Reusing a Comanche "frame"
have anybody tried to unweld the X-frame of a comanche? the idea is to find a MJ with a damaged cab and assuming the X-frame is good, unweld the cab and then, get a good XJ, cut it right behind the front doors and weld the MJ X-frame and the back of the cab...
yeah, i`m desperate to get more MJs..
19 minutes ago, DirtyComanche said:
You could do this, although there is some major complications as there is differences between them.  I do not think it would be worthwhile though, as fixing a MJ cab would likely be much easier.
This^
It's an interesting idea but even if you tried to turn an XJ into an MJ, you'd need the back of the cab to make it look right, and then a bed, and then all the trim pieces.  You would be much better off taking on really really poor shape Comanches and fixing those to save them.  The majority of them I've seen for sale recently are listed as "parts" trucks because they are further gone than the current owner cares to fix.  You could look for these, scoop them up, then spend your time fixing them because ultimately, they will end up at the crusher.  As you get into the swing of saving these, you may come across one that it makes sense to do what you are thinking and graft in major sections of XJ parts to fix it.
How about crashed or rolled over MJs? as long as the frame, bed and back of cab is good... also MJs that have been stripped but happend to have those parts in good shape, in here people trash perfectly good XJs with blown gaskets or worn engines (which can be fixed)
so bad to make it not worthy? that`s my question...
Problem with that is good luck finding an MJ that only has damage to the front end and not the rest of it.  If the damage to the front was substantial enough to cause the whole front end to be completely unrepairable, the back end wouldn't have survived either.   And any stripped MJ is going to missing the key components you would need.  Very very rarely would someone take a front clip or fenders from an MJ and not grab the good stuff also, and if this does happen, the next guy walking by is going to grab the rest.
I like where your head is at but I think you are delving into the "unicorn" of wrecked MJs and honestly it would never really be worth it to haul a heavily wrecked MJ farther than your state's boarders, at least not at this point in time.
You have to consider that yes the XJ and MJ are very similar in that they use a majority of the same parts but the skeleton is completely different.  Check out Bleepinjeep on YouTube as he is doing an MJ build currently and in one of his earlier videos in the series,  he describes the differences of the frames.
I think HOrnbrod has a point in that it's usually going to be easier and more cost effective to build something custom than to graft a bunch of mismatched parts together to make it work.  Yes it can be done, but it's extremely difficult and I wouldn't recommend it unless you are a highly skilled fabricator and have a ton of time on your hands, but then consider that time you spent doing drastic repairs to one MJ, how many other MJs you could have saved that needed less work.
10-15 years from now i think we will start to see more conversations about drastic repair work like you are describing, we just aren't at the point that it's worth it yet IMO.   And it's not that these trucks and the XJs junked just with bad gaskets aren't worth repairing, but people just don't care for vehicles like they used to and they are considered disposable now.  Nobody outside our little world cares about an old rusty pickup that's loud and smells funny or an XJ that they made 2 million of.  It's sad really but that's the reality we live in.
So the differences between an MJ cab and XJ "cab" are the floorpan, rockers, back of cab, and the roof.
Rust wrecks the floorpan and rockers first.
Rollovers wreck the roof and back of cab.
I can't think of many situations where it might be less work to swap everything over than to just fix the damage to the MJ. You'd have to peel both the top and bottom off of the XJ "cab" to make it work out the same as factory. You'd be saving what, the firewall, a-pillars, and doors?
One member here a few years back did do the '97+ OBD2 swap (I think?) by cutting the front end off an XJ right behind the firewall and welding it onto a similarly cut MJ... But many people have got the same result with significantly less work involved.
7 hours ago, HOrnbrod said:
Unfortunately, finding decent MJ "frames" that are not rotted out beyond repair isn't easy.  :sad:  Might be more cost effective to build a custom updated frame.
He's in Mexico. I doubt they have a problem with rust there. I wonder if Cherokees and Comanches are as popular there as they used to be in Chile (my late wife's native country).
The hybrid splice has been done before. I thought we had photos of one somewhere on this site. If we didn't -- we do now.
This is a bit too long for my taste. I think it would be better with a shortbed box. Sort of like this (edited photo):
XJs are common here, so common that like i said, they get dumped as soon as something goes wrong, they don`t bother to fix them...
MJs are nonexistant, only my unit and like 5 other i have seen, one of which is in very bad shape
i also saw several of those 4 door "comancherokees"...
and yes rust is not an issue here, mine had rusty floors but that was because some idiot PO got the carpet wet and didn`t do anythign to dry it...
On 4/15/2018 at 9:43 AM, omega_rugal said:
:beerbang: that... never ocurred me...
This is pretty much the Comanche project on the BleepinJeep YT channel.  Cut off the x-frame, then replace with a tube frame and custom 4 link.
The ‘90 longbox I was going to graft 12” of my ‘88 MJ cab’s rear onto so I could use the short box and 2dr XJ doors on it turned out to be too rusty for me to do that. Someone wants the back portion of the bed to chop down for practice shortening his but it has the rear X-section up to the driver’s seat that I considered making a trailer from but again, lack of lifetime left to do it all means stuff is going away.
