Posted August 6, 2023 MTS has the HO sending unit available but the OP has an XJ tank from what I can see. The Bosch bump was a turbine pump and a very good unit but as you mentioned, almost impossible to find. It’s the adapter that came in that kit that I haven’t been able to locate anywhere. That being said, both myself and @Limeyjeeper have installed a deatshwerks DW200 pump on an MJ sending unit. It does require some engineering but works well. The airtex/precision pump from the parts store is hit and miss but use a cane style pump iirc. The Bosch and most other newer pump designs are a turbine design. Smaller, more efficient and quieter. Link to comment Share on other sites More sharing options...
gogmorgo Posted August 6, 2023 Share Posted August 6, 2023 Missed that. Yeah an XJ sending unit should definitely fit an XJ tank. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted August 7, 2023 Author Share Posted August 7, 2023 Thanks for the replies. If I have have to change the parts store pump frequently I will probably switch to the DW200 pump. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 8, 2023 Share Posted August 8, 2023 20 hours ago, Eagle_SX4 said: Thanks for the replies. If I have have to change the parts store pump frequently I will probably switch to the DW200 pump. Just keep the warranty info. Mine lasted about a year of daily driving but was warrantied out for free. Pump swaps really are quite simple on our trucks Link to comment Share on other sites More sharing options...
cruiser54 Posted August 8, 2023 Share Posted August 8, 2023 Ever consider going to the Walbro or Bosch website and looking around? Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted August 8, 2023 Author Share Posted August 8, 2023 I have thought about it but I don't know what I am looking for. Does any one know the pressure and flow rates of a stock pump are? Link to comment Share on other sites More sharing options...
cruiser54 Posted August 8, 2023 Share Posted August 8, 2023 https://walbrofuelpumps.com/jeep-cherokee-1989-1990-fuel-pump-6-cyl-4-0l.html Link to comment Share on other sites More sharing options...
Gojira94 Posted August 8, 2023 Share Posted August 8, 2023 The OE part number for all 4.0 applications for MJ and XJ from 87-93 is 4637192. The body of this pump is longer than most of the aftermarket offerings, including the Bosch 69302, Delphi FE0108 and the Walbro 5CA234 noted above. These shorter pumps seem to be turbine pumps, where as the longer ones like OE and the Carter P90011 are likely roller vane (louder, less efficient). The longer ones (about 170mm) are easier to fit but likely have somewhat shorter service life inherent in the design, while the shorter ones (about 135mm) require some cobbling but likely quieter and last longer. IMHO the cobbling required to use the turbine design is worth it, though you need to make sure the end result has the inlet of the pump at the same position as it would be with an older, longer roller vane design for proper fuel draw from the tank. The most important and most often left out spec for a pump is free flow volume in gal/hr or lph. A lot just throw out a pressure spec, but don't say what the regulation method is, or what volume of flow was required to hit that advertised pressure. Pressure is resistance to flow. You can make high pressure with low flow if you restrict the return enough but the delivery rate at low flow won't meet the demand from the rail/ injectors. Too much free flow rate and you have a hard time regulating it to a usable pressure without putting a lot of strain on the pump. From what I've seen looking at a lot of pumps offered for 4.0 applications prior to the change to 49psi at the rail, the required free flow rate to efficiently make 31-39psi is somewhere between 25-45gph (94-170lph). Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 9, 2023 Share Posted August 9, 2023 18 hours ago, Gojira94 said: The OE part number for all 4.0 applications for MJ and XJ from 87-93 is 4637192. The body of this pump is longer than most of the aftermarket offerings, including the Bosch 69302, Delphi FE0108 and the Walbro 5CA234 noted above. These shorter pumps seem to be turbine pumps, where as the longer ones like OE and the Carter P90011 are likely roller vane (louder, less efficient). The longer ones (about 170mm) are easier to fit but likely have somewhat shorter service life inherent in the design, while the shorter ones (about 135mm) require some cobbling but likely quieter and last longer. IMHO the cobbling required to use the turbine design is worth it, though you need to make sure the end result has the inlet of the pump at the same position as it would be with an older, longer roller vane design for proper fuel draw from the tank. The most important and most often left out spec for a pump is free flow volume in gal/hr or lph. A lot just throw out a pressure spec, but don't say what the regulation method is, or what volume of flow was required to hit that advertised pressure. Pressure is resistance to flow. You can make high pressure with low flow if you restrict the return enough but the delivery rate at low flow won't meet the demand from the rail/ injectors. Too much free flow rate and you have a hard time regulating it to a usable pressure without putting a lot of strain on the pump. From what I've seen looking at a lot of pumps offered for 4.0 applications prior to the change to 49psi at the rail, the required free flow rate to efficiently make 31-39psi is somewhere between 25-45gph (94-170lph). I agree, swapping to a turbine style pump is worth it. The Bosch kit had a nice little adapter for it. Some of the pumps will lost both a free flow and a flow at given pressure in their specs. I personally went with the dw200 because of my engine swap. But I think I’d probably do it again even with a stock rig (though maybe a lower flowing unit depending on needs of the engine) Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted March 6, 2024 Author Share Posted March 6, 2024 Doing some more research on this topic. I found out Jeep started using turbine style pumps for the Cherokees in 94. I was planning on buying a sending unit assembly for the 94-95 Cherokee as it has the turbine style pump and most importantly there would be no modifications necessary. I can't find one for sale anywhere. MTS only makes ones up to 93 but not the 94-95 one. Other than Junkyards does anyone know of a source for this hanger? The 94-95 Bosch pumps (#69544) seem to be available and spec'd for the 4.0 high output. Also a much better replacement than the roller vane pumps. The YJ wrangler used this pump from 91-95 for both the 2.5 and 4.0 liters. The Cherokees only used it from 94-early 96 before they switched to plastic tanks. Crown Automotive makes one for the 96 Cherokee. Part# 5003869AA. The problem with that one is it has an integrated Fuel Pressure Regulator and a different plug. This is a picture of the Crown part Link to comment Share on other sites More sharing options...
