General Question
Hey guys!
I've got an open-ended question that is probably a little too broad, so apologies in advance (breaking the rules by apologizing!) I have a 1987 Jeep Comanche base model that randomly stopped working on me a few weeks ago. Haven't had the time to troubleshoot, but I'm not too sure where to start. Background is that it never had any real big issues until now. I was driving back home and the power randomly cut out while driving forcing me to pull over. Electronics and all still worked but the car was getting no power. It started and died a few more times before it finally gave out and I got towed home. Now it is looking very clean in the front yard but not going anywhere. It tries to crank but doesn't start. I've done basic things like clean grounds, new battery, checked fuses and relays and that's pretty much where my knowledge ends. Does anyone have any suggestions or recommendations? I'm happy to answer more questions if that helps diagnose!
5 hours ago, Tony el Tigre said:
Thanks gents! Looks like I'm going to have a field day going through that list
Which engine do you have?
The CPS can be tested. It's in one of the tips..... But, just for fun, unplug it and plug it back in and see what happens. The ground the taillamp is huge. Do it right away. There's a Tip for upgrading that ground also. Should be done.
C101 connector refreshing is also huge. Do that.
10 hours ago, Pete M said:
yup, start running through Cruiser's tips.  should be the first link in the link in my sig.  one of them is refreshing grounds, specifically the one behind the drivers side taillight which grounds the fuel pump.  :L:
Pete, those tips you refer to in the link are totally outdated. Best to use www.cruiser54.com. thanks.
I've been doing a lot of cleaning under the hood and haven't struck gold yet. I'm thinking the next thing to tackle is the CPS. Getting to it looks like a great time!
C101 was a sludgy mess and I got that cleaned up. I can hear the fuel pump cut and the injectors are getting fuel. On another note, would rotting hoses be enough to keep the engine from starting? Either way they're getting replaced
For those asking, it's the 4L straight 6.
FWIW, I just changed the CPS in my MJ (4.0L BA10-5 transmission). To be able to get my gorilla sized hands and arms in place I ended up taking the transmission crossmember off and allowing everything to rotate around the engine mounting points, effectively lowering the transmission. It bought me an extra 4" of clearance or so, which made it possible to get my hand up to the CPS and guide the socket. Only took an extra 30 minutes to do this as well, so its worth it IMO. I also used (literally) every single extension I own and came at it from the space above the transfer case. Good luck with it.
The CPS is the first thing you should have checked, as several people suggested. Don't replace it unless you have tested it and found that it's bad. If you do the A/C voltage test and you're getting a good reading, then the CPS isn't the problem and you need to look elsewhere.
