rylee144 Posted September 16, 2021 Share Posted September 16, 2021 And freeze it before install. I have the bushing, working just fine Link to comment Share on other sites More sharing options...
RusellFromCanada Posted September 16, 2021 Author Share Posted September 16, 2021 2 hours ago, rylee144 said: And freeze it before install. I have the bushing, working just fine Smart. Thank you. Link to comment Share on other sites More sharing options...
RusellFromCanada Posted September 16, 2021 Author Share Posted September 16, 2021 Anyone know where I can find this bushing? or whatever bearing I can use. Everywhere is sold out, going to cost a fortune to ship to Canada or won't be here until November as far as I can see. My garage is not heated, I need this truck out of there before November for sure. I'll keep looking but i'm having no luck. Link to comment Share on other sites More sharing options...
rylee144 Posted September 16, 2021 Share Posted September 16, 2021 https://www.rockauto.com/en/moreinfo.php?pk=221655&cc=1309452&jsn=925&_nck=ZExt1ysfqhqWnq%2BEvUNdS3Txyey60IDtnjPWF5UU9J0BWQv7pvqZbkEUk86%2BAYIhteHnM8iYlR4ebKH3uRnjZxcDb0o67mtPZBCV8ZwaYy9iATWCyKzrWw6zMoVZjeRvj6PPTkpMNTx95f9DaD7HdXOK3NBSaOc405yvcWxQAj5x6%2B5Zs%2FXQVizs%2F8emZNwVXMFNavEZjDi2LQQFoWloc8ScKPSEC3HSeLnRHye8icso1SEmYkCR018M%2FE6Awt8A5FYKrr7MGN5%2BFrW4OkIbjLQHeTJACesL%2BmLy9rWOab%2BrYUe3BnQikb6hLuN4yGvtMPhT5EU78RGOUuu2FByiMOzVmuh%2FAlf5 Link to comment Share on other sites More sharing options...
RusellFromCanada Posted September 17, 2021 Author Share Posted September 17, 2021 out of stock :/ Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 17, 2021 Share Posted September 17, 2021 Did you try Novak? Local parts store? Summit racing or Jegs? Link to comment Share on other sites More sharing options...
RusellFromCanada Posted September 20, 2021 Author Share Posted September 20, 2021 I found it. Thank you all. Just ordered quite a few parts and am looking forward to getting this thing driving. Link to comment Share on other sites More sharing options...
RusellFromCanada Posted October 21, 2021 Author Share Posted October 21, 2021 Hey guys. I'm trying to put my crossmember back on and i'm a bit confused. As far i can see the bolts / holes circled here are the only ones ill need to repair to mount the crossmember, so what the h*ll are the rest of them for?? Before i spend any more HOURS repairing, drilling, tapping, welding, swearing ect can someone clarify if i'm wasting my time repairing any of the studs other than the ones i've circled? As you can see on the driver side picture i got ahead of myself and repaired a stud, and now I'm not so sure i need the stud there at all. Just need some clarification here and hopefully that will mean i only have one broken stud left to remove (right circled bolt on passenger side) Thank you. Link to comment Share on other sites More sharing options...
watchamakalit Posted October 21, 2021 Share Posted October 21, 2021 Those bolt holes are there to accomadate different motor, transmission, and/or transfer case combinations that were available. Just find the 8 holes that line up for your application and bolt it in. Link to comment Share on other sites More sharing options...
RusellFromCanada Posted December 13, 2021 Author Share Posted December 13, 2021 So i've been trying to get my ax-15 input shaft into my renix 4.0 pilot bearing for a few weeks now. At first I had the wrong size bushing, so when I ordered this new one I made sure to test fit it on the input shaft before installing. Unfortunately, after a few long nights of wiggling the transmission, re-doing my clutch alignment, ect I got fed up and removed the pilot bushing from the motor to confirm that it was not going to fit. As you can see in the pictures, the bushing fits on one way. (backwards from how it was put in the motor) and can not slide down the shaft further than pictured. I assume the size of the bearing slightly changed once it was pressed into the motor. So, solutions. Can i sand out the middle of this bearing to make the input shaft fit? Should i take material from the input shaft instead? Can i re-use this bearing now that its already been squished into there and then removed, or should i order a new bushing? Should i order a different size bearing/bushing to avoid this problem? Thanks in advance. This tranny install has been increasingly frustrating. In hindsight i see i probably could've sanded down the bushing inside of the motor, but a few hours into a frustrating night i had to see just WTF was going on. Link to comment Share on other sites More sharing options...
jdog Posted December 13, 2021 Share Posted December 13, 2021 You can sand down the inside of the bushing. What bushings did you buy? Link to comment Share on other sites More sharing options...
RusellFromCanada Posted December 13, 2021 Author Share Posted December 13, 2021 National PB-77-HD Clutch Pilot Bearing on amazon https://www.amazon.ca/gp/product/B003UEEJAK/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
RusellFromCanada Posted December 14, 2021 Author Share Posted December 14, 2021 Ok. More progress more questions. I've got the transmission mounted up now. My question now is, are one of these crossmembers going to work? They look the same to me. I read that the ax-15 had a 1 inch lower tranny crossmember than the other transmissions. When I went to identify the 2wd transmission i removed from the truck i looked up the ID code ( 53005386 ) and it brought me to a page on this forum identifying it as an ax-15. Is that possible? A 2wd ax-15? Did i just swap my Ax-15 for another ax-15?? If the removed tranny IS an ax-15, I assume the crossmember will work? will I need to find another rubber mount for the 4wd setup or should i be able to use this 2wd mount? It seems like it would have my transmission up rather high, and i don't want to have an unnecessarily straining angles due to me having sourced the wrong crossmember. thanks for any input. Link to comment Share on other sites More sharing options...
Pete M Posted December 14, 2021 Share Posted December 14, 2021 the one inch drop is in the center of the crossmember. it's a slight dip in the middle where the trans mount bolts on. Link to comment Share on other sites More sharing options...
Pete M Posted December 14, 2021 Share Posted December 14, 2021 like this: Link to comment Share on other sites More sharing options...
87MJTIM Posted December 14, 2021 Share Posted December 14, 2021 Like this: Link to comment Share on other sites More sharing options...
RusellFromCanada Posted December 14, 2021 Author Share Posted December 14, 2021 SUPER helpful guys. Just had a closer look at the crossmembers and I don't see any reason I can't cut that 1'' and re-weld it back on close to where yours is. Should work fine. Thank you. Link to comment Share on other sites More sharing options...
89ComancheProject Posted December 16, 2021 Share Posted December 16, 2021 I just did the AX15 conversion on a 88 SWB and used the shorter AW4 Automatic driveshaft with a SYE. Link to comment Share on other sites More sharing options...
