A/C problem
I just replaced all the components under the hood on my a/c system, I brought to my local repair shop to get the a/c system charged. The compressor is not receiving any power.  I started trouble shooting and when  I turned on the a/c to max and turned on blower, the air only comes out of the defrost and not the vents.
Any tips on fixing that problem.
Did you check the relay?
How does your vac lines from the canister under the bumper t the fire wall look?
There are several air gates under the dash that direct air to different air vents. Engine needs to be running to provide vacuum to dashpots to open or close them. eaglescout526 is telling you to look for vacuum leaks.
  LOOK FOR
  AC fuse blown, the fuse is 25 amps and I have seen several that weren't making good contact in the fuse box
  Wires not hooked up / bad connection to the low pressure switch
  Check the AC relay, is the relay getting power, is it working?
  Run 12V to the AC compressor to see if the clutch works
   A list of all of the parts you replaced might help.
On 7/11/2020 at 8:08 AM, Richard 91 said:
I have the dash apart but cannot figure out how to remove glove box the white vac line coming out by coolant lines is no good trying to find where it comes through fire wall.
No need to go that far into the system unless you want to replace the evaporator core. Just check for vacuum going through the firewall where the ac lines connect to the expansion valve. That vacuum line feeds the vacuum for the hvac switch panel.
One line goes to the heater valve and the other line runs to the vac reservoir behind the front bumper on the passenger side. I believe the gray/purple one goes to the vac cannister and the black should go to the heater valve. Youll have to see if your vac lines are still present and haven't been dry rotted out.
I JUST GOT MY TRUCK BACK FROM THE SHOP, THEY HAVE SERVICED THE A/C GOOD NEWS NO LEAKS BAD NEWS IS THE LOW PRESSURE READS HIGH AND THE HIGH PRESSURE IS LOW, MECHANIC THINKS THERE IS A BLOCKAGE SOMEWHERE. ALL HOSES, COMPRESSOR, DRIER, EXPANSION VALE AND CONDENSER  ARE NEW AND I BLEW OUT THE EVAPORATOR  COIL WITH AIR. THE ONLY THING I CAN THINK OFF IS THE LINE WITH THE MUFFLER ON IT WAS REBUILT BY JEEP AIR SO MAYBE THE MUFFLER IS CLOGGED. ANYONE WITH OTHER IDEAS?
Low pressure high and high pressure low, as in both pressures are the same or close to the same, means you have a bad compressor. Was the expansion valve replaced? It could also be clogged. Were all lines flushed to include the condenser and evaporator?
A good system drops air temp at the central air vent about 40 degrees from ambient,, when the doors are open and the control is on maximum. If you have some cooling, but not what you should have, I'd think the system is over-oiled. Sometimes, that can happen. One tech does one thing, adds oil but doesn't tell anyone, the next tech adds more, not knowing it's already been done. Or, a compressor comes pre-oiled and someone adds more. Another thing to check is if the compressor had oil added to it but not cycled through by manually turning the clutch plate and shaft. I usually install the freshly oiled compressor, hook up the lines, then hand-turn the clutch plate to run the oil through the cylinders and out to the discharge line.
