Thinking of a V8
I've seen guys put a Chevy 5.3 in Cherokees without too much trouble.  The small block Mustang motor is also pretty popular and fits without too much modification.
No matter what you do, you'll have to adjust the motor mount locations which kind of requires cutting, but that's not too bad.
After researching a V8 swap for a while, I decided that building a 4.7 stroker gives you V8ish power without altering the engine bay at all.
okay thank you i will have to talk it over with my brother Jeff (blue88comanche) to see what he thinks would be the best choice.  One of the big reasons for the engine swap would be to completely fix the engine.  It is not currently running properly.  It is really hard to describe what is going on with it but what i can tell you is that it starts off running good then it bogs down to 15mph and continues to slowly go down from there. it will continue to idle rough and no matter how much you give it gas it will not accelerate.
I feel like doing a complete motor change due to a poorly running motor is not a great idea. Even if it turned out to be something catastrophic or just a tired out motor, swap in or rebuild your 4.0 and keep trucking. Be a whole lot easier and cheaper.
Because of this thread I did a bunch of reading last night on V8 swaps and building up strokers .... mostly because both are AWESOME  :yes:  :yes:
It seems like the 4.8 or 5.3 Vortec is a popular option.  There is a ton of info out there on the swap and you can even buy adapter kits easily.  Seems like this swap runs in the $3k range if you do it right - maybe less if you get a smoking deal on the motor/trans and do all the work yourself.
The 4.6 or 4.7 strokers are also popular, and put out some impressive numbers ... especially in torque (more than the 5.3 even).  The beauty of the stroker is that it's a direct drop in replacement.  They seem to run in the same ballpark as a V8 swap.
I guess it comes down to what you like .... or what you have available.
Personally, I love the idea of picking up a decent 4.0 from Craigslist for a couple hundred bucks .... building it into a stroker in the garage .... then dropping that 275HP torque monster into my Jeep in one evening after work.
Building a 275hp stroker is going to cost more than $3000.  Almost every build log of a stroker 4.0 I have seen ends up in the 4k+ range by the time all parts and machine work is considered.  Now, if you want to do a budget stroker with minimal to no head work and a mild cam you could be looking at a cool 230ish hp stroker, but realistic costs will still put that in the 2000-2500 range (never underestimate the added up costs of little stuff).  You will still have tons of torque.
I've never had one but a lot of the stroker info seems exaggerated,seems that a lot of strokers don't break 200hp at the wheels.
they also typically seem less reliable than the original 4.0l.
personally i think i would rather have a stock V8 that reliably makes the same or more power.
200HP on the ground is a ton for an MJ.  If you go much more than that you'll have to upgrade the trans, TC, axles, drive shafts, cooling system, suspension, etc.  That's big big money.
Strokers are perfect for people who want a noticeable increase in power with a mostly plug and play swap.
If you need more power than that, then a V8 swap will certainly do it.  Just be ready for a big project.
Going through this exact swap now (5.3 vortec) in the Manche (taking plenty of pics) the 3k estimate is pretty light. I will have around 3k in parts alone my engine and tranny were free! I decided to do it, because some buddy's that have mall crawlers have done it and the power WOW it's exactly what you think would happen if someone shoved a V8 in there trust me. I've rode in a lot of strokers doesn't compare in the "seat of pants" department. Would like to add that I'm not saying a 4.7 stroker won't run with a stock V8 and won't put roughly the same useable power to the ground, but most people will have the same reply when getting out of an LS MJ "Holy $#!&"!
