88 LWB Camper Build
  • Replies 219
Got an NP242 out of an '89 Cherokee this morning from the JY. Took it apart to find a wonderful sight on the magnet :eek:
There was almost no fluid in it, but what was in it was fairly clean, so I'm guessing they drove with low fluid for a bit. Crazy because the bearings appear to be in good condition and so are all the gear teeth.
I was looking like: WHERE DID THIS METAL COME FROM? lol. I could repair my floorboards with this amount of metal.
Someone has been into it before, so maybe they just didn't clean the magnet... I hope...
Anyway, cleaned what remained and applied some RTV to all of the mating surfaces & loctite to the bolts. Snugged them all down and I'll torque them tomorrow when the RTV has time to harden.
Today was an experience for sure. Welded a section of the floor in. Before you say anything, yes I know the welds looks god awful. But I tell you it's in there for life. I've never welded a day in my life until today. Seam sealer will be my savior in this case it seems.
But, hey, I don't have a giant hole in there anymore!
I still have to further sand and paint. I only sprayed something down for now so it wouldn't rust overnight since I had driven a few hours to have access to a welder and ran out of time. The piece of metal is actually from a rear driver XJ panel. Fit well all things considered.
I didn't document much when doing this, but I swapped the D30 for one from a '98 XJ with 3.55s. Got it from the same guy as the replacement D35. Since it didn't come with rotors I replaced the knuckles with my '88 because I already had new everything for it. Next time I have to do the front brakes I will probably swap it back. I also replaced the worn LBJs with the ones I had just installed in the '88 axle as well. Other than needing an alignment, it's running well.
I've been putting off the clutch until I move (I've already purchased it). Today, I had a full load from my storage unit and was in reverse to the driveway. I had to back into a curb and when the front wheels rested on the curb I gave it gas but the tranny just gave a loud bang and didn't go anywhere. Just wouldn't pull the weight. I ended up bumping it and made it fine, but hate that it happened. Hopefully it's ONLY the clutch and not something else. Drove just fine after. 4wd is a bit wonky. Doesn't seem happy. Will be a fun discovery.
Side note, the RC suspension is actually not bad when under load. It's stiff for sure, but was very enjoyable on the 20min ride home.
1st "Off-Road" use  :laugh:
11 hours ago, Pete M said:
practice on spare sheetmetal.  then weld on your truck.
That's what I did (Top was 1st try, Bottom was 2nd) and the bead was certainly not the best, but would've been fine. But for some reason (maybe ground or just cheap welder) it just wanted to spit the weld. I'd like to acquire one and eventually learn, but this was simply to get the floor in before I move next week and won't have access to a welder.
Made the move from Georgia to Utah this week. She held up nicely on the dolly. After packing the rear, it sat about 5" lower. Swayed like crazy due to the weight distribution. Not a fun way to drive 2,000mi for sure, but it does make a great enclosed trailer  :laugh:
Can't wait to get everything situated so I can continue working on it.
5 minutes ago, eaglescout526 said:
Is it bad that I can see you're missing the upper trim piece?
It's awful right?? lol
I was going to replace the header panel with similar year since it's actually cracked a lot of places, but I figure I'll just wait it out until I do a 97+ clip.
  • 1 month later...
Well, guess I better start working on it again lol
I've honestly been driving it around town as my daily. Almost 900mi on it since this project started. Trying to keep to a minimum though now that salt is on the ground and I haven't refreshed the underbody yet.
Since moving, I haven't had anything in the garage set-up. So first thing was buying a toolbox and building a couple tables/shelves this past week. Now that I've got that completed, I can finally start turning a wrench again.
I've been slowly collecting the NP242 swap parts and the last will be here tomorrow. Plus the new clutch has been sitting looking for a job. I'll try to knock those two out together.
Tonight I figured I would start on the decal removal. I'll probably hit a section each day this week. Boy does that factory color look great! Crazy how it's been almost pristine for 30+ years under there.
On 10/26/2021 at 1:20 PM, PocketsEmptied said:
New windshield. It's like seeing in 4k.
For future reference, I ordered it as a '94 windshield (cheaper) and trim fit just fine.
Did you install the windshield or just the trim? I have the same color design trim and debated going to the 98 version with the rubber gasket, as wasnt sure how the trim would fit back..:shhh:
@MiNi Beast Installed the windshield. It's my understanding the rubber trim started in '94 which was what I was hoping to have installed. The installer wouldn't do it though so he put back the old trim. There were some slight bends when put back in place, but nothing crazy. It doesn't lay flat everywhere because of this, but after a week I never paid any attention and works for me.
Started on the NP242 swap today. For not having stubby or ratcheting wrenches, I'd say removal went fairly smoothly....until I got to the last bolt. It seized somehow and took the stud out instead. So I managed to remove the stud and pull the TC off, but now I can't remove the bolt from the stud itself. So I'm off to the hardware store in the morning to buy something to saw it off. Not so sure a cutoff would be smart and not thinking I can fit a Sawzall under there so may need to cut by hand. Might try a stud extractor and just hold the nut with the wrench.
Then I went to swap the vacuum thing for the light since I don't have a harness yet and found out they're two different depths. So I'll have to address the electrical at another time. No big deal there. Honestly, I'd have the 242 in already if it weren't for that stud.
Have you thought about putting a couple more nuts on the stud and tightening them together and use one of those two as a hold with one wrench and wrench off the stuck one(maybe apply some heat)? Another one you could also try if you don’t want to damage the threads is to use a hot glue gun and a pair of vice grips/channel locks and hot glue the stud to either one and see if you can get the nut off that way?
I've already damaged the thread with vise-grips. That didn't seem to work though. It's an $0.83 part so not concerned with damaging it. I just don't have two 9/16"-16 nuts unfortunately or I would have tried that first.
There's a stud that needs removal at the crossmember too and I tried jam-nutting it with no success. So I think I'll head to Autozone tomorrow and get an extractor. But now that I'm thinking about it I guess I could go to ACE and get two nuts to try that first since it's cheaper.
I have a handheld butane torch that I absolutely love for stuck/seized threaded fasteners.  I have found you don't always need to make things super hot to free up.  I heat nuts and bolts frequently with it, with great success.  they are cheap and easy to maneuver and fill.  Just a suggestion.  The studs in the frame can be a real bear due to the buildup of dirt and road debris that collects on top of them over time.  In the past on other trucks I have cut them flush and drilled with decent success.  Usually during drilling they will eventually become thin/ warm enough they will free up and just thread themselves out
Absolutely. I do the same with a torch and some PB or WD40. There is too much oil all over the tunnel to use a flame safely. The stud for the TC has to be cut or removed with a tool. For the crossmember, I just haven’t bothered with it yet. But I want to take the drop off and bolt it back up so I probably won’t remove it.
  • howeitsdone changed the title to 88 LWB Camper Build
