SuperWade2 Posted December 16, 2007 Share Posted December 16, 2007 Are the clusters interchangeable (as far as the wiring and connections and stuff), and/or "year specific"... would and 86 cluster work on an 89? Such as ;http://cgi.ebay.com/ebaymotors/1986-Jeep-Comanche-Cherokee-Instrument-Cluster-w-Tach_W0QQitemZ270195183973QQihZ017QQcategoryZ33675QQssPageNameZWDVWQQrdZ1QQcmdZViewItem I would prefer to have a cluster with a big tach and the 89 MJ I just picked up has the Big Gas Gauge and no Tach. There are also 2 "Open" spots on either side of the steering column. What was supposed to go there? I see connectors, but nothing is there. One more thing, the "dome" lights don't some on when I open the doors. Other than the obvious things like checking the fuses and the bulbs", is there something else I can/should look at? Thanks SW2 Link to comment Share on other sites More sharing options...
Burls Posted December 16, 2007 Share Posted December 16, 2007 I don't believe the 86 cluster will work. 87-90 cluster will swap directly into your 89. You will need to get a new oil pressure and temp sending unit that is specifically for full clusters. here's a link for the cluster swap http://www.jeepin.com/features/gaugeswap/ As for the dome light, have you checked the door switches? Link to comment Share on other sites More sharing options...
SuperWade2 Posted December 16, 2007 Author Share Posted December 16, 2007 As for the dome light, have you checked the door switches? Nope, it was Dark!! :eek: :D Link to comment Share on other sites More sharing options...
KYMJ Posted December 16, 2007 Share Posted December 16, 2007 Have you actually looked at the interior lights? They're not a very good design. Sometimes they just simply don't make good contact with the bulb. I had some that were corroded just enough to keep them from doing so. I sprayed them with contact cleaner and they worked for a while. Replacement was the only permanant solution. I bought new ones for 1 of my trucks, don't know if they are still available from the dealer. I paid $24 wholesale each. The lights in my remaining MJ are doing the same thing now, and once in a while they will come on with the doors open, but most of the time not. They will come on with the light switch turned to the interior light position. You can try cleaning the contacts, but after you see the lights up close, you'll realize its not as easy as it sounds. Plus the more you mess with these stupid lights, the more chance you'll break the tabs that hold them in the side panels. Mine hang from the wires :nuts: . Poor design. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 16, 2007 Share Posted December 16, 2007 I take mine apart and file the contact surfaces, they work for a loooong time after that (they made it 20 years, let's see another 20!) Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 16, 2007 Share Posted December 16, 2007 Here is the link to the write up that I did on replacing the interior lights. http://www.comancheclub.com/forums/view ... highlight= Link to comment Share on other sites More sharing options...
McClare Posted December 16, 2007 Share Posted December 16, 2007 My dome lights come on when I open the door if I have them flipped down. The light itself rotates, maybe you didn't try that. The blank spots beside the steering column are for switches. The left side was for fog lights and something else, can't quite remember. And the right side is to switch the tranny from comfort to power, and for the rear wiper (for XJ). Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 16, 2007 Share Posted December 16, 2007 Here is the link to the write up that I did on replacing the interior lights. http://www.comancheclub.com/forums/view ... highlight= I used Porsche / VW Hella interior lights because they looked more like the original Renault units: http://comancheclub.com/forums/viewtopi ... ht=porsche Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted December 16, 2007 Share Posted December 16, 2007 Nice writeups! We all know the original dome lights suck for illumination. Sure beats spending $70+ on a stock pair on ebay, I went ahead and bought the temp/compass and domelight mirror on quadratec it killed a lot of critters with one stone for me. I don't mean to hi-jack but in my eliminator I noticed I also have lights under the dash by the kick panels that helps a great deal. Is this standard on all MJ's? If not I noticed that some places sell kits for brighter lights under there. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 16, 2007 Share Posted December 16, 2007 Nice writeups! We all know the original dome lights suck for illumination. Sure beats spending $70+ on a stock pair on ebay, I went ahead and bought the temp/compass and domelight mirror on quadratec it killed a lot of critters with one stone for me. I don't mean to hi-jack but in my eliminator I noticed I also have lights under the dash by the kick panels that helps a great deal. Is this standard on all MJ's? If not I noticed that some places sell kits for brighter lights under there. No, the under dash lights came with the "Interior Lighting" package option. But all MJs I've seen are already wired for them, the receptacles are tucked up behind the kick panels. So you can pull them from a junk yard XJ and just plug them. Oh - and they did change the plug in 1991, so if you have a 91/92 MJ get the newer ones. Link to comment Share on other sites More sharing options...
