chopper35nj Posted December 31, 2018 Share Posted December 31, 2018 Hey guys, it’s been a while since l have been here but my old Heep has been pretty reliable for the past few years but, it’s now time to do the ball joints, tie rod and ends and bearings. Looking for recomendations for specific brands that you like and why. Also, possibly interested in the one ton ball joints and rod ends so tell me what is involved in that kind of conversion, have you done it and would you do it again? Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2018 Share Posted December 31, 2018 Moog makes a good product.  stock stuff works great on a stock truck, but I would upgrade to the v8 ZJ drag link. (or was it the tie rod?) one of those comes extra beefy on the v8 ZJs and is a bolt-in upgrade. Link to comment Share on other sites More sharing options...
Smokeyyank Posted January 1, 2019 Share Posted January 1, 2019 V8 ZJ tie rod as suggested is a great, easy upgrade or any solid tie rod. The stocker is as useful as a wiffle ball bat. Other than that Moog for the rest. They make decent stuff and have a fair warranty. don't bother with 1 ton stuff. If you really want to fix the geometry and improve everything go with a WJ swap. Not cheap but really a great upgrade. Better brakes better geometry. General idea of parts involed and some cost.  http://www.stinkyfab.com/sfr-high-roller-wj-steering-brake-kit-xj-mj/ Link to comment Share on other sites More sharing options...
JMO413 Posted January 1, 2019 Share Posted January 1, 2019 The ZJ steering is a great upgrade. The parts are cheap on Rock Auto. Moog for everything for sure! Link to comment Share on other sites More sharing options...
rokinn Posted January 1, 2019 Share Posted January 1, 2019 An added incidental while you're at it. This from Hornbrod some months back.  Read down to my question about which part as there is some confusion about which one of two is correct at the beginning of the thread. I found it a worthwhile addition. Link to comment Share on other sites More sharing options...
WahooSteeler Posted January 2, 2019 Share Posted January 2, 2019 I plan on doing the ZJ steering upgrade soon. In addition to the tie rod, is it recommended to use the ZJ V8 drag link also? Is it beefier and/or an upgrade over stock? Link to comment Share on other sites More sharing options...
Pete M Posted January 2, 2019 Share Posted January 2, 2019 I *think* the drag link is identical to ours. Link to comment Share on other sites More sharing options...
DesertRat1991 Posted January 2, 2019 Share Posted January 2, 2019 1991- 2001 XJ/MJ use the same drag link as the ZJ.  In this case, you just need the upgraded tie rod.  1990 and older XJ/MJ use a smaller drag link TRE and adjustment sleeve.  In this case, upgrade both drag link and tie rod assemblies.   Link to comment Share on other sites More sharing options...
WahooSteeler Posted January 2, 2019 Share Posted January 2, 2019 1 hour ago, DesertRat1991 said: 1991- 2001 XJ/MJ use the same drag link as the ZJ.  In this case, you just need the upgraded tie rod.  1990 and older XJ/MJ use a smaller drag link TRE and adjustment sleeve.  In this case, upgrade both drag link and tie rod assemblies.   Thanks, mine's an 88 so I'll do the drag link also. Link to comment Share on other sites More sharing options...
chopper35nj Posted January 3, 2019 Author Share Posted January 3, 2019 Thank you all for the input, l have a good idea what direction to go in. Link to comment Share on other sites More sharing options...
WahooSteeler Posted January 3, 2019 Share Posted January 3, 2019 10 minutes ago, chopper35nj said: Thank you all for the input, l have a good idea what direction to go in.  Chopper, if you decide to replace the drag link also, upon further research I found several posts on different forums that while the ZJ drag link will work, the geometry is apparently a little different and could throw off alignment etc. I found that the Moog #DS1238 is the proper drag link for an MJ/XJ but is a larger diameter than stock and the same thickness as the ZJ unit (Moog #DS1310). Link to comment Share on other sites More sharing options...
