what manual locking hubs should I use?
There are NO manual locking hub kits available on the market right now. They are no longer produced as they did not sell, and were not ever a factory option on any jeep with 5x4.5 bolt pattern
There are 3 or 4 companies that sell them aftermarket. They use Ranger hubs. I grabbed the Warn kit about 10 years ago for only a couple dollars, its still going strong. I have the 5x4.5 kit.
I don't think locking hubs are the answer for the OP. If all that you want to do is get away from the vacuum actuated CAD then just do a one piece axle conversion, get a posi-lok or build one yourself from directions available from the internet, or swap in a later one-piece axle assembly from a later XJ. That kit is stupid expensive.
YIKES!
$1300, plus labor. You can manually lock the front axle disconnect for free, in about a half hour. As described in Cruiser's link. For what it's worth, this manually (and permanently) does exactly the same thing as the Posi-Lock, for no cost and without an unreliable cable actuator.
Done.
