5x5 bolt pattern with WJ swap
4 hours ago, saveevryjp1998 said:
You are lucky. I am yet to see a jk hit a chain yard around here or small yard or at least up until last year. The lkq linked places get them along with the specialty part out yards. I'm sure there has been rare times but I've never been that fortunate enough to stumble on it yet. That stuff is high dollar, sells down to the last bolt usually, and more often sell whole for rebuilt titles whenever possible still for ridiculous money. I've seen the eBay sets you might be referring to as cheap. They also are China if you dig deeper without good or any seller reviews. There are some though that look reputable at 80 roughly per side with free shipping. That's still too much and more than much easier sourced wj parts.
haha no, that was a typo. I mean a dozen WJs.
I do see Jks on occasion, but they are usually really phucked up. I did see a rubicon recently. Someone snagged the rear before I could and the front was in a number of pieces.
  • 3 years later...
I am running the WJ Big Brakes. So, WJ knuckles with a 1/4 spacer. Then using the WJ Akebono Calipers. I also need to space out 1/4 for the Brake Caliper bracket. On mine with 5 on 5, I use WJ Rotors. That is with the WJ Hub Bearings. Also, use WJ lower ball joints. I see a lot of threads going in different directions. Some of them scare me. If people need a list or so. I'll post more info.
Good to know. I’m curious if we could use WJ hubs directly on XJ/Mj knuckles for the 5x5 pattern with appropriately drilled/sourced rotors without swapping to the other WJ components. I’m running a big brake kit at the moment with wk2 calipers. I need to see if I can find someone a the parts store that will let me measure some different options.
I have gone that route. Also, I think you would be running the early XJ knuckles. Cobra Marty had some write ups about that. I think he went even larger diameter rotor. I remember Dodge Dakota Rotors. Mustang GT calipers and 3/4 spacers. I want to say he used XJ hub bearings. The WJs are basically the same, except the 5 on 5. I use Rock Auto to get dimensions.
     I was/ am looking to use WJ Hubs, Dakota Rotors or later Jeep rotors to get a 13 inch rotors and use WJ hubs. I might try and go to 5 on 5.5. Thinking on of the later JKs or such would have the hubs etc.
That’s right. I’m running pre 90 knuckles with late model XJ HP30. I’m using 14’ GC calipers and brackets on 04’ Explorer rotors. I’m also interested in going to a 13” rotor. It’s a tricky part of my built atm as I try to sort wheel size, backspacing, brakes and steering. I’m running a KJ 8.25 rear with disks which is 63” wms. The track width is great in back as it fills out the wheel wells much nicer. Currently I have 1.25 spacers for the front to match the overall wms of the back but not sure if I’ll keep it that way. Looking for some wheels with the right bolt pattern and backspacing (around 5”). The tire debate is endless as well. Trying to go with at least metric 32’s but 33’s are a possibility if I go notch flares… too many options :brickwall:
So ultimately the question still remains. Perhaps we can put this to rest once and for all. Has anyone just installed WJ unit bearings on the XJ/MJ knuckle to accomplish the 5x5 bolt pattern? Not swapping on the WJ knuckles, steering or brakes, just the unit bearing. We know the spline count fits, we know it fits inside the XJ knuckle but the question is does it center the u joint when installed on that knuckle. Or is a spacer required to bump it out?
I think the spacer is required to keep the ball joints and the u joint in the shaft assembly aligned properly. A long while back I had all the parts sitting around that I started bolting it all together to see what’s what. It all physically went together, but there was binding in the joints when rotating through a turn. I never had the setup on the road though… only mocked on jack stands.
What’s interesting is that the WJ conversion using WJ knuckles still uses XJ/MJ unit bearings. Since the only thing changing is the knuckle, it would be logical that the 1/4” spacer is used to correct the knuckle and not the unit bearing. That would make it seem like a wj 5x5 pattern could be had simply by replacing the unit bearing with the WJ version but keeping the XJ knuckles. Someone just needs to get one and try it :holdwrench:
I think the WJ and 2000-01 XJ units are closer to width. I do not think you will need the weld on spacer. I did look into adapting to later XJ knuckles, not know the earlier XJ/MJ knuckles had bolt caliper brackets.
