dante2 Posted February 13, 2020 Posted February 13, 2020 Driver side door check is broken inside the door. I need to replace but I would like to know if the after market ones are any good or would I be better off with a used one?
olddude Posted February 13, 2020 Posted February 13, 2020 What is a door check? Is this for the Comanche?
eaglescout526 Posted February 13, 2020 Posted February 13, 2020 These are door checks. These are still available from Chrysler.
500 MJ Posted February 13, 2020 Posted February 13, 2020 If you can get one from the rear doors of a 4 door XJ they will work. The arm is the only item that needs to be swapped out, if you have a vice with some punches it is not a tough job to do it. The rear doors of XJ's were never used as much as the fronts, so the mechanisms are usually in great shape in the salvage yards...
Warren Mohler Posted February 13, 2020 Posted February 13, 2020 I would use OEM if price is reasonable, since 85 I have never seen one break, weak link is the pin and body side mount
Jeep Driver Posted February 13, 2020 Posted February 13, 2020 Yes, they break. Get one for $5 at the PnP from a late model XJ.
eaglescout526 Posted February 13, 2020 Posted February 13, 2020 2 minutes ago, Warren Mohler said: I would use OEM if price is reasonable, since 85 I have never seen one break, weak link is the pin and body side mount They list out at $94. But its great quality. My checks broke inside the door and it looked like just plain old age and corrosion.
Warren Mohler Posted February 13, 2020 Posted February 13, 2020 2 minutes ago, Jeep Driver said: Get one for $5 at the PnP from a late model XJ. Agree my local yard wouldn't even charge for that
dante2 Posted February 13, 2020 Author Posted February 13, 2020 Can you use the rear door check in the front? I thought it was only the front door checks worked on either side.
High2by Posted February 13, 2020 Posted February 13, 2020 I think I got my new ones from Team Cherokee.Sent from my iPhone using Tapatalk
500 MJ Posted February 13, 2020 Posted February 13, 2020 3 hours ago, dante2 said: Can you use the rear door check in the front? I thought it was only the front door checks worked on either side. Yes, - just swap the arms out. The mechanisms are the same. 4 hours ago, 500 MJ said: If you can get one from the rear doors of a 4 door XJ they will work. The arm is the only item that needs to be swapped out, if you have a vice with some punches it is not a tough job to do it. The rear doors of XJ's were never used as much as the fronts, so the mechanisms are usually in great shape in the salvage yards...
ghetdjc320 Posted February 13, 2020 Posted February 13, 2020 4 hours ago, High2by said: I think I got my new ones from Team Cherokee. Sent from my iPhone using Tapatalk X2 I used their replacements and they work great: https://teamcherokee.com/front-door-check-cherokee-comanche-1984-2001/
AZJeff Posted February 14, 2020 Posted February 14, 2020 For an item that wears as much as a door check, I would not even THINK about using one from a junkyard when new ones are still available. I got mine from either Team Cherokee or Quadratec, I cannot remember which, but they were OEM.
