Muncher Posted December 8, 2020 Share Posted December 8, 2020 Can some tell me what tooth count I need for a speedo gear in my transfer case? I have a 87 5 speed if that helps at all Link to comment Share on other sites More sharing options...
87MJTIM Posted December 8, 2020 Share Posted December 8, 2020 You need the diff. gear ratio and tire size to determine the tooth count. Search the internet for the proper size gear. Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 8, 2020 Share Posted December 8, 2020 Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 8, 2020 Share Posted December 8, 2020 tire size helps the equations as well Link to comment Share on other sites More sharing options...
derf Posted December 8, 2020 Share Posted December 8, 2020 3.07 with 205/75R15 = 31 3.07 with 225/75R15 = 30 3.55 with 205/75R15 = 36 3.55 with 225/75R15 = 34 This could possibly vary depending on the exact tire you get as tires aren't exactly the same. But an average sampling of the tire sizes pops out those results. Link to comment Share on other sites More sharing options...
Muncher Posted December 9, 2020 Author Share Posted December 9, 2020 1 hour ago, MiNi Beast said: This does help. I think I'll just get one for 4.10 gears and 33 inch tires because that is the plan in the long term. Link to comment Share on other sites More sharing options...
Muncher Posted December 9, 2020 Author Share Posted December 9, 2020 Would this work? Its a 33 tooth long shaft. Says it works for 53 to 90 jeeps but just wanna make sure Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 9, 2020 Share Posted December 9, 2020 19 minutes ago, Muncher said: This does help. I think I'll just get one for 4.10 gears and 33 inch tires because that is the plan in the long term. thats the idea. or for those that care you can just run a standalone gps for mph. just what i do. Link to comment Share on other sites More sharing options...
Sir Sam Posted December 10, 2020 Share Posted December 10, 2020 Another option is to check with gps how far off you are, pull your current gear tooth and then do the math to see what your ideal tooth count is, and then decide what to order, I prefer to have my speedo read a little high to help avoid speeding a little too much. Link to comment Share on other sites More sharing options...
JMO413 Posted December 10, 2020 Share Posted December 10, 2020 Most smart phones will be able to get an app for GPS speedometer. I have one on my phone that I used before I changed my speedometer gear. My speedo is now spot on. I used a chart very similar to the one above. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted December 11, 2020 Share Posted December 11, 2020 And don’t forget to get a tape measure to get your actual tire size. Most 33’s are 32’s or even 31’s when new. Link to comment Share on other sites More sharing options...
75sv1 Posted December 11, 2020 Share Posted December 11, 2020 I think Iron Rock list what their speedo gears work with. Link to comment Share on other sites More sharing options...
