jdog Posted December 14, 2020 Share Posted December 14, 2020 4 minutes ago, eaglescout526 said: Yeah it is absolutely an anomaly. So I’ll be going back tomorrow to install a few things and clean up some contacts with my drill wire brush. I also need to figure out why the front headlamps aren’t getting any power. I suspect the headlamp fuse on the switch is popped but wouldn’t I not have markers or rear lights? Suppose I need to spend a full day looking at the t-bird forums. I don't think they had a fuse on the lights, maybe a breaker. I'd suspect either a bad switch or a bad high beam switch Probably the latter Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 14, 2020 Author Share Posted December 14, 2020 Probably. It’s on the list of stuff to figure out. First thing first though is to fire her off. Then worry about petty electrical later. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 14, 2020 Author Share Posted December 14, 2020 Tank is in, some contacts have been cleaned up. Going to get some gas, blow out the gas line and hope the current pump works as I have discovered it’s been changed once already. Link to comment Share on other sites More sharing options...
89 MJ Posted December 15, 2020 Share Posted December 15, 2020 Dang, you have quite the fleet of older vehicles. What are the plans when this one is running and driving? Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 15, 2020 Author Share Posted December 15, 2020 10 minutes ago, 89 MJ said: Dang, you have quite the fleet of older vehicles. What are the plans when this one is running and driving? At this rate, I might sell it. It’ll just depend if I can get it running any time soon. Link to comment Share on other sites More sharing options...
89 MJ Posted December 15, 2020 Share Posted December 15, 2020 1 hour ago, eaglescout526 said: At this rate, I might sell it. It’ll just depend if I can get it running any time soon. Gotcha. You gotta do what you gotta do. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 15, 2020 Author Share Posted December 15, 2020 10 minutes ago, 89 MJ said: Gotcha. You gotta do what you gotta do. Pretty much. Link to comment Share on other sites More sharing options...
Pete M Posted December 15, 2020 Share Posted December 15, 2020 there is literally no reason why you can't get this car driving. just gotta slay each gremlin, one at a time. Link to comment Share on other sites More sharing options...
89 MJ Posted December 15, 2020 Share Posted December 15, 2020 1 minute ago, Pete M said: there is literally no reason why you can't get this car driving. just gotta slay each gremlin, one at a time. Or at least just slay the major gremlins. Don't sweat the small stuff yet. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 15, 2020 Author Share Posted December 15, 2020 Oh I’m not. It’s just tedious and a bit challenging when the car isn’t readily accessible but that’s more on my schedule. I should have it running once I get the starter replaced and the fuel line clear. The weirdest part is if I pour some gas down the carb and crank it, it acts like the gas is stopping it from cranking and slows up. I plan to pour some oil down into the crankcase and I may get back at it on Christmas weekend. Guess the holiday stress is hitting me. Link to comment Share on other sites More sharing options...
Pete M Posted December 15, 2020 Share Posted December 15, 2020 the car isn't getting any worse by patiently sitting a bit longer. unless mice move in. don't let that happen. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 15, 2020 Author Share Posted December 15, 2020 I’m not worried about that so much as I am worried that I won’t have the car running before my grandparents move out. Now if I can rent the house from them, then I wouldn’t have to worry so much. Link to comment Share on other sites More sharing options...
JMO413 Posted December 16, 2020 Share Posted December 16, 2020 I just reread this who thing. Did you change the points and condenser yet? If not that is a definite before trying to stay again. Points are finicky to say the least. If it's sat that long I would guess they are shot. Both are cheap to replace. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 16, 2020 Author Share Posted December 16, 2020 I can't say I recall doing anything to the points set up. I thought I sanded the contacts but perhaps I did not. But I can say that I didnt change them. I will have to take a look at them and see what their shape is. Link to comment Share on other sites More sharing options...
JMO413 Posted December 16, 2020 Share Posted December 16, 2020 For $25 if you buy the good stuff is well with the money. IMHO Definitely make sure the points are set correctly or it will never start. I've owned 3 cars and 1 motorcycle that had points when I got them. None had them when I was done. We when swapped a Pertronix in the fork truck at work. Link to comment Share on other sites More sharing options...
Pete M Posted December 16, 2020 Share Posted December 16, 2020 here, this should fix your points once and for all Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 16, 2020 Author Share Posted December 16, 2020 Points from what ive seen and read is finicky but reliable once it is set right. I am willing to bet that is my problem as it the engine fires on a few cylinders. Ive been spoiled by Renix. LOL!! Gotta find one. Maybe those 2006ish 1500's that had the Viper engine in them will suffice. If I found a V10 cheap enough I would do the swap. Be a very fast T-bird. Link to comment Share on other sites More sharing options...
jdog Posted December 16, 2020 Share Posted December 16, 2020 nah just go with this https://www.jegs.com/i/Ford-Performance/397/M-6007-A50SC/10002/-1 points are good as long as you set and adjust/change them out. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 16, 2020 Author Share Posted December 16, 2020 Might as well get the 427 at that point lol. Or better yet, swap out the New Yorkers 400ci engine lol. Link to comment Share on other sites More sharing options...
89 MJ Posted December 16, 2020 Share Posted December 16, 2020 50 minutes ago, eaglescout526 said: Ive been spoiled by Renix. I’ll bet that’s the first time anyone has said that! Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 13, 2021 Author Share Posted January 13, 2021 On 12/15/2020 at 9:00 PM, 89 MJ said: I’ll bet that’s the first time anyone has said that! Huh, I missed this but yes I will admit I have been a bit spoiled by such. Now on to some issues. Christmas day I went and cleaned all contacts for the points and that was it. Didnt try anything else. Came back today, cranked her over, can't tell if the starter hates life or if the engine doesnt like cranking while making compression. Might crack open the valve covers and just watch the action of all the lifters...that being said I took out all the spark plugs and each one has fired at least a few times as they are pretty damn black in color. I confirmed I am getting a good strong spark, it just seems like the starter needs to be replaced. But with the plugs out, itll crank all damn day without an issue. So not sure where to go with that other than replace the starter. I cleaned all the grounds and contacts. the batter cables get warm with resistance which could indicate the starter going out. Any ideas yall? Link to comment Share on other sites More sharing options...
jdog Posted January 13, 2021 Share Posted January 13, 2021 How are the cables? Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 13, 2021 Author Share Posted January 13, 2021 Ground was replaced after its melt down, surface was cleaned before installed. Power is alright, its cleaned up. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 26, 2021 Author Share Posted January 26, 2021 Well I am on the right track for pumping fuel into the carb rather than dumping fuel into the carb. It seems to cooperate better and comes close for starting. I think I am going to have to replace the starter and get a better battery. I don’t think the starter is up to the task of cranking that beast anymore. Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 31, 2021 Author Share Posted January 31, 2021 GUESS WHAT?! Link to comment Share on other sites More sharing options...
