Ordered up a Mechman alternator. My existing alternator was original to the engine and the regulator was staring to have issues. The mechman amperage at idle is excellent. The goal is to keep alternator voltage at idle vs dipping into battery reserve.
  • Replies 864
That'll be a nice addition.
Only thing that worries me about a special part like this is the availability... I guess a stock one would work in a pinch.
That’s right. Since the case and connections are the same, a parts store alternator would work in a pinch. These mechmans are really nice units. High quality bearings and square copper windings.
Audio system under construction at the moment. I’ve long wanted to build enclosures for some compact subs in the b pillars. It’s really an ideal location for them if done right. Started by some careful measuring the other day. Plan is custom enclosures for (2) JL 6.5 W3 subs. Will feed them with either a 3 or 4 channel amp from a customized RX173 head unit with a DSP.
Here’s the beginning of this project. 1/2” birch for the shell which is appropriate for the JL 6.5 subs. Exact dimension tbd but I’m within a narrow range. QTC will be in the .75 range
10 hours ago, Smokeyyank said:
Will be interested to see how the audio turns out. Assuming amazing as always.
Thanks! I’m also curious to see how it turns out :holdwrench:
All the glue is dry now. Going to put in some seam sealer around the inside just for the xtra insurance. For reference, I used 1/2” birch, wood glue, 1.25” cabinet screws and polyfill. Will probably finish them with some black textured bedliner. Next, I’ll cutout the b pillars and measure out the cabinet/edge supports
Overall dimensions are 9w 8h and 6.25d giving .17 airspace with 1/2 birch. Driver displacement of .02 give us a final of .15 and right in the money. Added 40% polyfill to dampen the response a bit. Some update pics of the finished product:
Had to make a small detour to patch a nasty water leak. Cutting out the old metal seam and getting some solid clean metal to work with. Then will weld it all up solid.
