rylee144 Posted July 14, 2021 Posted July 14, 2021 I have a constant grinding sound coming from the front tire area. I lifted the truck and could move the wheel back and forth a little. Is that the wheel bearing indicating its worn out? What brand is a good price/quality? Secondly, I'm getting really tired of the front locker clunking in low speed sharp turns. Really embarrassing in parking lots. Anything I can do? Thanks!
MiNi Beast Posted July 14, 2021 Posted July 14, 2021 Disconnect axle other wise will need to install live axle hubs to replace unit bearings or air or cable selectable locker. One down side to lunchbox lockers with d30s. Tire movement 9 to 3 a little but a means to check steering. 12 to 6 movement for bearings or ball joints 🤔 look close for wear or if bearing is hoter then should be...
rylee144 Posted July 14, 2021 Author Posted July 14, 2021 6 minutes ago, MiNi Beast said: Disconnect axle other wise will need to install live axle hubs to replace unit bearings or air or cable selectable locker. One down side to lunchbox lockers with d30s. Tire movement 9 to 3 a little but a means to check steering. 12 to 6 movement for bearings or ball joints 🤔 look close for wear or if bearing is hoter then should be... If I disconnect the axle in loose 4wd right?
MiNi Beast Posted July 14, 2021 Posted July 14, 2021 Well with the locker in you would still have use of 3 wheels. Look into the difference in lockers a bit.
rylee144 Posted August 18, 2021 Author Posted August 18, 2021 It appears I have some rubbing at full lock.
rylee144 Posted August 23, 2021 Author Posted August 23, 2021 I'm not positive it's the locker that's causing the clunk. I'm about to throw money at it its driving me nuts
MiNi Beast Posted August 23, 2021 Posted August 23, 2021 1 hour ago, rylee144 said: I'm not positive it's the locker that's causing the clunk. I'm about to throw money at it its driving me nuts First thing first, pull the cover and rotate driveshaft and take a look. Or pay me money and ill look at it 🤪
rylee144 Posted August 31, 2021 Author Posted August 31, 2021 Got new ball joints, wheel bearings and a u joint in the axle shaft. The u joint was toast just rust left inside. The wheel bearing had alot of wobble in it. Lastly the top ball joint was so tight I couldnt get the rod to move even with a big hammer. I think that was my problem but it could have been all of it. Putting it back together today then a test drive. 🤞
rylee144 Posted September 1, 2021 Author Posted September 1, 2021 Ugh the clunk remains! Wheel bearing feels real good though so that's nice. Are putting the stock gears back in the dana 30 hard? Thinking about ditching this locker.
MiNi Beast Posted September 1, 2021 Posted September 1, 2021 You can pull the axle shafts and pop the locker out and put the spider gears back in for sure, this will eliminate certain clunk but still may not be your issue perhaps.
rylee144 Posted September 1, 2021 Author Posted September 1, 2021 I don't have the original gears. Axle came with the locker in it. Had time to do some reading. Some suggest the brake calipers could be the culprit. Not sure how that works tho. Most testing to come
DesertRat1991 Posted September 1, 2021 Posted September 1, 2021 10 hours ago, rylee144 said: Ugh the clunk remains! Wheel bearing feels real good though so that's nice. Are putting the stock gears back in the dana 30 hard? Thinking about ditching this locker. If road manners are a priority then a selectable locker would be your best bet. That said, a Truetrac LSD will do 90% of the job for 50% of the cost and 5% of the hassle. A front Truetrac delivers flawless road manners in 2WD daily driving situations. No noise, no steering issues.
PIKE Posted September 1, 2021 Posted September 1, 2021 Have a Truetrac in the front of all three of my vehicles. Great traction, no maintenance and seamless on the road.
Jesse J Posted September 1, 2021 Posted September 1, 2021 I am very excited to see how my 2 tru tracs behave on and offroad.
PIKE Posted September 2, 2021 Posted September 2, 2021 Use gear oil that does not have any friction modifier for maximum traction wit your Truetracs. This is what I use. https://www.redlineoil.com/75w90-ns-gl-5-gear-oil This is also a good GL-5 transmission oil. Non corrosive to synchro and slows them easier for shifting because it is not as slippery.
rsmecham Posted September 2, 2021 Posted September 2, 2021 6 hours ago, rylee144 said: Your locker is the problem. That clunk will always remain as long as you have two solid axleshafts, I just put a lunchbox in mine. Besides a little steering feedback I don't really mind mine
rylee144 Posted September 2, 2021 Author Posted September 2, 2021 6 hours ago, rsmecham said: Your locker is the problem. That clunk will always remain as long as you have two solid axleshafts, I just put a lunchbox in mine. Besides a little steering feedback I don't really mind mine What I currently have
rsmecham Posted September 3, 2021 Posted September 3, 2021 14 hours ago, rylee144 said: What I currently have Looks like a spartan locker to me. I would keep it in there until you get the new one though. Seriously upgrades your offroad performance like you wouldn't believe.
rylee144 Posted October 12, 2021 Author Posted October 12, 2021 Swapped out my wheel bearings and ball joints. Still have a clunk when turning and a vibration starts at 35 MPH. Brought this up in another topic and Pete mentioned the front drive shaft. Crawled under the truck and checked it out. I'm no expert but the u-joints are toast, lots of play. I'm looking at buying the kit below to swap out the u-joints and the double cardon joint. I've watched a few videos online and I think it should do the trick. Advise and comments are encouraged before I buy. Thanks! https://oliversdriveshaft.com/shop/yj-drive-shafts/jeep-front-drive-shaft-1310-cv-rebuild-kit-part-5-1310x-211544x-tj-xj/
gogmorgo Posted October 12, 2021 Posted October 12, 2021 Good quality kit, although personally I would prefer greaseable ujoints. Something to watch for when rebuilding the double cardon, the centring yoke is a needle bearing, much like the ujoint caps, but the pin in the middle the bearings roll on is welded to the driveshaft, and if it’s worn in badly, your new centring yoke won’t last long before it gets the shakes. I don’t know if repair kits for it exist, if a driveshaft or machine shop could correct it, or if it just means you need to find a different driveshaft.
