... Okay, not really, but as i sit here I can't think of
a better explanation:
1988 - 4.0L/Ax15/D35/LWB
Went to reinstall the Ba10 driveshaft onto the back of
the new Ax15 transmission. According to all the literature,
the Ba10 shaft is 50" and the Ax15 shaft is 50" so
theoretically it should pop right on... but as you can see
from the picture its not exactly a precision fit.
Now if I jack the truck up and pry it in I think it'll fit,
but itll be TIGHT. From what I hear that is not an ideal
situation for the shaft or the TC. I also worry about what
might happen if I hit a large bump in the road.
Others have been telling me to shorten the shaft, but
before I do I just wanted to make sure I didnt miss
something important. I do not want to modify a good part
just to cover up a problem with another - I want to get
this right.
Any suggestions or observations?
What Pete said.
Are all the bolts to the trans and tcase tightened?
You had to change the tcase to 23 splines.  What year and model (XJ, YJ, TJ) were the trans and tcase out of?
Looks like your about 2" off...
And you don't want to install a TIGHT driveshaft because it will break your t-case...
Best thing to do is install driveshaft yoke and bring it out 1" then measure center to center (u-joint cap) to the rear axle...
Did you by any chance swap the axle as well? i thing the D44 and 8.25 yoke stick out about an inch more than the D-35...
When i swapped from BA10-5 to AX 15 the drive shaft was fine. but i had to shorten it when i swapped from D-35 to D-44 rear axle.
Ax15/231 is out of a 98 Xj. Motor and
Axle are stock to this truck.
The '98 is a different animal. Starting in 1997, I believe, Jeep changed the transfer case output. On our MJs and older XJs, the front yoke slides into the tailshaft housing and the seal rides on the machined surface of the yoke. The newer style transfer case is sealed and the yoke just has a dust boot around it.
Looks like you're trying to mix apples and oranges.
I took the yoke off the Xj because the spline
count was different. It looked like it was the
same lenght as the old Mj one. It makes perfect
sense if the tailhousing is a different lenght
though...
And i do plan to put in my D44 soon, but i was
gonna save up and have the locker installed
during the rebuild... ie: $$$... i need to get
her roadworthy immediately but the closest
driveshaft shop is over an hour away opposite
of my work schedule so itll be a week or more
to get it cut. I was hoping to avoid having to
do it twice but looks like thats my only viable
option at this point...
Thanks 87 - I can't seem to find any information regarding how
much difference the changeover affected the overall lenght,
but if there is a difference the only thing left to do is get
cutting...
So I had 2.25 inches cut from the driveshaft, here's
how she sits now - shaft bottomed out on yoke:
Since (theoretically speaking) I shouldnt have had to
cut it at all, I decided to err on keeping the shaft
from falling off the trans. Worst case senerio I can
always go back and cut it again...
  • 8 months later...
Just a quick update... went to try to bleed my
slave cylinder today and I noticed that the
driveshaft has now returned to its pre-Ax15
lenght... minus the 2" I cut off.. so now the
the shaft is sitting on about 2" of the yoke
on flat ground...
I'm about dun...
Hum..... Well at least the Dana 44 pinion is 1" longer than the D35 so when you swap axles you will be better off .... That is as long as the length don't change again!
