scguy Posted April 10, 2016 Share Posted April 10, 2016 Just picked up my first MJ, an 89. 4.0, AW4, RWD longbed. She's a little rough, but runs and drives. For a little bit, anyways. Overheating, had a head gasket done and that didn't fix it, PO thinks it has a cracked block. For $350, I can't complain. Plans: To be honest, at this point, I'm not sure. I like the 97+ swaps, I'm definitely considering a 4WD swap, I wouldn't mind trying my hand at an engine swap or stroker. I've looked for an MJ for years, so this project will likely be around for a while. Immediate plans: Diagnose overheating, pull carpet, overall inspection to see what I'm working with. Link to comment Share on other sites More sharing options...
scguy Posted April 10, 2016 Author Share Posted April 10, 2016 This is why I love SC trucks. That's a clean rocker. Link to comment Share on other sites More sharing options...
benjy_26 Posted April 10, 2016 Share Posted April 10, 2016 Good base to start with! Link to comment Share on other sites More sharing options...
Mattman6 Posted April 11, 2016 Share Posted April 11, 2016 Where at in SC are you? I would interested in the camper shell with it being a Long bed. I am out of Columbia. Link to comment Share on other sites More sharing options...
scguy Posted April 11, 2016 Author Share Posted April 11, 2016 On 4/11/2016 at 1:13 AM, Mattman6 said: Where at in SC are you? I would interested in the camper shell with it being a Long bed. I am out of Columbia. I'm down in Barnwell, about an hour south. I likely won't be needing the camper shell. Link to comment Share on other sites More sharing options...
scguy Posted April 14, 2016 Author Share Posted April 14, 2016 So I pulled the carpet back a bit, to get an idea of what I'm dealing with. Didn't look too bad Image Not Found Link to comment Share on other sites More sharing options...
Mattman6 Posted April 14, 2016 Share Posted April 14, 2016 On 4/11/2016 at 4:49 AM, scguy said: On 4/11/2016 at 1:13 AM, Mattman6 said: Where at in SC are you? I would interested in the camper shell with it being a Long bed. I am out of Columbia. I'm down in Barnwell, about an hour south. I likely won't be needing the camper shell. Yes I know where it is. I used to live in Aiken for a few years while in college. Let me know if you end up letting it go. I'd come down and get it off your hands. Link to comment Share on other sites More sharing options...
scguy Posted April 15, 2016 Author Share Posted April 15, 2016 Carpet and seats pulled tonight. More rust than I thought. Being in SC I have very little experience with fixing rust, but this looks minor enough just to patch and not replace the entire floor pan right? What should be my course of action? Poking with a screwdriver, this is all the holes I could find. Seat bolster bent to crap... Link to comment Share on other sites More sharing options...
87Chief Posted April 15, 2016 Share Posted April 15, 2016 I would get a grinder with a wire wheel and hit the entire floor with it. Then check and see where the rust goes through. You can always buy a floor patch panel and cut to fit in spaces. Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 16, 2016 Share Posted April 16, 2016 I'd buy a whole floor panel, XJ ones are cheap, then cut out the piece you need. Where those holes are, that should be a large patch. You don't even want to leave deeply pitted metal, even if it isn't through. So as said, wire wheel back from there and see how far you have to go. Get a good quality weld through primer and use it religiously. Use good paint and seam sealer when you're done, then undercoat the bottom again. Do not half @$$ rust repairs, it's just a complete waste of time if you do. Link to comment Share on other sites More sharing options...
scguy Posted April 25, 2016 Author Share Posted April 25, 2016 Fingers crossed, I'll be looking at a 89 Wagoneer for a parts vehicle. I love a Waggy interior. Link to comment Share on other sites More sharing options...
scguy Posted April 29, 2016 Author Share Posted April 29, 2016 Missed out on that. Made a little progress by getting the windshield leak fixed. The old windshield broke upon removal, but even so the total bill was only $180. One less thing to worry about. Link to comment Share on other sites More sharing options...
scguy Posted May 6, 2016 Author Share Posted May 6, 2016 Going to look at a parts XJ and an engine tomorrow. Ready to start working on the ol girl, but I've told myself I need to get my Nighthawk running first. Link to comment Share on other sites More sharing options...
scguy Posted May 7, 2016 Author Share Posted May 7, 2016 Here is my organ donor. 92 XJ Sport, 4WD, NP231, AW4. D35/D30 3.55. It has a new cylinder head with 5k miles on it, new fuel pump, distributor, starter, spark plugs, cap and rotor, Comp Cams custom grind cam, lifters, new header. It has the 01 intake manifold that has been port matched and coated with gold heat wrap with ZJ power steering pump (i think) I also like the 3 row aluminum radiator and triple electric fan setup. Not bad for $700. Link to comment Share on other sites More sharing options...
scguy Posted May 28, 2016 Author Share Posted May 28, 2016 Donor's in the shop. Couple hours of teardown. Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 28, 2016 Share Posted May 28, 2016 Good deal on the donor. Link to comment Share on other sites More sharing options...
scguy Posted May 28, 2016 Author Share Posted May 28, 2016 Donor engine stripped of head and cam. Cam and new timing chain installed Oil pan gasket and paint prep on the 92 Jasper engine that will be used Link to comment Share on other sites More sharing options...
scguy Posted May 31, 2016 Author Share Posted May 31, 2016 Put in a few hours today. Head on, new lifters in. New oil pan gasket and timing cover gasket, crank seal. Primed. And painted. I originally wanted to go with a different color, but black just fits everything. This engine is a Jasper Reman with 26k miles out of a 92 Jeep Comanche. Current setup is 4.0 HO block bored .060 over, 7120 HO Head (mostly new, only 5k miles on it from Dover Heads in Atlanta), 01 intake manifold, Comp Cams custom grind (mild torque cam), and an aftermarket header of unknown origins, Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 31, 2016 Share Posted May 31, 2016 That engine should be a nice package. :cheers: Link to comment Share on other sites More sharing options...
scguy Posted June 3, 2016 Author Share Posted June 3, 2016 I'm trying to decide on a lift. I want to run somewhere around 3-5". I'm torn between piecing a lift together or just getting the Zone 4.5"kit and a track bar. I plan on swapping the D35 out sometime down the road, so the add a leaf only needs to last till then when I go SOA. Link to comment Share on other sites More sharing options...
scguy Posted June 5, 2016 Author Share Posted June 5, 2016 Empty Post Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 5, 2016 Share Posted June 5, 2016 That firewall connector always looks like that. They put some semi-drying dielectric grease on it when they assemble it. I wish I knew what it was and where to get it, because it seems to work better than a lot of other things. Link to comment Share on other sites More sharing options...
scguy Posted June 10, 2016 Author Share Posted June 10, 2016 Lift is here. I went with the Zone 4.5" kit. Hopefully I can begin on it tonight. Link to comment Share on other sites More sharing options...
88Pghcomanche Posted June 10, 2016 Share Posted June 10, 2016 On 5/31/2016 at 7:26 AM, DirtyComanche said: That engine should be a nice package. :cheers: X 2 Looking good. Link to comment Share on other sites More sharing options...
88Pghcomanche Posted June 10, 2016 Share Posted June 10, 2016 On 4/10/2016 at 3:25 AM, scguy said: On 4/15/2016 at 4:34 AM, scguy said: Are the seats salvageable? Or do you plan to ditch them? Link to comment Share on other sites More sharing options...