gogmorgo Posted March 6, 2024 Share Posted March 6, 2024 18 minutes ago, Eagle_SX4 said: I was planning on buying a sending unit assembly for the 94-95 Cherokee as it has the turbine style pump and most importantly there would be no modifications necessary. Just to be clear the XJ sending unit is not a drop-in replacement for the MJ unit. They might sorta work in some circumstances but as a rule they do need modification. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted March 6, 2024 Author Share Posted March 6, 2024 This would be going in my Eagle which has an XJ tank in it. (see first post) Link to comment Share on other sites More sharing options...
ghetdjc320 Posted March 8, 2024 Share Posted March 8, 2024 Many different turbine pumps can be adapted with minimal mods to the stock fuels sender. I’m running a deatschwerks dw200 pump on mine. Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted April 11, 2024 Author Share Posted April 11, 2024 I could not stand the sound of the rotary vane pump any more so I got a Deatschwerks DW200 pump. I was lucky enough to find a '94 Cherokee in the local junkyard that still had its sending unit assembly. The DW200 replaced the stock turbine pump with no modifications. (Didn't check the fuel pump connector yet but the new pump came with a new one). This will be going in my Eagle with a Cherokee tank.It also has a rubber isolator for the pump to sit on. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 11, 2024 Share Posted April 11, 2024 1 hour ago, Eagle_SX4 said: I could not stand the sound of the rotary vane pump any more so I got a Deatschwerks DW200 pump. I was lucky enough to find a '94 Cherokee in the local junkyard that still had its sending unit assembly. The DW200 replaced the stock turbine pump with no modifications. (Didn't check the fuel pump connector yet but the new pump came with a new one). This will be going in my Eagle with a Cherokee tank.It also has a rubber isolator for the pump to sit on. Looks good! That must have been a later model gen 1 Cherokee with the turbine pump. MJ senders require a bit more modding. Those pumps are awesome btw. I run them on offshore jet skis as well with zero failures Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted May 18, 2024 Author Share Posted May 18, 2024 Got the fuel pump swapped out yesterday. I am amazed at how much quieter it is. The car runs great. Still need to sort out the sending unit as the Eagle gauge has a different ohm reading than the Cherokee. But it still reads the right direction. Half tank in the gauge is actually empty. Link to comment Share on other sites More sharing options...
Skylynx Posted Wednesday at 09:13 PM Share Posted Wednesday at 09:13 PM On 4/10/2024 at 9:25 PM, ghetdjc320 said: Looks good! That must have been a later model gen 1 Cherokee with the turbine pump. MJ senders require a bit more modding. Those pumps are awesome btw. I run them on offshore jet skis as well with zero failures Heyo! I’m looking to do this upgrade in my MJ as well but i was wondering if you could elaborate on what kind of mods i’ll have to do to the carrier to accept the DW200 pump? I have an otherwise stock setup for a renix 4.0 aside from the 4 hole bosch injectors that cruiser recommended in his page. Thanks for the time <3 Link to comment Share on other sites More sharing options...
ghetdjc320 Posted Wednesday at 10:49 PM Share Posted Wednesday at 10:49 PM 1 hour ago, Skylynx said: Heyo! I’m looking to do this upgrade in my MJ as well but i was wondering if you could elaborate on what kind of mods i’ll have to do to the carrier to accept the DW200 pump? I have an otherwise stock setup for a renix 4.0 aside from the 4 hole bosch injectors that cruiser recommended in his page. Thanks for the time <3 Let me see if I can dig up some pictures of my install. It’s noteworthy though that the later model bosch turbine pump kit has been popping up a lot for sale recently. That’s a drop in replacement style turbine pump that doesn’t require mods. found it: post 15 and 17 of this page: Link to comment Share on other sites More sharing options...
Eagle_SX4 Posted Wednesday at 11:11 PM Author Share Posted Wednesday at 11:11 PM I also recommend the Bosch 69302 pump kit it comes with all the adapters you will need to install the new style pump in the older sending unit. I just put one in my truck 3 months ago The only issue will be finding one. I was able to find one on eBay for about $50. If you can't find one you could also make new brackets and solder/braze them on to the existing hanger. Link to comment Share on other sites More sharing options...
