Jesse J Posted April 8, 2021 Author Share Posted April 8, 2021 it doesn't work. got a multimeter though Link to comment Share on other sites More sharing options...
jdog Posted April 8, 2021 Share Posted April 8, 2021 Ok, ohm between the black wire and ground With the key off. If that's 0 ohms check for vvoltage on The blue wire with the lights on. These wires should go to the bottom circuit of the light bulb. Once you've done these we will check the next set Link to comment Share on other sites More sharing options...
Jesse J Posted April 8, 2021 Author Share Posted April 8, 2021 ok explain that too me in a much simpler way kinda confused what I should do Link to comment Share on other sites More sharing options...
jdog Posted April 8, 2021 Share Posted April 8, 2021 Which multimeter do you own? Link to comment Share on other sites More sharing options...
Jesse J Posted April 8, 2021 Author Share Posted April 8, 2021 I think its a fluke 117 Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 8, 2021 Share Posted April 8, 2021 Look for a setting that shows the ohms symbol (google what it looks like). Or read the manual that came with your meter. What your measuring is the resistance or continuity of a wire from end to end. If a wire is damaged it will either have a high resistance reading from end to end or it won’t read at all (most meters display the infinity symbol). Put your meter in whatever mode shows resistance. Then touch both your black and red leads together. You should see 0ohms on the meter meaning that there is no resistance (aka there is a good connection). Now try testing the lines from end to end as mentioned in the previous posts. One lead on one end of the wire and the other lead on the other end of the wire. It doesn’t matter which lead is used in which end. If your still unsure what this process is checkout a YouTube video on measuring resistance with a multimeter. Remember, google is our friend Link to comment Share on other sites More sharing options...
Jesse J Posted April 8, 2021 Author Share Posted April 8, 2021 14 minutes ago, ghetdjc320 said: Look for a setting that shows the ohms symbol (google what it looks like). Or read the manual that came with your meter. What your measuring is the resistance or continuity of a wire from end to end. If a wire is damaged it will either have a high resistance reading from end to end or it won’t read at all (most meters display the infinity symbol). Put your meter in whatever mode shows resistance. Then touch both your black and red leads together. You should see 0ohms on the meter meaning that there is no resistance (aka there is a good connection). Now try testing the lines from end to end as mentioned in the previous posts. One lead on one end of the wire and the other lead on the other end of the wire. It doesn’t matter which lead is used in which end. If your still unsure what this process is checkout a YouTube video on measuring resistance with a multimeter. Remember, google is our friend well yes I get that but just what @jdogI am not quite sure what this part means 2 hours ago, jdog said: The blue wire with the lights on. These wires should go to the bottom circuit of the light bulb. Once you've done these we will check the next set Link to comment Share on other sites More sharing options...
Jesse J Posted April 8, 2021 Author Share Posted April 8, 2021 the black wires are the ground I am confused Link to comment Share on other sites More sharing options...
jdog Posted April 8, 2021 Share Posted April 8, 2021 Black wires are grounds. Let's just stick with that test first. So ohm between the spot where you spliced to the ground behind the taillight. Link to comment Share on other sites More sharing options...
Pete M Posted April 8, 2021 Share Posted April 8, 2021 aren't there wiring diagrams in the factory shop manual? the link in my sign should have a link to the 89, which might be close enough to help. Link to comment Share on other sites More sharing options...
Jesse J Posted April 8, 2021 Author Share Posted April 8, 2021 2 minutes ago, Pete M said: aren't there wiring diagrams in the factory shop manual? the link in my sign should have a link to the 89, which might be close enough to help. I can't find it in the manual I have 4 minutes ago, jdog said: Black wires are grounds. Let's just stick with that test first. So ohm between the spot where you spliced to the ground behind the taillight. ok it says 0.1-0.04 Link to comment Share on other sites More sharing options...
Pete M Posted April 8, 2021 Share Posted April 8, 2021 page 70 of the 88 electrical manual Link to comment Share on other sites More sharing options...
Jesse J Posted April 8, 2021 Author Share Posted April 8, 2021 thanks pete! Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 9, 2021 Share Posted April 9, 2021 2 hours ago, Jesse J said: well yes I get that but just what @jdogI am not quite sure what this part means @jdog asked: “which multimeter do you own”. Logically this would indicate that he is assuming you need help knowing how to use your meter. If you know how to use your meter and perform the test then the type of meter you have is irrelevant. it was in response to your question: “ ok explain that too me in a much simpler way kinda confused what I should do” Now in regards to your ohm test, your looking for the smallest number you get with your reading. So in your case .1 ohms which would indicate good continuity and minimal resistance in that circuit. Link to comment Share on other sites More sharing options...
jdog Posted April 9, 2021 Share Posted April 9, 2021 2 minutes ago, ghetdjc320 said: @jdog asked: “which multimeter do you own”. Logically this would indicate that he is assuming you need help knowing how to use your meter. If you know how to use your meter and perform the test then the type of meter you have is irrelevant. it was in response to your question: “ ok explain that too me in a much simpler way kinda confused what I should do” Now in regards to your ohm test, your looking for the smallest number you get with your reading. So in your case .1 ohms which would indicate good continuity and minimal resistance in that circuit. Yep that was my thinking Link to comment Share on other sites More sharing options...
jdog Posted April 9, 2021 Share Posted April 9, 2021 Ok with the meter set to voltage, black lead on ground, red lead on the blue wire what does the meter say, now do it again with the headlights on. Link to comment Share on other sites More sharing options...
Jesse J Posted April 9, 2021 Author Share Posted April 9, 2021 ok thanks guys. blue wire to ground is about 11 volts Link to comment Share on other sites More sharing options...
Jesse J Posted April 9, 2021 Author Share Posted April 9, 2021 with the headlighs on. headlights off zero Link to comment Share on other sites More sharing options...
jdog Posted April 9, 2021 Share Posted April 9, 2021 on both sides or just one? Link to comment Share on other sites More sharing options...
Jesse J Posted April 9, 2021 Author Share Posted April 9, 2021 both Link to comment Share on other sites More sharing options...
Pete M Posted April 9, 2021 Share Posted April 9, 2021 see, if this was my project I'd be jumping up and down because something went right. now we build on it. Link to comment Share on other sites More sharing options...
Jesse J Posted April 9, 2021 Author Share Posted April 9, 2021 yeah I was pretty excited Link to comment Share on other sites More sharing options...
jdog Posted April 9, 2021 Share Posted April 9, 2021 ok black lead on the ground, red on the gray wire with the turn signal on and key on, should have voltage. Link to comment Share on other sites More sharing options...
Jesse J Posted April 9, 2021 Author Share Posted April 9, 2021 no voltage Link to comment Share on other sites More sharing options...
jdog Posted April 9, 2021 Share Posted April 9, 2021 key on? ok check the other side with the turn signal turned to the right side Link to comment Share on other sites More sharing options...
