tarmac2dirt Posted April 17, 2019 Posted April 17, 2019 Hello, Looking for comments and solutions to welding on axle housings. Well for you guys that have been there-done that, have you had housing warp or bow from the welding. What can be done to prevent warping when installing perches , braces, shock mounts, etc----. Just asking as I plan to put a 8.8 ford at some point. Thanks Paul
89 MJ Posted April 17, 2019 Posted April 17, 2019 Don’t run a solid bead around what you are welding-too much heat. Instead do beads 1 in long at the most and let them cool briefly.
Pete M Posted April 17, 2019 Posted April 17, 2019 especially as you weld the pumpkin to the tubes. don't be in a hurry.
Eagle Posted April 17, 2019 Posted April 17, 2019 Perches and shock mounts are typically welded to the axle tubes, not to the differential housing. It's extremely unlikely that you would (or could) warp a tube by welding something to it. The factory spring perches certainly look like they were welded with continuous beads, not a bunch of spot or tack welds. Welding a brace (or anything) to the differential housing is a different matter. Those are cast iron (or cast steel), and that requires different welding techniques (that I consider to be over my head).
Jeep Driver Posted April 17, 2019 Posted April 17, 2019 As others have said........just spread the love around. I had no problem welding mine. With perches and brackets....just weld in one area then move on to another and come back to where you started.
Dzimm Posted April 17, 2019 Posted April 17, 2019 If you are just swapping in the 8.8 you will be fine welding the perches on without worry. Stitch the welds like stated above and you'll have no issues. If you plan on adding a truss kit or something that will weld to the diff, it's a different story. I swapped a C8.25 into my truck and just welded half the bead at a time and swapped ends of the axle between passes and it turned out similar to Jeep Driver's picture above.
tarmac2dirt Posted April 18, 2019 Author Posted April 18, 2019 Thanks for the encouraging info. Helps relieve the thought of warped housing. As it turns out there may be a d44 axel available instead from a 79 wagoneer. Have a feeling it may be to wide though it from a narrow body wagoner. Anyway thanks guys, Paul
carnuck Posted April 18, 2019 Posted April 18, 2019 Thanks for the encouraging info. Helps relieve the thought of warped housing. As it turns out there may be a d44 axel available instead from a 79 wagoneer. Have a feeling it may be to wide though it from a narrow body wagoner. Anyway thanks guys, Paul 79 (actually all ‘74-91 full size) 4 Dr wagons are within an inch of width wheel mounting surface to WMS at both ends. The rims are a different offset to make it sit wider and also pre ‘80 are offfset axles on the wrong side at both ends. (Front is passenger side till ‘80 and rear is quadratrac offset to the right as well) J10s and 2 Dr Cherokees are too wide unless you find the oddball narrowtrac 2dr without fender flares. Model 20 rear came in ‘80 until ‘88ish when the Grand Wagoneers (84-91) went back to D44 as M20s went to the Humvee production. Sent from my iPhone using Tapatalk
DirtyComanche Posted April 18, 2019 Posted April 18, 2019 4 hours ago, tarmac2dirt said: Thanks for the encouraging info. Helps relieve the thought of warped housing. As it turns out there may be a d44 axel available instead from a 79 wagoneer. Have a feeling it may be to wide though it from a narrow body wagoner. Anyway thanks guys, Paul The bolt pattern won't be right... But as Carnuck was getting at, it will be within an inch of the width of your existing axle; actually it will be an inch narrower. As to the original question, the factory welds brackets on in a single pass... While doing shorter welds and moving around is good practice, it is not strictly necessary.
Eagle Posted April 18, 2019 Posted April 18, 2019 5 hours ago, tarmac2dirt said: Thanks for the encouraging info. Helps relieve the thought of warped housing. As it turns out there may be a d44 axel available instead from a 79 wagoneer. Have a feeling it may be to wide though it from a narrow body wagoner. Anyway thanks guys, Paul A 79 Wagoneer was a full-size. The hubs will be 6-bolt.
