70barracuda Posted June 14, 2020 Posted June 14, 2020 Parting out an 1986 long bed. Bed is pretty shot along with everything underneath. It's a 2.8 with a 5 speed with 40k on the odometer. Dana 30 front AMC 20 rear. I was told it's true. Engine started up and it actually ran pretty good. unsure of trans condition, it didn't work when I bought it don't know issue. Pictures are where it stands today. I bought it for the interior and some small stuff. I'll list some stuff with prices but if what you need isn't there just ask and shoot me an offer. It's going to the scrapper eventually. All prices are OBO, I'm going off eBay for base prices. Shipping is on buyer. Tree fell on truck, rear window smashed. Interior gone, but I do have a grey dash and honey trim pieces if wanted. Steering wheel and clutch parts are sold. Mirrors broken. Flip windows are rotted out. Tail lights busted. Bed liner is rough. Vinyl floor is shot. Seat brackets are shot. All I can remember for now. Bench seat - $200 (Pretty good shape, small tears on driver side) Cargo light with switch - $175 Gauge cluster - $75 sold (Gauges worked, trip odometer is stuck) Shifter bezel - $50 Radio - $50 sold Seat belts - sold 4x4 linkage - sold
70barracuda Posted September 18, 2020 Author Posted September 18, 2020 Going to junkyard with this thing soon. Pictures of how it sits today. I've pulled everything I can think of worth it. If you see anything else you want just ask.
eaglescout526 Posted September 18, 2020 Posted September 18, 2020 Some people are apparently looking for the wing glass.
70barracuda Posted September 18, 2020 Author Posted September 18, 2020 1 hour ago, 89 MJ said: Saving the mirrors wouldn’t hurt. They are trashed unfortunately. 43 minutes ago, eaglescout526 said: Some people are apparently looking for the wing glass. The bottom pin is rusted out on both. Trust me, if they were good they'd be on mine already lol
eaglescout526 Posted September 19, 2020 Posted September 19, 2020 15 minutes ago, 70barracuda said: The bottom pin is rusted out on both. Trust me, if they were good they'd be on mine already lol Fair enough.
fiatslug87 Posted September 19, 2020 Posted September 19, 2020 Did you post this one in the registry?
ghetdjc320 Posted September 20, 2020 Posted September 20, 2020 I’d like the passenger side window regulator. Sending PM
500 MJ Posted September 20, 2020 Posted September 20, 2020 Inner and outer cab vents should be saved. Especially the inners. Also Jeep letters on the front header panel are easy to pull and no longer available from Mopar... Also, center pane from the rear window and the rear window outer rubber gasket. Center pane could put into a window that has a broken one, seen many times that the center pane is broken and plexiglas is put in there...
JMO413 Posted September 20, 2020 Posted September 20, 2020 And chance the seal for the slider is good? I need one. Mine is missing a chunk.
70barracuda Posted September 21, 2020 Author Posted September 21, 2020 3 hours ago, 500 MJ said: Inner and outer cab vents should be saved. Especially the inners. Also Jeep letters on the front header panel are easy to pull and no longer available from Mopar... Also, center pane from the rear window and the rear window outer rubber gasket. Center pane could put into a window that has a broken one, seen many times that the center pane is broken and plexiglas is put in there... Cab vents have been pulled. Outter ones are chipped but the inner are in amazing condition. Jeep badge will be pulled. Someone painted it with crappy black paint but it's decent. Rear window was smashed pretty bad but that center slider is still whole. I'll try and pull that. 3 hours ago, JMO413 said: And chance the seal for the slider is good? I need one. Mine is missing a chunk. I'll check the shape of that tomorrow.
Archived
