On 5/11/2023 at 11:56 AM, EUREKA said:
I'll look forward to you resuming.
Thanks! It’s all covered and stored away for now. 2024 will be the year of the Tomahawk
Edit: correction, 2025 will be the year :holdwrench:
  • 6 months later...
  • Replies 861
On 11/21/2023 at 1:40 AM, ghetdjc320 said:
Getting close to picking up this project again. Planning to pull the engine again and adding notch flares and ares bedside armor. Anyone ever used the ares armor? Here is what I was looking at: http://aresfabrication.com/shop/mj-bed-armor/
I used this armor but got it with the tubing for the rub rail. Really heavy duty stuff. I love it but beware it is heavy. Also the nutserts you want to be careful they seat well so they don't just spin when you tighten the bolts to hold it on. Unfortunately that happened to a few but it still worked out well
Good to know. I wasn’t planning to install it with the nutserts but was going to panel bond and weld it on. I do have the heavy duty nutsert tool though from doing corner armor on my YJ. Was going to see if I can order a set and forgo the “Ares” logo if possible.
  • ghetdjc320 changed the title to Project “Tomahawk”
3 hours ago, ghetdjc320 said:
:D
:drool:
Been following a lot of builds and yours are definitely some of my favorites. Really enjoy the detailed pics of improvements wrt leaks, seam sealer, etc.
Much appreciated :L:. I try to post a ton of pics of the smaller detail items as I’ve found it’s always the one thing I skipped or overlooked that comes back to bite.
So for the next chapter of this build. I have about 11 weeks to get things as far along as I can this go around. I have a set of Revolution 4.56 gears and install kits waiting to go in. The “original” aspects of the build are becoming fewer and fewer. The nos turbines i ended up selling so I have a clean slate to move forward on. My previous choices on steering gear box, and fender flares may need to be reconsidered. I’m still on the fence regarding notch flares. If I go that route, 33-34’s are in the sights on this otherwise LCG build. I did decide on some wheels though which should help things a bit. After reading through @USN_JeepMJ’s build, I love those JL wheels and am ordering some up. Will use BORA wheel adapter that will give me the M14-1.5 stud for the wheels to use JL lug nuts as specified. I have to say, I really appreciate everyone posting the tidbits of details from there builds especially issues they’ve had as there are so many takeaways and lessons from those who have gone before.
So here are the Mopar accessory wheels for the JL/JT. 17x8.5 with a 71.5mm center bore. 5.22” backspacing.
With the BORA adapters, they are also custom made in the USA and are available in 1mm increments for thickness. The starting size is 19mm (3/4”). Going to do a lot of measuring to get the exact stance I’m looking for.
Notch flares on the way. It’s officially an LCG build. Plan is 33’s or maybe 34’s on the 3” BDS lift. Time to measure every component to the T so it all fits as intended.
I’ll post up pics on the notch flares install as well. There are very few pics of the install on the bed of an MJ. I will not separate the inner and outer wheel well housing though. That opens up a whole can of worms. I’ll trim it nice and tight but keep the integrity of that body seam. Front fenders I don’t really care about hacking up but I’m switching to the 97+ front clip :laugh:
Alao reached out to Corbeau and ordered some matching upholstery for my trailcat’s to do the door panels with. Have to think ahead about audio setup as well since they will be custom made. IMO, the best scenario is to build some kind of enclosure in the B pillars to accommodate a 6.5” sub (like the little JL W3). If I could manage to accomplish that, I’d run a nice morel or similar 3 way system up front with some 6.5’s or larger main woofer along with mids and highs properly positioned.
Also need to measure for driveshafts and order that “Dirty Dingo” AC kit for the ls. I considered going with the new Holley mid-mount accessory drive but after seeing how @USN_JeepMJ and @Limeyjeeper managed to install their steering reservoirs and keep a stock style PS pump using a smaller intake tubing, I’d decided to go that route. Also considering the psc big bore box as I had one previously in my YJ and it’s a great box for filling the gap between a stock box and hydro assist.
Mopar slotted wheels just arrived. These things are awesome. Also took a picture of the back side as I couldn’t find any pics of it online. For those who may be using adapters for these wheels, they should fit very well within the back of the flange
Those are sweet, feel free to drop them by my house whenever you come and see my MJ projects lol. Also if you don't mind put those notch flares in my street MJ while your there 😜
I’m dreading how much work those flares are going to be to fit :holdwrench:
I'm thinking about maybe going with the Ares bed armor to get a better mounting surface and open up the wheel well to its full potential :dunno:
I've run those flares on a past XJ build, nice when done, not nice before done lol.
I run ares fab armor on my XJ, too quality stuff, I used to have his bumper as well and he even customized it to not have the logo, and an additional front trailer hitch point. Would not hesitate to run more of his products
Good to know, and I was wondering if he could build them without the logo. I’ll reach out to him today about that. Thanks :L:
Well, I’ve considered it thoroughly and my schedule is just not going to give me the time to finish this project. Regretfully, I’m considering passing the torch on to someone else who can finish it off. You guys have known me here for years so if someone in the club is interested just let me know. Headed back overseas in mid April. If you go through this thread you’ll see the level of work and quality of components that are on this thing. No expense was spared.
You can't quit now! BOOO!
That's a real bummer. You're attention to detail, and commitment to perfection have been inspiring. I know I'm not the only one who has followed your builds, drooling at home. I hope this one goes to a good owner, and continues to get the same level of dedication that you've put in.
Thanks! I may end up keeping it here in long term storage, tightly sealed up for a later date. Just far too busy to get back to this and build it at the moment. Now I understand the whole “barn find” thing :laugh:
Got a chance to meet up with a fellow Comanche builder today @Comanche SS
First time I met anyone from the club. Great guy :L:. We got a bit of a game plan for getting this project finished up though it will still take probably about another year. Will be nice to get this one completed though.
here are some build updates: notch flares came in. Planning to focus on electrical and interior during the time I have left. The painless harness is great but requires a good bit of customizing and of course planning ahead for any extra accessories. I measured out for tire size and am planning on running metric 34’s (285/75/17) which have actual dimensions of 33.9” and 11.2 width on a 8” wheel. The notch flares really open up the leading and trailing edges of the rear wheel well in an MJ but don’t raise the opening by more than about an inch. Shouldn’t be necessary to separate the pinch weld/seam for the bed wheel wells.
Nice meeting you too, looking forward to helping get this project over the finish line!
Found a company online that repairs and refurbishes the old overhead console electronics. Just sent them my 1991 XJ sunroof console to get worked on and found a clean factory harness for it as well. More interior/electrical updates coming soon.
