Jargon Posted July 23, 2016 Posted July 23, 2016 Wow! That's an intimidating amount of rust! Kudos to you for being confident enough to tackle it. :thumbsup: I'm excited to follow your progress. :popcorn:
ahmincha Posted July 23, 2016 Author Posted July 23, 2016 Thanks for the encouragement Jar. If the frame/unibody was not in good shape I would not be doing this
ahmincha Posted July 23, 2016 Author Posted July 23, 2016 I had to cut out about 1.5' of rust metal and replace it Welded in
ahmincha Posted July 23, 2016 Author Posted July 23, 2016 A coat of rust to metal paint and them a coat of weld thru primer
ahmincha Posted July 23, 2016 Author Posted July 23, 2016 A few pin holes all welded up And a coat of rust to metal paint
ahmincha Posted July 24, 2016 Author Posted July 24, 2016 So I am starting to weld on the rocker. being as I am not a body man can I use filler to cover the rest of this weld to make it look better?
DirtyComanche Posted July 24, 2016 Posted July 24, 2016 Applies sparingly, yes, should be fine to do that. Make a little round profile paddle (or buy one) to put it on evenly and as minimally as possible.
ahmincha Posted September 5, 2016 Author Posted September 5, 2016 Startrted the passenger side but this time I used a plasma cutter instead of cutoff wheels
ahmincha Posted September 20, 2016 Author Posted September 20, 2016 Strokermjcomanche came through with the roof section. Was glad to meet him real nice guy hope to meet with him again. Thanks again!!!
ahmincha Posted October 19, 2016 Author Posted October 19, 2016 Passnger side floor welded in Driverside started
DirtyComanche Posted November 4, 2016 Posted November 4, 2016 Damn, that's a lot of bodywork, but it looks like it has paid off!
ahmincha Posted November 12, 2016 Author Posted November 12, 2016 All chassis saved (por 15) Like material
buxmj Posted November 16, 2016 Posted November 16, 2016 Wow, awesome work! Keep the picks coming! Buck.
ahmincha Posted November 20, 2016 Author Posted November 20, 2016 Thanks buxmj I'll take more pics as I put her back together
dragordie Posted November 20, 2016 Posted November 20, 2016 makes me kind of torn between should I have kept my Eliminator 2WD insteed of converting to 4WD. Wow Nice WORK. :thumbsup: :thumbsup:
