Warren99 Posted January 18, 2021 Share Posted January 18, 2021 So I'm basically making observations and asking if I'm right. It looks to me like my truck came with the big chrome tow mirrors at some point, because you can see the top set of holes lined up with the window frame. And the PO mounted random mirrors in front of them on the door skin(the broken plastic). I've looked forever and just can't find any good mirrors from a junkyard, so if I just buy some manual ones from rockauto(I don't care about having the joystick on the inside), they should just bolt on and I keep the little triangle cover pieces that are on the inside, correct? Link to comment Share on other sites More sharing options...
Warren99 Posted January 18, 2021 Author Share Posted January 18, 2021 Half the reason I'm making sure that they will go on right is because it mentions needing self-tapping screws for it. I was looking at the Various MFR ones but now they only have a right one. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 18, 2021 Share Posted January 18, 2021 All aftermarket mirrors are crap. Mostly because they aren’t threaded and when you thread them yourself, the bolts will spin the threads and not tighten the mirror down to the body. OEM is recommended for mirrors for that reason. Link to comment Share on other sites More sharing options...
Warren99 Posted January 18, 2021 Author Share Posted January 18, 2021 Ok, but with that being said, is there anywhere that makes them good still, because I just can't find any at a salvage yard. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 18, 2021 Share Posted January 18, 2021 Personally I don’t have any recommendations aside from OEM. I thought about trying quadratecs in house mirrors but didn’t. Link to comment Share on other sites More sharing options...
rylee144 Posted January 18, 2021 Share Posted January 18, 2021 try car part. here is a link to the page that allows you to add what type of mirrow you want. https://www.car-part.com/cgi-bin/search.cgi Link to comment Share on other sites More sharing options...
Warren99 Posted January 18, 2021 Author Share Posted January 18, 2021 2 minutes ago, rylee144 said: try car part. here is a link to the page that allows you to add what type of mirrow you want. https://www.car-part.com/cgi-bin/search.cgi Ok Link to comment Share on other sites More sharing options...
rylee144 Posted January 18, 2021 Share Posted January 18, 2021 prolly cheapest to go on market place and find a Cherokee part out prolly get a set for $20-$30 Link to comment Share on other sites More sharing options...
Warren99 Posted January 18, 2021 Author Share Posted January 18, 2021 Yeah probably. At salvage yards, if one has any at all, theres only one and the frame pivot points are busted. Link to comment Share on other sites More sharing options...
Warren99 Posted January 18, 2021 Author Share Posted January 18, 2021 And as for car-part, the cheapest one I can find is $55, for one mirror. Link to comment Share on other sites More sharing options...
schardein Posted January 19, 2021 Share Posted January 19, 2021 I'm not sure I understand what you want, but maybe this is an option- get mirrors off a 97-01 XJ. They are a different shape which might not be good if you are trying to stay original. But they are available, finding late model XJs in the JY isn't hard. Get some power mirrors, and just tuck the wires back into the mirror or cut them off. You can still adjust the actual mirror glass by hand. While this is a fairly common swap, I've found that few mention the need to pull the outer window trim off and slightly modify it to let the mirror sit flush on the door. I had to do that on my XJ and MJ, but perhaps in varies from one vehicle to the next. On my XJ, I was able to adapt the slightly different wiring to work with the factory XJ power adjust mirror switch. Link to comment Share on other sites More sharing options...
thecodemonk Posted January 19, 2021 Share Posted January 19, 2021 97+ mirrors are also bigger than the 96 and earlier ones, giving added visibility. Link to comment Share on other sites More sharing options...
89 MJ Posted January 19, 2021 Share Posted January 19, 2021 My blue truck has OEM mirrors in the 84-96 flavor. The truck is my daily driver and I am yet to think, gosh, I wish my mirrors were bigger. I also think that the 84-96 mirrors are better looking. I have even pulled a trailer with my truck and visibility was fine. In my opinion, you should just find mirrors that you like and go with those. Link to comment Share on other sites More sharing options...