PIKE Posted January 3, 2019 Share Posted January 3, 2019 On 1/2/2019 at 11:33 AM, DesertRat1991 said: 1991- 2001 XJ/MJ use the same drag link as the ZJ.  In this case, you just need the upgraded tie rod.  1990 and older XJ/MJ use a smaller drag link TRE and adjustment sleeve.  In this case, upgrade both drag link and tie rod assemblies.   I have read that the 1991-2001 xj/ mj drag link is different than one from a 93-98 V8 ZJ. It has to do with how the steering stabilizer bolts up.  My research shows to use the 1991-2001 xj drag link with the 93-98 V8 ZJ tie rod  Hope this helps. Link to comment Share on other sites More sharing options...
PIKE Posted January 3, 2019 Share Posted January 3, 2019 3 minutes ago, WahooSteeler said:  Chopper, if you decide to replace the drag link also, upon further research I found several posts on different forums that while the ZJ drag link will work, the geometry is apparently a little different and could throw off alignment etc. I found that the Moog #DS1238 is the proper drag link for an MJ/XJ but is a larger diameter than stock and the same thickness as the ZJ unit (Moog #DS1310). You beat me to it Wahoo, I have read the same info. Link to comment Share on other sites More sharing options...
PIKE Posted January 3, 2019 Share Posted January 3, 2019 29 minutes ago, WahooSteeler said:  Chopper, if you decide to replace the drag link also, upon further research I found several posts on different forums that while the ZJ drag link will work, the geometry is apparently a little different and could throw off alignment etc. I found that the Moog #DS1238 is the proper drag link for an MJ/XJ but is a larger diameter than stock and the same thickness as the ZJ unit (Moog #DS1310). I agree with part number Moog #DS1238 for drag link. But for tie rod I have part number Moog #DS1312. Make sure tie rod is for a V8 ZJ.  Tie rod ends are Moog#ES3096L , you will need 2 of them.  Adjuster sleeve is Moog#ES2079S , you will need 2 of them.  Please correct me if you think these numbers are not correct. I spent some time researching this and it can get confusing. Link to comment Share on other sites More sharing options...
WahooSteeler Posted January 3, 2019 Share Posted January 3, 2019 10 minutes ago, PIKE said: I agree with part number Moog #DS1238 for drag link. But for tie rod I have part number Moog #DS1312. Make sure tie rod is for a V8 ZJ.   Agreed. The ZJ drag link that you DON'T want is Moog #DS1310. Link to comment Share on other sites More sharing options...
chopper35nj Posted January 4, 2019 Author Share Posted January 4, 2019 Wow, thanks again guys. All good info. My origional thought was to go with all Moog parts and l see that my first instinct was correct. I have heard some feed back on a decline in quality but it still seems to be the choice of most. I am still concidering going with Timken bearings instead.  Link to comment Share on other sites More sharing options...
zomeizter Posted January 31, 2019 Share Posted January 31, 2019 Dudes, are these the correct items to upgrade my MJ's steering?  Link to comment Share on other sites More sharing options...
zomeizter Posted February 3, 2019 Share Posted February 3, 2019 On 1/30/2019 at 7:13 PM, zomeizter said: Dudes, are these the correct items to upgrade my MJ's steering?   I reckon the picture is not clear. Just to make sure I order the correct upgrade items, my cart contains the following MOOG parts:  DS1238 x1 (XJ) DS1312 x1 (ZJ) ES3096L x2 (ZJ) ES2079S x2 (ZJ)  I will be installing these together with a 4-5" lift, is a Pitman arm or any other steering component required/recommended? Link to comment Share on other sites More sharing options...
JMO413 Posted February 3, 2019 Share Posted February 3, 2019 When I did mine I bought all ZJ parts. I have a 4.5" lift and didn't need anything else. Link to comment Share on other sites More sharing options...
zomeizter Posted February 5, 2019 Share Posted February 5, 2019 Right on, thanks. I will be running 31 inch mudders on steelies myself, nice setup you got there... Link to comment Share on other sites More sharing options...
JMO413 Posted February 5, 2019 Share Posted February 5, 2019 13 minutes ago, zomeizter said: Right on, thanks. I will be running 31 inch mudders on steelies myself, nice setup you got there... Thank you! It has been allot of work but I do love this little truck. Link to comment Share on other sites More sharing options...
