neohic Posted October 1, 2016 Posted October 1, 2016 What kind of trim is around the openings for the tow hooks, Don? I used a hole saw on mine and was very happy with the results without any additional garnish.
johnj92131 Posted October 1, 2016 Posted October 1, 2016 Kind o look like something for an electrical box? While I like the look of the tow hooks, I do wonder about their actual strength and utility. I have a front mounted Drawtite hitch. It has a pair of loops welded on from factory with a 300 pound pull rating. Tink the only use I ever found was to pull some small trees I had cut down into an easier place to trash them. Have used the front hitch a couple of times to move a trailer in tight spots.
HOrnbrod Posted October 1, 2016 Author Posted October 1, 2016 What kind of trim is around the openings for the tow hooks, Don? I used a hole saw on mine and was very happy with the results without any additional garnish. It's plastic flex U-channel for lining the edges of holes in sheet metal. I've had a roll of it for years and always use it on 2" dia. holes or greater. And yes John, it's mainly used for sheet metal and protects wire bundles from sharp edges when pulling through. It looks more finished w/o the edge showing for applications like these I think. Besides, I like additional garnish. :)
fiatslug87 Posted October 2, 2016 Posted October 2, 2016 Nice. Did you not have the tow hooks before? The stock hooks say max load 10,000 lbs, and if all the stock brackets are used should be pretty strong since they tie into the frame.
HOrnbrod Posted October 2, 2016 Author Posted October 2, 2016 Err, yes I did. I'll reword the title; it's confusing. I don't use the stock tow hook brackets; I'm using the HiCountry brackets I worked on with Matt Bush years ago. . HiCountry tow hook brackets / steering box brace:
Knucklehead97 Posted October 2, 2016 Posted October 2, 2016 Where did you get the little "light bar" from? I kinda want one on my MJ now :D
HOrnbrod Posted October 2, 2016 Author Posted October 2, 2016 Where did you get the little "light bar" from? I kinda want one on my MJ now :D The 30" BBLB-1 bar from: http://detoursusa.com/bumperbrow.php
Knucklehead97 Posted October 2, 2016 Posted October 2, 2016 Where did you get the little "light bar" from? I kinda want one on my MJ now :D The 30" BBLB-1 bar from: http://detoursusa.com/bumperbrow.php kind of pricey but I think I'll get one one day. Thanks!
Old man with MJ Posted October 2, 2016 Posted October 2, 2016 What exactly are you selling,the one from your truck, and what is the price? Thanks
HOrnbrod Posted October 2, 2016 Author Posted October 2, 2016 What exactly are you selling,the one from your truck, and what is the price? Thanks I'm not selling anything. This isn't in the classified forum............
schardein Posted October 3, 2016 Posted October 3, 2016 I've got a set of factory tow hooks and mounting brackets to add one of these days. I like those a lot more. Especially the way they tie into the sway bar mounts. Don't you run some sway bar mounts that drop down and forward slightly? How do those fit into this setup?
HOrnbrod Posted October 3, 2016 Author Posted October 3, 2016 The Synergy sway bar mounts fit fine. They just were not installed yet when I took the pics of the HiCountry brackets.
schardein Posted October 3, 2016 Posted October 3, 2016 Nice setup. Are the brackets available or are they a one-off?
HOrnbrod Posted October 3, 2016 Author Posted October 3, 2016 These are the brackets: http://www.synergymfg.com/Synergy-Jeep-JK-Rear-Long-Travel-Upper-Shock-Mount-Sway-Bar-Relocation-Bracket-p-29981.html I bought them originally for my JK but they work great for the MJ/XJ front bar too.
Minuit Posted October 3, 2016 Posted October 3, 2016 That looks nice and all but shouldn't everything on there be chrome? :D In all fairness to the guy above asking if it was for sale, before I realized this was in the Tech forum I thought it was a for sale ad too. The sidebar doesn't tell you which forum a thread is in.
