So I did a goof
gogmorgo
And accidentally on purpose put in a bid on this wreck, made a typo in my bid so it was much higher than intended and then won... Or possibly lost, depending on how you look at it. Either way I'm now the not-so-proud owner of this fine KJ.
10301200_551491268361295_282479273090990
12832372_551491241694631_311577704108005
It's an '03 4-banger/standard with ~45,000 miles. That's all I know from the listing, but I'm already into it $400... I haven't seen it yet, but unless my research is wrong, I'm thinking the rear axle is going to be a 4.10 8.25 w/discs, which is what attracted me to it in the first place. My plan is to pick it up tomorrow (already had a "recovery" day booked off work, just not that kind of recovery...), grab the pos, drop the axle, and scrap the carcus. Is there anything else I should be looking at that would be useful on an MJ? Assuming there's anything useful left on it at all...
In regards to my plan for the axle, I think it was JeepCoMJ put me on to it a couple years back. Not sure yet if I want to prep the axle for the MJ's leaf springs or prep the MJ for the KJ links (and I know which will be easier) but that decision is going to be put off until I have the rest of my lift &c planned, I'm just going to grab as much as possible out of it so I can leave my options as open as possible in that regard.
And kids, don't get yourselves a credit card. It enables $#!& like this.
The t-case will be a 231 or a 242...that would be worth something...and I don't know if you would want it for your MJ but my wife has the same KJ and the buckets are big and comfortable
Yeah, I was thinking about grabbing the seats... I'm a little short on furniture in my place, lol. Didn't even look twice at the tire carrier, but I'll check it out too. I've already got a 231 kicking around, but if it's a 242 I'll grab that as well. I was thinking the trans might be a decent potential swap for my Lada and maybe the motor but I don't know how much of it's left. I also don't want to spend too much time with it, I'll only have about a six hour period between when I can pick it up and when I can drop it off at a wrecker unless I can find a closer one. I also don't want to hang onto it too long either and deal with parting it out... I'm sure xymj can attest to how many KJ parts sit forever on kijiji and my landlords are already not happy about the half-XJ I have sitting in my backyard already.
It does have discs :D
996992_552210271622728_63632234176427191
And I'm pretty sure that's an 8.25.
For how crushed the front end is, there's very little protrusion into the passenger compartment. A bit of damage where the trans got shoved around in the tunnel, and the door gaps are a little off, making it seem like the body got a bit of a twist, but none of the glass is even cracked, and all the doors still open and close properly.
12790969_552210244956064_375476368729619
5388_552210218289400_4190574902835680887
The very rare quick-change timing belt option. heh
1174862_552210171622738_3578864303882793
Not sure where the shifter went but the holes don't line up any more... big surprise.
10271495_552210104956078_757801731497922
Interior's not bad but everything's covered in dog hair. I'm still up in the air about the seats, don't know if I'll have the time to pull them, but they're in pretty good shape.
1508179_552210378289384_4078219208091953
12115817_552210348289387_809521460269737
1929740_552210331622722_8509216456316365
Shameless promotion of a local beer. It's superbly mediocre.
10288760_552210314956057_196326092362411
11220463_552210294956059_665651197384180
It is 4x4, with the 231. Pretty basic spec, although it looks like it might have a towing package if such a thing existed... 7-pin trailer plug and wiring look factory. Didn't think to look for a brake controller but if there is one I'll for sure nab that.
I have those rims on my MJ. I don't like them lol
Get this, they've got @#$%ing locking lug nuts on them and the key isn't in any of the obvious places.
So I missed my window to get it to the wrecker I was intending on by a long shot. Haven't even started pulling things. Had to borrow the tow vehicle from my dad and he took forever getting it here this morning. There's a much closer wrecker that's the only one I know of open on Saturdays in the area, but they close at noon. Hopefully I can get at least the axle out of it and some other goodies by then... shouldn't be too much trouble I don't think.
Haven't sat in the seats yet. I haven't found many seats from that area comfortable either. The ergonomic design for the average 5'9" person doesn't work so well for someone 6'2" like myself. Pushes my shoulders forward leading to me driving all hunched over and the lumbar support, if even there, is too low to do anything for me.
I hope that's not the case with these seats, but I don't plan on putting them in another vehicle if they do come out... They'd be going into my living room :D
Don't think I got so lucky. Everything got shoved back pretty hard. The bellhousing's cracked and I don't want to know what that did to internals. Also the 231 housing is cracked where the front driveshaft got rammed into it, so that's nfg as well.
I've got the axle out. The lca bolts were absolute bastards. The nuts must be some kind of distorted thread. That or just old and rusty, but I had to creep them off by rocking them back and forth with my impact gun. I'll have to call around to wrecking yards now cause I just missed the only one I knew would be open... They close at noon.
The gas pedal?
One of the tail lights is cracked.
If somebody actually wants something I'll try to make an effort, but I'm just about sick of thinking about it. I got the rear suspension out and then a housing comity rep showed up and gave me an official warning that I wasn't allowed to keep it around, (well, technically just that I can't take it off the trailer...) and also that I need to get rid of my parts XJ as well before the end of the month.
Sigh.
I'm pretty sure the non-crd libertys had normal throttle cables, but figured I should ask.  we have an electronic accelerator pedal.  I hate it and suspect it's the cause of my issues. :fs1:
and a search has shown a part number gap between your taillights and ours so I'm guess that's out too.  :(
Well I can see what's left, but even if it is intact I still may need the jaws of life to get anything out of the engine bay...
Diesels and gas engines do the throttle thing very differently. Are you sure they'd even be compatible? Or are you just thinking the pedal itself?
