Took a nice long break from all of my projects. For good reason, got married.
The Comanche of course was part of the wedding as it was the only vehicle we have had since day 1, all of our first dates were in it, and all of our first memories.
On 10/27/2025 at 9:18 PM, ghetdjc320 said:
Congratulations!! :beerchug:
Thanks!
In other news, the comanche is back on the backburner, couple reasons, One being winter.
But on a more serious note, after the initial test drives with the new front end some issues arose.
First big one is the shock mounts, they are too far back, and cause a binding scenario that I could compensate with running a crazy caster angle, but it really just needs to be fixed. The fix is to get shorter shocks and mount the lower shock mount on top of each beam. This is just a problem of using the shock towers I previously installed, placing the shocks where they are, and it not playing nicely with the new front end. This is the costly repair, as the shocks I want to get are about $2k.
Other odd issue, is the 9'' rear axle keeps unseating the axle shafts. This is a new one and I am not sure of the source of this issue. The shafts are full floating, and never needed a retainer in the past, but the last few times I've taken the rig on a drive, the driver side rear shaft will slide out of the splines in the hub, resulting in one wheel drive lol. I think I need to add a spacer in-between both shafts, so that they physically cannot slide out of the splines in the hub or diff, or I can thread a bolt thru the hub cap into the axle shaft. I much prefer the first option as it makes for less failure points and leak points.
All that to say, the jeep is put away until after winter most likely. I got my hands full with my Turbo Silverado project in the workshop that's realistically got another month or two before its out of the workshop.
  • 4 months later...
Alright so current damage report and things to finish:
-Rear Axle shaft
-Front Coilover needs a rebuild & new shaft
-Front Differential re-gear
Also slowly aqcuiruing parts to go back to a 4L80E...In my turbo truck I have one and really figured out how to tune it better and really enjoy how it drives, plus I can't do clutch drops which will save me from breaking axle shafts on the street some more lol.
In doing so though, I will likely put a smaller cam in the LS3, so that I don't have to run a crazy torque converter, as that won't be ideal for an off road rig.
53 minutes ago, 89 MJ said:
Keeping it now? I know you were considering selling it.
It has to be fixed one way or the other, I don't want to sell it, but if someone comes by with a wad of cash I could use that more than I can use a Jeep that sits and cost money lol
  • 4 weeks later...
Alright well, noone came along with a reasonable offer. So going to keep it, but taking it to the next level.
With that said, I won't be using this thread much anymore for it. It will no longer be much of a Comanche.
With the exception of title, cab, dashboard, and some emblems it will be a completely ground up full tube chassis build. I have started to document the future of this truck on the forum below that is more suited to full chassis builds.
https://irate4x4.com/threads/comanche-fun-runner-phase-3.412529/
Ill still be around for nostalgic reasons, but the next phase of this build doesnt apply to comanche's much anymore.
Ill be posting not needed parts in the classifieds.
You’re in Epic tech so it definitely qualifies :holdwrench:. This section of the forum doesn’t get much traffic but it really does have some fantastic builds and info. It’s awesome that you have some really out of the box designs and fabrication that can be referenced in the years to come. Keep posting here, even if it doesn’t get many replies, it will have a good home :L:
I can still post in her periodically, I mostly meant I will primarily be on that new thread as there is a larger crowd of those with the Full Chassis know-how and nitty gritty details there. CC is a great resource for everything Jeep/Mopar, mine will be almost nothing Jeep/Mopar any longer lol.
47 minutes ago, 89 MJ said:
:yeahthat:
I I always like watching the hardcore builds
Agreed! I just need a larger “hardcore” crowd to get this build to that next level properly
2 minutes ago, ghetdjc320 said:
I think a lot of members don’t even realize the Epic section exists. DIY section suffers from a similar fate.
I definitely noticed when I made the jump to Epic that the activity slowed. Don’t know if it’s a lack of interest in extreme builds or a lack of knowing this section exists. Lol
  • 2 months later...
Alright, its been 2 months, and I can't bring myself to take a saw to this truck anymore. I don't regret what I have built it into, but I am also not happy with it.
Long story short, I think the only way I will get the most use out of this truck is to tone it back. Its so un-fun/radical, scary, and expensive to drive as it has been. Thats needs to change so I can just get back to simply enjoying the truck again.
