Odd Renix No Start: Have Fuel/Spark
I'm at a loss and need some help and forums have always been a great source to give and receive such knowledge. To clarify I did not install all these parts to try and correct no start issue but even new parts have been tested as some were installed before me buying. I bought truck not running.
1989 Comanche 4.0 Renix Manual Trans
Crank No Start Issue
New Battery
New Fuel Pump
New Fuel Filter
New Injectors
New Starter
New Plugs
New Engine Ground 4Gauge Cable
New Air Filter
New Distributor
Cleaned TB and TPS (calibrated TPS)
Cleaned CPS (crank sensor) (tested ok)
Cleaned Coil Contacts
Checked Firing Order
Vehicle cranks well and sometimes tries to start and fails and other times just seems to crank and crank. I've tested CPS and TPS and both within specifications. I have 38psi Fuel Pressure when cranking. I have spark as well and visually appears to be strong spark. Attached a picture of a connector on passenger side of engine bay I'm not sure what it connects to?
What else can I check or test? Thank you so much in advance!!
  • Replies 82
You have spark, but do you have spark when and where you need it? Is it possible the previous owner got the distributor in 180 degrees out of phase? That would mean #1 is "firing" when it's at the top of the exhaust stroke rather than the compression stroke.
Find that connectors mate. It can't be too far away. Unable to tell if you're showing the Engine Harness side connector or the Engine Control side harness connector, either way, find its mate.
48 minutes ago, DirtyComanche said:
Will it run on starting fuel or with gas dribbled down the TB?  Rule out if it's ignition or fuel.  Injector harness could be on wrong, which sucks. :roflmao:  But I'd say more likely the disty is indexed wrong.
Will not run with fuel down TB. Injector harness would be harder to mess up than say ignition wires. I'm going to check distributor tomorrow
Haha I searched and searched and cannot find it anywhere. I looked on either side of engine and even possibly on transmission.
It's actually incredibly easy to put the injector harness on wrong.  No, I've not done it, but I've dealt with trying to troubleshoot it.
Pictures show it at TDC and where the Rotor is in relation to #1 cylinder which appears to be lined right up with it.
According to the Cruiser54 regarding Cam Sensor:
"For clarification though, that’s not a cam sensor inside the Renix dizzy. It’s there to fire the injectors sequentially with the firing order. You’ll never notice if it went bad because the ECU will try to “guess” where it is and does a heck of a job at it. "
Look for path to ground at the sync sensor (C231_A harness side). If missing 4 pin connector is C109, then no path to ground.
Added: You still need to determine if Cyl #1 is on compression stoke or exhaust stoke. Your pictures don't prove that.
I held my finger on cyl 1 when rotating engine to verify it was on compression stroke.
Is the Sync Sensor the one in the distributor?
20 minutes ago, Ωhm said:
Yes
The Sync Sensor is currently plugged in. I have not tried to start with it unplugged to see if any change. Is C109 Sync Sensor connector? Greatly appreciate yours and everyone's help!
I do have another complete distributor assembly I'm going to try as well.
C109 is a inline connector (engine harness to engine control harness) located on the right side of the engine bay. Sync Sensor is C231 and ground pin is "A" (harness side).
But is it TDC on the compression stroke?
Looks like he has the timing marks aligned at TDC.
Replaced complete Distributor with a good known working unit and still no dice. I even tried starting with Sync Sensor unplugged and no difference. I have not lost hope but this Jeep really has me at a loss...
I am updating original post too as far as parts replaced and things tested. Original issue still present of getting spark/fuel/air and no start condition.
What am I missing here?
Mystery plug is coming from main harness as well as a small single wire (solid black) on passenger side.
Mystery Plug Wiring
A- BLACK WITH YELLOW STRIPE
B- BLACK WITH WHITE STRIPE
C- BLACK WITH BLUE STRIPE
D- PINK WITH BLACK STRIPE
