89 MJ Posted November 30, 2020 Share Posted November 30, 2020 Has anyone found a source for replacement heater hoses? I haven’t been able to find some yet. Thanks Link to comment Share on other sites More sharing options...
jdog Posted November 30, 2020 Share Posted November 30, 2020 open or closed system? Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 30, 2020 Share Posted November 30, 2020 Want some part numbers? That’s how I found one for my AC setup. Its a Gates hose but it was cut to fit and it was bent where it was needed to be. Link to comment Share on other sites More sharing options...
gogmorgo Posted November 30, 2020 Share Posted November 30, 2020 You can still get the molded hoses for a ‘97+ XJ, with the open system and heater valve delete, if that’s the way you want to go. If not, bulk heater hose cut to fit will work a treat. Link to comment Share on other sites More sharing options...
89 MJ Posted November 30, 2020 Author Share Posted November 30, 2020 13 minutes ago, jdog said: open or closed system? Closed 11 minutes ago, eaglescout526 said: Want some part numbers? That’s how I found one for my AC setup. Its a Gates hose but it was cut to fit and it was bent where it was needed to be. Yes please! 11 minutes ago, gogmorgo said: You can still get the molded hoses for a ‘97+ XJ, with the open system and heater valve delete, if that’s the way you want to go. If not, bulk heater hose cut to fit will work a treat. Thanks Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 30, 2020 Share Posted November 30, 2020 1-52003880 2-52003881 4-52003882 5-52003876 6-52003877 7-52003878 Assuming you have retained all the Renix set up, these are the numbers. Link to comment Share on other sites More sharing options...
89 MJ Posted November 30, 2020 Author Share Posted November 30, 2020 17 minutes ago, eaglescout526 said: 1-52003880 2-52003881 4-52003882 5-52003876 6-52003877 7-52003878 Assuming you have retained all the Renix set up, these are the numbers. Thank you! Link to comment Share on other sites More sharing options...
1989commanche Posted November 30, 2020 Share Posted November 30, 2020 I just called up NAPA and told them I need one of each. Delivered next day. Link to comment Share on other sites More sharing options...
89 MJ Posted November 30, 2020 Author Share Posted November 30, 2020 7 hours ago, 1989commanche said: I just called up NAPA and told them I need one of each. Delivered next day. Thank you Link to comment Share on other sites More sharing options...
Dave Vig Posted January 7, 2021 Share Posted January 7, 2021 Hope some one sees this because I need the same hoses as well. But! The hose have those strange clamps they are not your typical clamp that you turn with a flat head screw driver. If anyone knows what I’m talking about. How do you take them off?? Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 7, 2021 Share Posted January 7, 2021 2 minutes ago, Dave Vig said: If anyone knows what I’m talking about. How do you take them off?? Those are spring clamps that are probably original to the truck. Use a pair of channel locks and squeeze the two tabs together to release the tension to slide the clamp off. Link to comment Share on other sites More sharing options...
Dave Vig Posted January 7, 2021 Share Posted January 7, 2021 Ok great and to replace them can I use your typical clamp that you turn with a screwdriver? Also all those hose numbers that are listed up above are those part numbers? Like from Napa ? Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 7, 2021 Share Posted January 7, 2021 10 minutes ago, Dave Vig said: Ok great and to replace them can I use your typical clamp that you turn with a screwdriver? Also all those hose numbers that are listed up above are those part numbers? Like from Napa ? Yes you can and no. Those are Mopar numbers. You can plug those numbers into Napa and see if they cross reference. Otherwise you can still go to the dealer and get them. Link to comment Share on other sites More sharing options...
Dave Vig Posted January 7, 2021 Share Posted January 7, 2021 They are mopar part numbers ok great damn thank you so much. And I can use a standard clamp then right? How do I register my Comanche on here? This forum is great Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 7, 2021 Share Posted January 7, 2021 19 minutes ago, Dave Vig said: They are mopar part numbers ok great damn thank you so much. And I can use a standard clamp then right? How do I register my Comanche on here? This forum is great Yup and no problem! Yes those standard clamps will do just fine unless you want to retain the factory appearance under the hood. To register your MJ just simply find the year yours is, go into that subforum and start a new thread with the title as your VIN and then I will run the VIN and get you a build date and sheet. Link to comment Share on other sites More sharing options...
Dave Vig Posted January 7, 2021 Share Posted January 7, 2021 Ok thank you I will do that now. Appreciate your help Link to comment Share on other sites More sharing options...
Ωhm Posted January 7, 2021 Share Posted January 7, 2021 ADD A SIGNATURE: When LOGGED-IN. Go to upper right hand corner of screen. Click on Username. Click on Account Settings. Find and click on Signature. Add vehicle information here (YR, ENG, TRANS, etc, etc) then click on SAVE. This helps everyone. This information will be available every time you post. Link to comment Share on other sites More sharing options...
