Various parts
ghetdjc320
Looking for a few final touches for my MJ:
Rear mud flaps (all black Jeep logo style or would also consider a set of fronts I can trim to fit the rear)
Drivers side kick panel (any color since I have the interior dye already)
Dash clock for my 91 (my original wiring is still there and ready to plug in)
Thanks!
I have some used front mud flaps if they are of any interest to you? I can toss some pictures up tonight. I also think I have a set of new XJ rears. These are all the plastic type with no AMC logo on them...
Also, I could get a drivers kick panel for you if no one else offers one up. I am hoping to make a quick yard trip on Friday this week... if you could choose a color, what would it be?
Grey would be preferable. I have a modified xj kick panel currently but need to get the mj specific one. Send me pics of what you have for mud flaps. The fronts can be trimmed to look like oem rears easier than the xj rears. Thanks!
Here is the one that I am thinking to grab the kick panel out of. This would be gray. There is another one there that should be maroon if this one is gone or damaged. This gray one would be perfect to paint as it has had some sun exposure and is faded a bit.
Just to be certain, you are needing the piece that goes from the door sill to the B-Piller? Other side, but what is circled here in this photo? Capture20.JPG.2c060c21feae38bd3507de0212d831d5.JPG
Expand
i actually need the panel that goes where the parking brake is. It’s a sort of triangle shaped piece. You can see the passenger one under the dash. The sill piece you highlighted runs right into it and they overlap a bit
Expand
Ok got it. You said MJ specific and now that makes sense. Forgot about the parking brake on that side, which makes it unique. It should be there, if not I am 99% certain the maroon one will be there.
I'm all but certain the factory "MJ" kick panel is just an XJ one they cut a radius out of to clear the parking brake. If you had some equipment (or hell, a band saw and a steady hand) and knew the dimensions of the cut you could produce a perfect MJ kick panel out of an XJ one.
  On 5/27/2020 at 4:17 PM, Gjeep said:
If you look on the back side of an XJ driver's side kick panel '86-'93 there is a curved line for the exact cut for the MJ foot brake pedal sweep.
Expand
the one I have is a trimmed xj version but I does not fit well. I’d like to get the mj specific one still
Expand
Bad news on my end. The yard that I hoped to hit tomorrow is still closed thanks to COVID. So no access to those MJs for that kick panel.
I am changing my plans to go to a different yard tomorrow, this one I know has a 2 door '92 XJ. It might have the dash clock and the kick panel. Do you have a reference pic for the clock (and electrical plug that is needed) that you want so I can make sure it will be the correct one? Also, Let me know if another XJ kick panel is of interest to you, if it has the line on it for where to cut maybe you'd want to go that route? Sorry that my local MJ resource is not available right now...
I'll PM you with pics and prices of the splash guards I have.
