neohic Posted October 7 Author Posted October 7 I figured there aren’t too many days left in the year to cruise into work with a top less CJ. Ripped it around a bit before I got home too. Here I thought we were having a nice time and then it just starts dumping fuel from the gas cap! To recap, I didn’t think I was having this issue since I gutted the pressure relief from the cap and changed the vent line from the tank to just a filter venting to atmosphere. On the tank, theres two vent lines as the factory intended. I’ve been using one as a fuel return since I did the fuel injection swap. I know… it’s not the right way to do it, but I also haven’t had any problems up until this year. The blue arrow is the fuel return and the red goes to the filtered vent. An in tank fuel pump has been on my mind for years, but again this has only been a problem this year.
neohic Posted October 12 Author Posted October 12 Ugh… So there I was trying to better the Jeep by making an actual fuel return and slosh pan to get to the bottom of the fuel issues. I get on to cleaning out the fuel tank and I found not one, but FOUR SCREWS plugging holes and some hardened peanut butter looking junk slathered over a bunch of rust. Not just four screws, but not even the SAME four screws!! I briefly debated patching the tank, but the more I cleaned the worse it got. Ah well… new tank is on order. I moved forward with using it to mock up the new pickup, return, and slosh pan. My material scraps are REALLY getting down there! A new gasket is also on order, but I borrowed it and the split ring from my auxiliary fuel tank from the Moab trip. The slosh pan sits on the bottom of the tank and has the return dump right into it while the new pickup location is towards the back. This should keep the pickup submerged all the time. I’m set should I decide to go with an in tank pump in the future. Now the old fuel pickup and gauge sender is just a sender. The old pickup got cut off and will now just be a vent. I would imagine it might’ve had something to do with the issues, but the pickup screen was falling apart and could barely be seen through. … and now we wait for parts to show up.
neohic Posted October 12 Author Posted October 12 8 hours ago, 89 MJ said: Is one of those screws a wood screw? There is a drywall screw, a self tapping, machine screw, and a steel siding screw with the rubber washer for extra sealing strength.
derf Posted October 12 Posted October 12 I've seen a DSPO (Dip "Stick" Previous Owner) use wood screws to attach valve covers. These days, very little surprises me. Way too much "I need this to get me to work right now" desperation combined with ignorance and apathy out there.
neohic Posted October 19 Author Posted October 19 Literally a day late. I wanted to get the CJ out of the shop yesterday but I just received the replacement tank. Honestly, ordering a fuel tank feels a bit out of character for me that I feel like I typically would’ve made a new one out of scraps or found materials. My material stash just isn’t what it used to be! Anyhow… I should be working on it but I went and broke my toe this morning.
neohic Posted October 25 Author Posted October 25 Back on the road and into its usual parking spot! I was worried that space would get tight under the floor but there’s plenty of room.
Pete M Posted October 25 Posted October 25 On 10/19/2026 at 3:32 PM, neohic said: Anyhow… I should be working on it but I went and broke my toe this morning. now why would you go and do a thing like that?
neohic Posted October 25 Author Posted October 25 26 minutes ago, Pete M said: now why would you go and do a thing like that? You know that fancy, new bed I just finished? You know that thing where you slightly rearrange your furniture and bad things happen? Yup… that happened.
neohic Posted October 26 Author Posted October 26 Damn CJ left me stranded!… blocks from home. It had the same feel in the throttle like it was out of fuel that it’d idle but die when given any gas. So?… … glad I added a pre filter! There’s a 10 micron filter after the pump and I put in a 100 micron filter before that I could keep an eye on. Guess I should’ve gotten the three pack of filter elements at the same time! Not saying I’d be pleased if it decided to clog up two more filters right away, but theres backup elements in the console now.
neohic Posted October 26 Author Posted October 26 11 hours ago, fiatslug87 said: WOW! Colorado gets some bad gas. I’m assuming it was something from inside a fuel hose? When I took the filter housing apart, the icky black stuff was like a furry residue… I guess? Weird.
neohic Posted November 1 Author Posted November 1 Welp… today is that time of year again to put the top back on. Unfortunately, I need to drop the new fuel tank due to the fuel gauge not working. That’ll be another day. I was a bit worried how the heavy top would settle on the new suspension, but so far so good.
neohic Posted November 11 Author Posted November 11 The suspension has been settling in just fine with that big ol’ top on it. Today’s project though was to swap out the spark plugs and diagnose the fuel gauge issue. The spark plugs looked okay(ish) but I also haven’t looked at them since the engine went in and lately it has been stumbling a little at startup. As for the fuel gauge, I thought about adding an inspection hole while I had the tank out, so I went ahead and added one. … almost in the right spot too! Unfortunately, the sweep mechanism is totally broken. Bummer.
