Rubikahn
Everything posted by Rubikahn
Pics of all three parts of the harness. I see the tan power wire that has a red clip on it. That was plugged into power/acc in the bottom portion of the fuse panel IIRC? Where is the ground though? Also have some small green connectors. What are those for? Anyone have a diagram for a 96, lol.
Awesome! Ty
Reviving this old thread. I just picked up all this from a 96 2-door XJ. The power window/ lock driver side harness, the passenger side harness, and cross body harness. I also have both driver and passenger side switches. After going through this thread it seems I’m going to have rewire a few things to get it to work in my 89 Comanche. There is only one plug in the driver’s side harness that was clipped into the fuse panel. Was there a relay center I should’ve grabbed as well from the passenger side? I don’t recall seeing anything like that there tbh.
Rusty’s 4.5” rear leafs part number ropcom35-0
Rubikahn replied to Rubikahn's topic in MJ Tech: Modification and Repairs
Sorry, I haven’t loaded anything that heavy into the bed yet. It’s currently off the road since I pulled the carpet up and the floors were in really bad shape. -
Thanks guys! I’ll see what happens when I pull the gauge out. As far as the lube going in a ziploc, I’m there with you on that. I do the same thing with Antiseize lol
I do still have the dummy cluster but the gauge face is a different color scheme. I’ll try pulling out the full cluster one and see if I can figure out what is going on with it. I found that lube on Amazon. I’ll be ordering that for the speedo cable, Ty
Factory-Original Sport Bar Install (With KC-Lights)
Rubikahn replied to NEO auto's topic in MJ Tech: Modification and Repairs
Ok, thank you for that. So it looks like part “E” ,the reinforcement plate, is the backing plate for the roll bar legs that sit on the wheel wells like you had mentioned. Ty -
I didn’t think so and yeah the pic looks like it’s the bed floor. In the break down it lists the reinforcement plate as “E” but it’s never called out in the diagram. -
These have a reinforcement plate sandwiched between the gasket and the bed floor? -
I’ve searched online and couldn’t find the fix for this. Which I am going to assume is a replacement at this point. So here’s where I’m at so far. I replaced the dummy light cluster a few months ago with a full cluster. The full cluster I bought had more miles on the odometer than my dummy cluster one did. I never bothered fixing it. The odometer has gotten stuck at 125,000 miles. It won’t go past that number. The tach works fine and so does the speedometer. My speedometer needle bounces quite a bit but I haven’t had a chance to pull it/ grease it to see if that fixes that issue. So has anyone run into this? Is it repairable or am I going to have to source a new odometer/speedometer gauge?
Yes sir, that is it. I didn’t think you did cuz I bought the power antenna nut you had listed on eBay from you 🤣
That stinks…
I’d suggest reaching out to Brandon Scarborough on FB. I have a set of rear brackets but they’re pretty rusty and bent.
I spoke to Brandon at one point and asked if he was ever going to make another run of brackets. He said he had no plans to make them again but if IIRC he mentioned he’d share the files if someone else was interested in making them.
I am hoping to take measurements today. I was only asking if anyone has run these. From what I recall reading about the OME rear shocks on an MJ, there were ZJ shocks that would work but it depended on lift height. So when I saw these on Quadatec figured I’d ask on the forum
I recently installed a set of Rusty’s 3.5” rear leafs on my 89 LWB. I have 4” coils up front. I found a BNIB set of OME 60052L front shocks which will work for the front. I found these OME 60053L rear shocks which look like they’ll work for the rear. Anyone have any experience with these?
Anyone have one they’re looking to sell? PM please, Ty
2.5L Idle Speed-up Jumper harness
Rubikahn replied to eaglescout526's topic in MJ Tech: Modification and Repairs
Following -
This past Monday I finally got around to pulling my carpet and seeing how bad the cab floors are. They’re in pretty bad shape. How screwed am I? I’m going to order replacement floor pans. Inner and outer rocker replacements from Key Parts for this.
Wheel Center Cap Emblems
Rubikahn replied to ghetdjc320's topic in Vendors- members making products for MJs
Put me down for 8 please. -
Has anyone ever removed the originals? I’d definitely be interested in a set. Just paranoid of gouging the $#!& of the cap trying to pry the old ones off