Warren99 Posted January 19, 2021 Author Share Posted January 19, 2021 Yeah I have considered getting newer ones before but I just like the old style so much more. Link to comment Share on other sites More sharing options...
schardein Posted January 20, 2021 Share Posted January 20, 2021 20 hours ago, 89 MJ said: My blue truck has OEM mirrors in the 84-96 flavor. The truck is my daily driver and I am yet to think, gosh, I wish my mirrors were bigger. I also think that the 84-96 mirrors are better looking. I have even pulled a trailer with my truck and visibility was fine. In my opinion, you should just find mirrors that you like and go with those. I understand a desire to retain the factory look. But I can tell you that after driving a 2000 XJ for a number of years with the larger mirror and no vent window bar blocking the view, going back to a 84-96 style is a noticeable downgrade from a functional standpoint. Link to comment Share on other sites More sharing options...
Minuit Posted January 20, 2021 Share Posted January 20, 2021 For those stubborn ones of us insistent on keeping the 84-96 square mirrors (now that I found a good power set and installed them in my truck, I damn sure ain't taking them out for a while), I found that sticking on a rectangular blind spot mirror in the top corner helps greatly. My idea was so brilliant that Ford actually copied it from me and built it into their mirrors. Link to comment Share on other sites More sharing options...
Eagle Posted January 20, 2021 Share Posted January 20, 2021 2 hours ago, schardein said: I understand a desire to retain the factory look. But I can tell you that after driving a 2000 XJ for a number of years with the larger mirror and no vent window bar blocking the view, going back to a 84-96 style is a noticeable downgrade from a functional standpoint. I disagree. Having owned (and still own) and driven XJs and MJs since 1988, despite the 2000 side view mirrors being slightly larger I don't notice any functional difference between the old mirrors and the new mirrors. Link to comment Share on other sites More sharing options...
Warren99 Posted January 20, 2021 Author Share Posted January 20, 2021 Like I said, I rly just can't find any at a JY, I'm about to buy aftermarket ones or get the newer style and hope it doesn't look too off. Are the aftermarket really that bad? Link to comment Share on other sites More sharing options...
Warren99 Posted January 20, 2021 Author Share Posted January 20, 2021 Aftermarket as in old style. Link to comment Share on other sites More sharing options...
89 MJ Posted January 21, 2021 Share Posted January 21, 2021 4 hours ago, Warren99 said: Like I said, I rly just can't find any at a JY, I'm about to buy aftermarket ones or get the newer style and hope it doesn't look too off. Are the aftermarket really that bad? I have a set of sell you. Link to comment Share on other sites More sharing options...
Warren99 Posted January 22, 2021 Author Share Posted January 22, 2021 On 1/20/2021 at 9:21 PM, 89 MJ said: I have a set of sell you. What kind? Link to comment Share on other sites More sharing options...
89 MJ Posted January 22, 2021 Share Posted January 22, 2021 5 minutes ago, Warren99 said: What kind? OEM. I can PM you a pic this weekend. Link to comment Share on other sites More sharing options...
Warren99 Posted January 22, 2021 Author Share Posted January 22, 2021 Just now, 89 MJ said: OEM. I can PM you a pic this weekend. Ok. Are they manual or cable. Also I don't care too much about the condition as long as the metal case ain't cracked in half or something dumb. Link to comment Share on other sites More sharing options...
89 MJ Posted January 22, 2021 Share Posted January 22, 2021 2 hours ago, Warren99 said: Ok. Are they manual or cable. Also I don't care too much about the condition as long as the metal case ain't cracked in half or something dumb. They are manual. Link to comment Share on other sites More sharing options...
Warren99 Posted January 22, 2021 Author Share Posted January 22, 2021 3 minutes ago, 89 MJ said: They are manual. Ok perfect. And just to clarify they are the old style 84-96 right? Link to comment Share on other sites More sharing options...
