Hey friends, looking for some advice. I'm from California but I'm up visiting friends in Canada. I haven't driven my truck a ton while I've been here but when I have driven it it's been fine, until last night. I drove from where I'm staying to a friend's, roughly 10m drive, it was fine. When I went to leave a few hours later, truck wouldn't start. I was able to get it to move by giving it a ton of gas but it sounded horrible and I could tell it didn't want to drive so I pulled over and had it towed.
I've been working on it today, haven't found anything glaring so I made this video, mostly for audio purposes of how it sounds. Once I can tell its going to start it idles super low like it's about to stall, then it shoots up to 1500 or so rpm before dropping back down to normal rpm of 900ish. It'll hover there for a few before dropping down to 400ish. Sometimes it'll go back up to normal idle or sometimes it'll just stall out as it does here. I'm kind of leaning toward this is a fuel delivery problem or bad gas but I dunno.
Any help would be appreciated.
https://photos.app.goo.gl/oejjdCZyLU3mFyfN7
Kinda sounds like a blown head gasket. I had that issue where it would idle fine (IE going into open loop mode) then it would go back into closed loop and it would suffocate itself from the coolant intake.
Possibly something simple like poor grounding would be easy to check. Inspect the ground behind the driver rear tail llight and everything on the rear bed harness.
I haven't checked that one yet but I have done all of cruisers grounding tips including adding a new ground for the fuel pump to the frame.
That sounds exactly like a bad/sticking IAC to me.  I'd pull it out, inspect and clean it if nothing else.
14 hours ago, Jess said:
*Richmond/New Westminster BC
Sorry… I was thinking if you were a bit closer I might have been able to offer a little more assistance, tools, etc, but I’m in Alberta. Can’t think of any forum members in the Vancouver area, either, at least not off the top of my head.
7 hours ago, cruiser54 said:
Make sure intake manifold bolts have not loosened up.
Carefully inspect the hose from MAP to throttle body.
Just checked the bolts, nothing was blatantly loose but I was able to snug a few of them.
Checked MAP hose, looks good. I did tip #31 about 40k miles ago but I did a thorough inspection of it a few weeks before I left on this trip.
I inspected it, it's very clean as is the whole TB as I cleaned it before this trip.
2 hours ago, Pete M said:
which of Cruiser54's MJ tips have you done so far?
1-8, 11-14, 25, 28, 29, 31, 32 and probably a few others.
No worries. Thanks for the thought, appreciate it!
This is my biggest worry. Engine oil (from dip stick at least) looks normal. I'm going to try and source a compression tester from one of the neighbors here today and hope I can rule that out.
Yeah it’s not a fun thing to suspect. And usually you won’t see a milky oil. I had the issue where oil was fine but most of the gasket failure was putting water into the combustion chambers. Hopefully the compression test will reveal something.
She's starving. Not enough fuel or too much air.
If it were a head gasket you would usually see blue or white smoke billowing from the exhaust.
Since you already checked IAC, inspect all vac lines, intake hose and valve cover gasket for leaks.  Do they have Autozone or O'Reilly's up there? If so, you can rent a fuel pressure tester.
No and no, although many of the local parts chains have the same program, but a few of them have paused it due to covid. Canadian Tire and Partsource for sure had the program, Lordco might have and is my prefered parts supplier if an option. I’ve seen reference to Napa renting out tools as well but my local one doesn’t. Probably better to call ahead.
If you’re looking for cheap single-use tools for purchase, Princess Auto is the go-to, although any parts chain will have tools for sale.
I don't see any smoke. I called Lordco, Napa & Canadian Tire and Canadian Tire is the only one with tool rentals but the friend I'm visiting has a mechanic friend who's letting me borrow a fuel pressure tester and hopefully a compression tester tomorrow.
The neighbor here did have a vacuum gauge which was reading 20-25Hg at normal idle (while it lasted). No idea how accurate his gauge is. I used the vacuum reservoir port on the intake manifold.
I went over every vacuum line and ground point today and couldn't find anything.
4 hours ago, Ωhm said:
Watch the video. That packard connector for the, I think, TPS has a cracked hold down cover latch.
Yeah that just broke a couple months ago when I put inna new TPS. The clip on the IAC connector has been broken for years as well. Both are on my to-do list.
I'm getting around 8psi key on/engine off and 15psi at idle until it stalls then it very quickly drops to 0. No change in psi removing the vacuum line on the pressure regulator.
Check to see how much voltage you have at the pump connector. Orange wire I believe.
If you have about 12 volts, likely your fuel pump is bad or the internal rubber hose is messed up.
9.75v with engine on
Just now, cruiser54 said:
That was fast!! Have you bypassed the fuel pump ballast resistor or is it still stock?
Still stock. But I did try jumpering the wires together the other day to see if it would do anything (it didn't).
Maybe that isn't the correct way to bypass it?
