Rubikahn Posted January 14, 2022 Share Posted January 14, 2022 I was thinking of replacing my door cards with some XJ ones that have the cloth inserts in them, but I read somewhere that my existing panels aren’t all that common. I can’t find where I read that now. They have like fake stitching in them. Can anyone verify wether these are common or harder to find door cards? Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 14, 2022 Share Posted January 14, 2022 I can look later in the catalog and give you a basic trim level idea as to what that style came with. Link to comment Share on other sites More sharing options...
Pete M Posted January 14, 2022 Share Posted January 14, 2022 rule of thumb, anything that's fancy is rare. Link to comment Share on other sites More sharing options...
Rubikahn Posted January 14, 2022 Author Share Posted January 14, 2022 39 minutes ago, eaglescout526 said: I can look later in the catalog and give you a basic trim level idea as to what that style came with. Very much appreciated! Link to comment Share on other sites More sharing options...
Rubikahn Posted January 14, 2022 Author Share Posted January 14, 2022 29 minutes ago, Pete M said: rule of thumb, anything that's fancy is rare. I know, right? Especially on these trucks. If they’re not common, they’re getting cleaned up and staying! 😂 Link to comment Share on other sites More sharing options...
fiatslug87 Posted January 14, 2022 Share Posted January 14, 2022 My 88 Pioneer had those. Link to comment Share on other sites More sharing options...
Rubikahn Posted January 14, 2022 Author Share Posted January 14, 2022 15 minutes ago, fiatslug87 said: My 88 Pioneer had those. These are in my 89 Pioneer. Link to comment Share on other sites More sharing options...
54bobby Posted January 15, 2022 Share Posted January 15, 2022 7 hours ago, eaglescout526 said: I can look later in the catalog and give you a basic trim level idea as to what that style came with. i have the same cards. came with Laredo's. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted January 15, 2022 Share Posted January 15, 2022 These are from my 90 eiminator Link to comment Share on other sites More sharing options...
Rubikahn Posted January 15, 2022 Author Share Posted January 15, 2022 8 hours ago, 54bobby said: i have the same cards. came with Laredo's. So these are Laredo specific or an upgrade option? Link to comment Share on other sites More sharing options...
Rubikahn Posted January 15, 2022 Author Share Posted January 15, 2022 5 hours ago, ghetdjc320 said: These are from my 90 eiminator I can’t tell from the pic if yours have the stitching? Link to comment Share on other sites More sharing options...
Jasper Posted January 15, 2022 Share Posted January 15, 2022 My brothers 88 has the same panels. The panel in the picture is what I have in my 86 those came out of a 92 Cherokee Laredo Link to comment Share on other sites More sharing options...
Rubikahn Posted January 15, 2022 Author Share Posted January 15, 2022 16 minutes ago, Jasper said: My brothers 88 has the same panels. The panel in the picture is what I have in my 86 those came out of a 92 Cherokee Laredo Ok, those 92 XJ panels with the cloth inserts are what I was looking to upgrade to. Looks like you have PWs and PLs too. Did you add those from the XJ as well? Link to comment Share on other sites More sharing options...
Jasper Posted January 15, 2022 Share Posted January 15, 2022 9 minutes ago, Rubikahn said: Ok, those 92 XJ panels with the cloth inserts are what I was looking to upgrade to. Looks like you have PWs and PLs too. Did you add those from the XJ as well? Yes I did swap power windows locks and mirrors in. It’s a 86 Comanche with a 94 4.0 engine and running 96 wiring for obd2 capabilities just currently trying to finish up the wiring. I also have a set of non power window mj door panels with cloth inserts if you wanted I could send a picture of those as well. Those are out of a 88 mj Laredo Link to comment Share on other sites More sharing options...
Rubikahn Posted January 15, 2022 Author Share Posted January 15, 2022 Did the PW/PL harnesses plug into the existing fuse panel or did you need to upgrade that too? Link to comment Share on other sites More sharing options...
jdog Posted January 15, 2022 Share Posted January 15, 2022 44 minutes ago, Rubikahn said: Did the PW/PL harnesses plug into the existing fuse panel or did you need to upgrade that too? Mine plugged in the existing fuse block Link to comment Share on other sites More sharing options...
Rubikahn Posted January 15, 2022 Author Share Posted January 15, 2022 42 minutes ago, jdog said: Mine plugged in the existing fuse block Perfect, ty Link to comment Share on other sites More sharing options...
Jasper Posted January 15, 2022 Share Posted January 15, 2022 1 hour ago, Rubikahn said: Did the PW/PL harnesses plug into the existing fuse panel or did you need to upgrade that too? Mine was a 86 with the 2.8 so I swapped the entire wiring out of the 96 xj I had parts from Link to comment Share on other sites More sharing options...
ghetdjc320 Posted January 15, 2022 Share Posted January 15, 2022 4 hours ago, Rubikahn said: I can’t tell from the pic if yours have the stitching? Yep, same stitching. My 91 also had them. Link to comment Share on other sites More sharing options...
Rubikahn Posted January 15, 2022 Author Share Posted January 15, 2022 2 hours ago, Jasper said: Mine was a 86 with the 2.8 so I swapped the entire wiring out of the 96 xj I had parts from 👍 Link to comment Share on other sites More sharing options...
Rubikahn Posted January 15, 2022 Author Share Posted January 15, 2022 1 hour ago, ghetdjc320 said: Yep, same stitching. My 91 also had them. Ok, couldn’t really see it, lol. Ty Link to comment Share on other sites More sharing options...
Minuit Posted January 16, 2022 Share Posted January 16, 2022 7 hours ago, Rubikahn said: Ok, couldn’t really see it, lol. Ty 87s and 88s had plaid instead of tweed if that's your thing. Link to comment Share on other sites More sharing options...
