Some TLC and upgrades are coming soon!  Starts with finally having functional reverse lights (new switch in the trans).
Now to get the LEDs tied in.
  • Replies 284
Posted Images
Over the last couple of years I've gone back and forth in my head about a hundred times; TDi? 4.8LS? 318? MegaSquirt-ed 4.0?
But last week I stumbled upon a local deal I couldn't refuse and took the bait.  My mind has been made up for me!
Its a 2000 Jetta TDi with the ALH engine.  At almost 400k on the clock the engine will definitely need gone through, but it runs and drives.  I'll be pulling all the necessary parts here soon but I won't likely see any swap progress for a long time.  This is the swap part supplier I'm considering.
Oh well, I'm still excited!  :comanche:
  • 2 months later...
I used shackles for a 1/2ton Chevy Express / GMC Savana van.
A word from the experienced: always use copper/nickel brake lines if they're available (cunifer, copperhead, cuneiform, whatever).  Flares like butter, bends clean and easy by hand, and will never rust.  The stuff is awesome!
I haven't measured the actual ride height yet, but It feels like I'm driving a freakin' Tonka truck :applause:
Now this would be a nice place to say "I drove it in to work and lined her all up and now I drive it everywhere!" except I seem to have broken the frame at the steering box  :crazy:
As they say, "welcome to the upgrade treadmill!"
I like it. I want to lift mine just so it's easier to climb underneath it.
Sent from my LGLS992 using Tapatalk
  • 1 year later...
The truck has been making lots of pops and creaks in the steering box region since the SOA and new tires; my suspicion was the usual broken aluminum spacer and/or tearing frame.  After much deliberation I decided to get the JCR steering box brace kit.  If this doesn't suit my fancy later on I can always sell it and go with something else (I really wanted a sector shaft support of some kind but wasn't impressed with the available options).
To my pleasant surprise this is what I found:
Crazy, right?!
Got her all painted up and installed the brace kit and steering box.  I haven't driven it enough to really note much of a difference though.  Peace of mind at least.
YOUn8X5h.jpg?1
nZS8bIWh.jpg?1
Darn the luck, looks like I'll have to fab a new front bumper for her now... :brows:
I do like the "stubby" look on XJ/MJs...
4.0 AX-15 to TDi adapter kit from Randy at TD Conversions.  This dude (Randy) is active on the boards and has supplied adapters for quite a few completed swaps out there.
My actual conversion is still a ways out but this is the biggest single puzzle piece.  Gotta slowly acquire the rest as finances allow.
Picked up an AR7753 from JRE (Minuit here on CC) and installed it today.  It looks and sounds great!  Dash looks much better now.
  • 10 months later...
TDi update:
THIS HANGS TOO LOW
A/C bracket and compressor from an '04 Passat 1.8T gasser fit onto my 2000 Jetta ALH. Had to open up an un-used bolt boss and clearance it a bit to fit. Couldn't manage to break the crank bolt loose in the junkyard so I can't confirm it all will line up.  High hopes of leaving the Jetta's accessory drive alone and using it's A/C compressor for on-board air.
  • 6 months later...
The truck has been under the knife since this time last year.  Hoping to take care of the rusted rockers and floors, fab up a new cross-member/skid and front bumper, finish the rear bumper, straighten the body, prime and paint.  I toyed with also doing the TDi swap as well but decided to give the 4.0 one more "season."
Sauce:
it kills me a little every time I see someone diving into the rust repair and not pulling up the frame caps, :(
gotta do it right!  :D
I agree! (Obviously)
I'm not looking forward to the floorpan job though. The rust crept pretty far; I'm afraid it'll be just on the border or completely outside of where commonly available patch pieces cover.
Suggestions are welcome.
it's not impossible to fab your own patches. :L:   plus POR-15 can be used on anything you can reach but don't want to cut out.