WahooSteeler Posted December 16, 2007 Share Posted December 16, 2007 the stock dome lights are a 3 position switch. when in the up position they should come on manually. in the center position they are off, i.e. always off, down position, come on by door opening. my door switches were shot, got replacements at teamcherokee.com for less than $10 I think. you will need to clean the contacts on the lights too, most likely. be carefull when you pull them out, they have 2 flex tabs on the right or left side depending how they were put back in the last time someone had them out. anyway, these plastics tabs are very fragile and are the most common thing to break on these which keeps them from holding in place, so be gentle. there are replacements out there for less than they go for on ebay. most of the guys here seem to have a private stockpile of them, but occassionally they let a pair go LOL!! Link to comment Share on other sites More sharing options...
SuperWade2 Posted December 17, 2007 Author Share Posted December 17, 2007 the stock dome lights are a 3 position switch. when in the up position they should come on manually. in the center position they are off, i.e. always off, down position, come on by door opening. my door switches were shot, got replacements at teamcherokee.com for less than $10 I think. you will need to clean the contacts on the lights too, most likely. be carefull when you pull them out, they have 2 flex tabs on the right or left side depending how they were put back in the last time someone had them out. anyway, these plastics tabs are very fragile and are the most common thing to break on these which keeps them from holding in place, so be gentle. there are replacements out there for less than they go for on ebay. most of the guys here seem to have a private stockpile of them, but occassionally they let a pair go LOL!! Well, after a short drive today, I messed with the dome lights, in the daytime and they acutally do sort of work. The Door switch on the driver side is gone , physically missing, and the one on the passanger side seems 'crooked;. But with a little tap and wiggle, and a push up and down, the lights on both sides came on. But in either the up or down position, they stayed on whether the passenger side door (the only one with a switch) was open or shut. So not a big deal, I know they work when I need them manually, so thats the important thing. If I happen across some door switches at some point in my travels, maybe I'll fix it up. Might go for the swap at some point if I run across those replacement ones. SW2 Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 17, 2007 Share Posted December 17, 2007 they stayed on because of open loop, or bypass, on the missing door switch. Link to comment Share on other sites More sharing options...
WahooSteeler Posted December 17, 2007 Share Posted December 17, 2007 will they come on when you turn your headlight switch all the way left? Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 17, 2007 Share Posted December 17, 2007 Yes, they do. Link to comment Share on other sites More sharing options...
WahooSteeler Posted December 17, 2007 Share Posted December 17, 2007 ooops, yeah i knew that, i was asking superwade. should have clarified that. Link to comment Share on other sites More sharing options...
SuperWade2 Posted December 17, 2007 Author Share Posted December 17, 2007 will they come on when you turn your headlight switch all the way left? negative...not in either the up or down with the door open or closed. Cannot make them come come by any means, other than manually flipping them up or down. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted July 15, 2008 Share Posted July 15, 2008 Alright i know this is a few months old......but i finally got an OEM pair of interior lights and they won't work at all, ive read all the info on em.....right now I'm thinkin its bulbs (ill check the lights with a test light tomarrow) but it could also be any of the other culprits. but right now they won't light with anything (door switches, headlight switch turned or manually flipping the lenses) Link to comment Share on other sites More sharing options...
jtdesigns Posted July 15, 2008 Share Posted July 15, 2008 FUSE, FUSE, FUSE... You have a 5spd?? Check for clutch fluid on the fuse box... I hate that crap!!!!! It made most of my lights not work!! Plus check that ground on the firewall and fender... Link to comment Share on other sites More sharing options...
McClare Posted July 15, 2008 Share Posted July 15, 2008 hook them up directly to the battery. that'll tell you if the light itself works. Then narrow it down to switches and fuses Link to comment Share on other sites More sharing options...
