Odd Renix No Start: Have Fuel/Spark
  • Replies 82
1 hour ago, gilman711 said:
Found another random unused connector which is right next to the CPS Connector...or is this the CPS Connector?
2 Wire
BLACK WITH WHITE STRIPE
WHITE WITH BLACK STRIPE
Should be this one, violet with w/tracer and white with tracer.
you get spark so the CPS is good, leave it alone for now
puttin gasoline / starter fluid directly in the air intake and "tries" to run...
check for compression and see if the valves are actually opening all the way...
The original one it was plugged into seems to be for CPS as plugged in the other connector and then instantly no spark. Swap it to other and have spark. Connector with
RED WITH GREEN STRIPE
BTW, you have not mentioned MAP.
Might start if not connected but will not idle..........may not even start.
You need to check all your wiring against schematic.
MAP sensor plugged in and tested according to www.lunghd.com and tested good (I can't test the running voltage obviously though)
2 minutes ago, gilman711 said:
During Re-test of CPS...I'm getting an ohms resistance of 178ohms which is within normal range. When cranking on AC Volts though I'm only getting .35 which is below the .5-.8 range.
New CPS.
If you got two wires that go from the CPS to and through the firewall, vehicle has TSB fix for CPS. This fix took CPS wiring directly to the ECU. Drop ECU and visually check CPS wiring at the ECU. Make sure both wires are connected and terminated properly. Easy check before new CPS arrives.
Yes. And part of the instructions in that TSB was a note to cut the old CPS connector off.
Wasn't always done.
I'm fairly certain the specified resistance for the CPS is to be measured at normal operating temperature. That always bothered me, because how do you get it to normal operating temperature if the engine won't start and run?
heat gun?
Well new CPS installed and AC Voltage when cranking still low...fluctuates between .44-.56 which I believe is still too low? I'm still getting spark but will not fire up.
I did pull ECU and checked wiring going in from CPS and it's good there. Cleaned and Dielectric Grease done for good measure
Any negatives to have the CPS Voltage be 1+ AC Volts? I've adjusted 3 different voltages and tried but no make any difference in attempt to fire. All positions are allowing for spark and no noticeable difference in spark regardless of position/Voltage of CPS.
I have air, fuel, spark and compression...indexed distributor...I just don't know what else to check...
are the valves opening? same thing happens when a timing belt breaks, cranks but no start... also remove the dizzy cap and see if it`s turning... if still doesn`t work pour gasoline and set it on fire because it`s cursed, CURSED I TELL YOU!!!!
On 5/3/2018 at 7:12 PM, gilman711 said:
I have 38psi Fuel Pressure when cranking.
Check manifold vacuum using a vacuum gauge. While cranking fuel pressure should drop as manifold vacuum increases.
EDIT: With throttle plate closed.
