  • Replies 89
Ok all done for now 4wd is in also the 3" lift is installed
Here is picture of cut down drive shaft $90.00 and 24  hour turn around lift kit installed Plow installed
  • 3 weeks later...
I use this truck to plow my personal driveway and a friends or 2 . I replaced both axle shaft u joints and both axles broke at u joints.
I ordered g2 chromealloy axles and installed them so far so good. I guess I did something wrong when I installed thenu joints
Do you have any pics of the truck with the 3" lift before you put the plow on? I'd like to see how much the plow sagged the BDS coil springs. Dosent look as tall as other bds 3" kits iv seen installed, how ever those were on Cherokees. I just ordered a 2" kit for my friends build I'm assisting him with and am now thinking I should of got him the 3".
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
Nice looking truck.  I still have the white '92 that we swapped several years ago.  Other than blowing through clutch slave cylinders it's running strong!
That is a clean looking MJ!  Makes me somewhat wish I had kept mine at the lower height and the Ravine wheels.
  • 3 weeks later...
Wow this thing is a rust bucket kinda reminds me of mine when i just bought it.. you have your work cut out but i'm sure nothing you can't handle...all the best!