I have a plan in mind, but I don't want to divulge all the details until its more for sure and I'm actually moving forward with it.
For now I am just going to drop this photo of what I think I want to go for...and work on clearing the projects out of my shop so I can prepare to get back onto the MJ. Ill pop back in to update in the next month or so when the plan hopefully starts coming together.
1989_jeep_comanche_1989_jeep_comanche_e46a0a95-d1fb-4f57-9e5c-b0f73d7de1df-RnTjLE-37739-37740-scaled.jpg
  • Comanche SS changed the title to Comanche Fun-Runner: Identity Crisis (stay tuned)
Looking forward to what you come up with. I ended up having to daily drive my MJ for almost a year and that totally changed the way I mod it now.
Alright I can give more info now that the plan is in motion.
So when I started thinking of what I want to do with the Comanche to get back to enjoying it, I knew I needed to go more conventional with it, Its too radical to easily enjoy. Purpose built items arent fun when you arent doing that purpose...I figured that out the hard and expensive way lol.
So anyway, I started looking for stock 98+ XJ's for axles & interior/exterior parts. Then I was kicking myself since I literally did this exact thing a little while back on the other Comanche project I began and abandoned (linked below).
But it was with a close buddy of mine who bought it from me, parked it and literally didnt touch a thing from the day I sold it to him. So I offered him what he bought it off of me for and he took it!
Feel free to read that old thread, but essentially, itll be used as a donor to get my OG Comanche back on the road. It has a Disc brake 8.25 29 spline rear, a D30 front, a full 98+ interior swap, a good bed, tail lights, and some misc items ill need for my OG comanche.
The Donor Comanche is pretty rough, floors are toast, rockers are toast, etc...If I want to scratch my itch of cutting up and building a buggy Comanche, that would be a much better one to start with rather than my rust free CA Comanche lol.
The build will entail an LS still, likely a 4L80 or 6L80, and 4x4. Still epic, just more widely usable.
Lots of luxury adjustments will be made to really enjoy driving this truck like the classis that it is, Ive proven to myself I don't enjoy building it into the off road machine that it was. I want to be able to take my wife or Dad to car shows with it, or fishing, adventuring, exploring reliably and comfortably, with AC.
The donor Comanche link:
  • Comanche SS changed the title to Comanche Fun-Runner: Prerunner turned adventure Rig
I'm really liking this plan. There was a time where I wanted to make my truck have 33-35" tires, but now I am glad that my budget only allowed 31s. I'd possibly be a buyer if you've got an AX-15 to LS bellhousing you'd want to sell though, just make sure you won't want to use it first :laugh:
Yeah, I'm excited for the next phase. I don't have the adapter for sale any longer. @boxyjeep Already got it from me.
The donor has finally landed at my house, I completely forgot how many unique parts I threw in the deal for my buddy.
-Full Black & Gray 1998 Dash
-Completely redone axles
-Complete wiring harnesses from the 1998 XJ bumper to bumper
-2001 XJ ECU (very important for using stock gauges)
-1998+ XJ Manual pedal assembly
-1998 XJ Brake booster/Master
-Most of the Comanche specific interior pieces
-NP242 shifter assembly
I'm sure there is more that I'm missing but those are most of the cool parts. I'm probably not going to use all of it. Ill post the not needed parts for sale.
Got some tailgate brackets and speaker boxes on the way from @boxyjeep
Posted a handful of items in the classifieds that I won't be needing for my current projects.
In the meantime, I sorted thru what I am keeping and moved it all into safe keeping for the time being...I need to finish my turbo silverado before I can begin working on the Comanche's.
here’s some current photos:
Its too hot to be working outside, so I am thinking ahead at some of the luxury items I want to do.
Starting with the gauges/ECU....I don't want to run two ECU's and two harnesses to retain the jeep gauges.
So I decided if I am doing custom gauges, I want to solve a few issues with one elegant solution.
here's my new music, gauges, navigation, and telemetry device all in one, thanks to an old iphone lying in a random drawer in the house lol.
The only two things the ECU won't be able to give readouts on is the fuel gauge and oil pressure, hence the two smaller gauges outside the cluster.
This will drop in the 97+ dash and fit like factory, thanks to a scan from @boxyjeep
