ghetdjc320 Posted August 10, 2021 Author Share Posted August 10, 2021 Progress Link to comment Share on other sites More sharing options...
MiNi Beast Posted August 10, 2021 Share Posted August 10, 2021 You make it look so simple. Chop,cut, and rebuild! looks great. Nice job. You gots skillz. Link to comment Share on other sites More sharing options...
howeitsdone Posted August 10, 2021 Share Posted August 10, 2021 Looks awesome! Seems like the pan fit well. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 10, 2021 Author Share Posted August 10, 2021 4 minutes ago, PocketsEmptied said: Looks awesome! Seems like the pan fit well. They fit pretty well for aftermarket pans. The designs are definitely XJ. There sure are a lot of ways to increase the unibody strength that become apparent when the pans are out. Link to comment Share on other sites More sharing options...
howeitsdone Posted August 10, 2021 Share Posted August 10, 2021 I bet you could easily put slats in the frame rails. Or even drop some square tubing in there. Also looks like you cut out the mounting bolt and then welded back in. Any particular reason or was it just easier? Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 12, 2021 Author Share Posted August 12, 2021 More work. Had to make several patch panels for the inner rocker panel and the floor pan where it curves up to the firewall Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 12, 2021 Author Share Posted August 12, 2021 On 8/10/2021 at 11:52 PM, PocketsEmptied said: I bet you could easily put slats in the frame rails. Or even drop some square tubing in there. Also looks like you cut out the mounting bolt and then welded back in. Any particular reason or was it just easier? The replacement pans are for an XJ which doesn’t have the upper brace with the seat mounting stud in it. The pan is fairly long and needs to be sandwiched under that upper frame casing. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 12, 2021 Author Share Posted August 12, 2021 Nice clean new metal. Just finished applying all the seam sealer now. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 13, 2021 Author Share Posted August 13, 2021 Removed the remaining dynamat. It like trying to remove melted mozzarella cheese from a pizza lol. replaced a couple of more rust spots with some fresh metal. Seam sealer then epoxy primer coming up next. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 13, 2021 Author Share Posted August 13, 2021 Floor complete. Por 15 on any surface rust, and extra screw holes welded closed. 4 coats of epoxy paint. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 13, 2021 Author Share Posted August 13, 2021 Fabbed up some new speaker brackets Link to comment Share on other sites More sharing options...
MiNi Beast Posted August 13, 2021 Share Posted August 13, 2021 2 minutes ago, ghetdjc320 said: Fabbed up some new speaker brackets Why? Link to comment Share on other sites More sharing options...
howeitsdone Posted August 13, 2021 Share Posted August 13, 2021 That's a good looking floor! Link to comment Share on other sites More sharing options...
Minuit Posted August 13, 2021 Share Posted August 13, 2021 What is the brown-orange product you're spraying on the weld areas? Some type of weld through primer? Link to comment Share on other sites More sharing options...
89 MJ Posted August 13, 2021 Share Posted August 13, 2021 1 hour ago, Minuit said: What is the brown-orange product you're spraying on the weld areas? Some type of weld through primer? I would imagine it’s Eastwood Weld Through Primer. Weld through primer is good stuff. I 100% recommend it. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 13, 2021 Author Share Posted August 13, 2021 1 hour ago, Minuit said: What is the brown-orange product you're spraying on the weld areas? Some type of weld through primer? Yep it’s weld through copper primer Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 13, 2021 Author Share Posted August 13, 2021 36 minutes ago, 89 MJ said: I would imagine it’s Eastwood Weld Through Primer. Weld through primer is good stuff. I 100% recommend it. Yep, but mine is from dominion sure seal Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 13, 2021 Author Share Posted August 13, 2021 8 hours ago, MiNi Beast said: Why? Have some component speakers going on the b pillars. Link to comment Share on other sites More sharing options...
MiNi Beast Posted August 13, 2021 Share Posted August 13, 2021 1 minute ago, ghetdjc320 said: Have some component speakers going on the b pillars. Did you not have factory brackets already? Different size?.. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 13, 2021 Author Share Posted August 13, 2021 46 minutes ago, MiNi Beast said: Did you not have factory brackets already? Different size?.. different size. The front and rears will all be 5.25” now. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 19, 2021 Author Share Posted August 19, 2021 Don’t buy mass backing on your carpet Link to comment Share on other sites More sharing options...
ghetdjc320 Posted August 22, 2021 Author Share Posted August 22, 2021 Link to comment Share on other sites More sharing options...
MiNi Beast Posted August 22, 2021 Share Posted August 22, 2021 Tweet tweet fools! Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 28, 2021 Author Share Posted September 28, 2021 Well I was just planning on fixing the rear window leak lol. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted September 28, 2021 Author Share Posted September 28, 2021 Treating and refinishing the frame now Link to comment Share on other sites More sharing options...
