Alec Posted June 9, 2015 Posted June 9, 2015 Just bought a 88 commanche yesterday for $400. 2.5 4cylinder with 5speed manual. Not sure if 4wd though. Was too excited and forgot to check. Picking it up next weekend. Can't figure how how to post a pic. Help???
Alec Posted June 9, 2015 Author Posted June 9, 2015 Oh ok. I use that for another forum too. Thanks buddy
Wesleypipesyo Posted June 9, 2015 Posted June 9, 2015 It looks like there might be a small air gap in the intake. Looks like fun.
JurassicJeep24 Posted June 9, 2015 Posted June 9, 2015 Looks like you have a lot of work ahead of you.
Alec Posted June 9, 2015 Author Posted June 9, 2015 That's what I was thinking mnkyboy. And I definitely do. First I just wanna get it running and 4wd swap. I have a spare set of 31's I'm gonna throw on for now. How much lift will it need to clear them? I've never touched a commanche before
Alec Posted June 9, 2015 Author Posted June 9, 2015 It looks like there might be a small air gap in the intake. Looks like fun. thats a random art sitting in the engine bay lol. But he'll I'll take free parts
Wesleypipesyo Posted June 9, 2015 Posted June 9, 2015 It looks like there might be a small air gap in the intake. Looks like fun. thats a random art sitting in the engine bay lol. But he'll I'll take free parts hahahaha
JurassicJeep24 Posted June 9, 2015 Posted June 9, 2015 Depending on where you are located I have a transfer case out of an 89 laying around I don't need, its mated to an aw4 auto but that won't work with the 2.5. I have the front dana 30 from the 89 too if you want a CAD axle.
neohic Posted June 9, 2015 Posted June 9, 2015 ... I've never touched a commanche before :shake: Nor have you paid attention to the badge on the fender. :D
Minuit Posted June 9, 2015 Posted June 9, 2015 Just going to take a wild guess and say that, considering the algae growth on it, it doesn't run. Fix that part before you think about lifting it. I also see what looks like a lot of very badly spread Bondo on that bed. It looks like you have a lot of work to do before even considering turning it into a "mud truck." In any case, good luck!
Alec Posted June 10, 2015 Author Posted June 10, 2015 Obviously I'm gonna get it running and driving before everything else. I already bought a battery, distributor, plugs, and wires and a new fuel filter just for good measure and the bondo I don't care about. It's getting a rattle can camo paint job
Alec Posted June 10, 2015 Author Posted June 10, 2015 Depending on where you are located I have a transfer case out of an 89 laying around I don't need, its mated to an aw4 auto but that won't work with the 2.5. I have the front dana 30 from the 89 too if you want a CAD axle. I'm in New Jersey. And my parents live in kingston ny so I have easy access to both areas
Jeep Driver Posted June 10, 2015 Posted June 10, 2015 I don't think you are going to get it running without major expense. Some things just should not happen.
Alec Posted June 10, 2015 Author Posted June 10, 2015 Jeep driver. I pulled a 78 f150 out of a field. Had been sitting for 8 years and it fired right up with some fresh fuel and a battery.
Alec Posted June 22, 2015 Author Posted June 22, 2015 Ok so I picked up a Dana 30 and np231 tcase for $50. Tcase needs a rebuild. Where's the best place to get the rebuild kit at a fair price
Jeep Driver Posted June 23, 2015 Posted June 23, 2015 Have you got the truck running yet? And you know you'll need a new trans too, right?
Alec Posted June 23, 2015 Author Posted June 23, 2015 I'm collecting parts for it. And actually I just need a tail shaft which I have
Jeep Driver Posted June 23, 2015 Posted June 23, 2015 Alec, I was trying to lead you to study for yourself......much reading is required. The 2WD AX5 that you have will need to be replaced with a 4WD AX5.......they are NOT the same. You cannot just swap a tail shaft. Further, your Comanche is not a F150, the likelihood of you puring in fresh gas and a new battery and having it fire up is next to 0.....nil. You really need to read up.
Alec Posted June 24, 2015 Author Posted June 24, 2015 The tail shaft housing that's on the back of every transmission which allows either a transfer case to be bolted on or turns the output shaft into a yoke. I think you need to do some reading as well if you don't know what a tailshaft is
shelbyluvv Posted June 24, 2015 Posted June 24, 2015 Follow Jeep Drivers advice. The AX-4/5 is either a 2wd or 4wd trans.
